| New Reply |
Japan Earthquake: nuclear plants |
Share Thread | Thread Tools |
| Apr6-11, 12:02 PM | #3095 |
Japan Earthquake: nuclear plantshttp://www.ic.unicamp.br/~stolfi/EXP...t-un1-full.png Any hope this could just be some H2O vapor ? And (if the question has not been raised yet) : 7 atm is a very high pressure, I thought the desin was for 4 atm ... why inject nitrogen under such circumstances ? |
| Apr6-11, 12:09 PM | #3096 |
http://english.kyodonews.jp/news/2011/04/83613.html |
| Apr6-11, 12:17 PM | #3097 |
Admin
Well, the design pressure is greater than 4 atm, but the operating limit would be specified at 4 atm to ensure that the containment had sufficient margin to failure. Theoretically, the concrete the steel liner should hold to about 7 atm, although the concrete might start cracking (leaking). Leak-before-break is a typical approach to designing containment systems. |
| Apr6-11, 12:25 PM | #3098 |
| Apr6-11, 12:31 PM | #3099 |
But the source gives temperature slowly going down; of course, they can think the data are wrong but it seems to me the 2 measures are "coherent" both in time and between them. On the other hand, it does not exclude increase elsewhere in the system, of course. |
| Apr6-11, 12:34 PM | #3100 |
=> in which way to you find it confirms anything? edit: which |
| Apr6-11, 01:06 PM | #3101 |
According to the article "Nishiyama said past hydrogen explosions have likely occurred due to hydrogen accumulation caused by the reaction of melted fuel rods' zirconium with steam from the coolant water". It also states that "The utility has been pouring massive amounts of water into the reactors and their spent nuclear fuel pools as a stopgap measure to cool them down. But the measure is causing ''side effects,'' such as the detection of contaminated water in various parts of the nuclear complex and some leakage into the sea." TCups points out "That big old steel reactor vessel sets on a pedestal like a long, skinny boiled egg. It is made of heavy steel, and it is full of water and one of the densest things I know of -- uranium. Furthermore he states "If the lateral acceleration forces exceed the design parameters, the pressure vessel risks becoming the upside down clanger in a giant bell shaking at about a 9 on the Richter scale." The key vulnerable structure if that happens is the high pressure steam outlet pipe. If that cracks or leaks, then you have high pressure steam and shortly thereafter, hydrogen in the primary containment" |
| Apr6-11, 01:29 PM | #3102 |
Admin
One can find there assessment reported in the NY Times here:
http://djysrv.blogspot.com/2011/04/n...fukushima.html |
| Apr6-11, 01:38 PM | #3103 |
7 atm, isn't that the reading inside of the RPV!? And I thought the operating pressure in the RPV is something like 10 times that!? |
| Apr6-11, 01:41 PM | #3104 |
Thank you.
ps: I'm i the only one with the google doc linked in the article displaying upside down? |
| Apr6-11, 01:56 PM | #3105 |
Admin
| Apr6-11, 01:56 PM | #3106 |
Admin
| Apr6-11, 02:15 PM | #3107 |
Firework Colorants
| Apr6-11, 02:46 PM | #3108 |
Has anyone seen an estimate of how much total radioactive material has leaked (or still is leaking!?) or been dumped into the sea? I suppose most interesting is the amount of Cs-137.
Maybe someone here would like to maka a personal estimate? The ocean is vast but not infinite... |
| Apr6-11, 03:24 PM | #3109 |
| Apr6-11, 03:26 PM | #3110 |
http://www.tepco.co.jp/en/press/corp...1040613-e.html
"Injection of nitrogen to reactor containment vessel of Fukushima Daiichi Nuclear Power Station Unit 1" (with schematics) |
| Apr6-11, 03:27 PM | #3111 |
Admin
As for fuel release, it would be useful to find out if there are any detections of: Nd isotopes, and Ce144, Zr95, Ru103, Ru106, Ba140, Eu154 in addition to the volatile Cs isotopes, which are gamma emitters. Other than the Cs which can easily get out of the fuel because of low melting temperatures and solubility, the others are harder to get out and therefore their presence in the environment would support loss of fuel from damaged/breached fuel rods. |
| New Reply |
| Tags |
| japan, nuclear |
| Thread Tools | |
Similar Threads for: Japan Earthquake: nuclear plants
| 8.9 earthquake in Japan: tsunami warnings | Current Events | 671 | ||
| New Nuclear Plants | Nuclear Engineering | 9 | ||
| Gen IV Nuclear Plants | Nuclear Engineering | 10 | ||
| New Nuclear Plants | Nuclear Engineering | 14 | ||
| Astronomer Predicts Major Earthquake for Japan | General Discussion | 65 | ||
