New Reply
Japan Earthquake: nuclear plants
Share Thread Thread Tools
May7-11, 07:04 PM   #6121
From the U-Tube real time camera it looks to me as if most of the debris from the upper floors of #3 are gone.
Then there are these stills from last night (unless they are a photoshopped prank.)
http://twitpic.com/4unrpd
But not a peep out of anybody.
May7-11, 07:23 PM   #6122
Unlurk, I was watching about the time those stills were taken. it was odd because I'm used to the puffs of steam coming out regulary, but there was nothing. Then very suddenly 3 and 4 both got very busy. At first I thought it was fog because it can be pretty random, but then it cleared up enough to tell it was 3 and 4. I figured they had started giving them water again.
May7-11, 07:27 PM   #6123
Unit 4 looks to have some of it's junk taken off the top.
But I'm less sure of that.
http://www.youtube.com/watch?v=Ck_KE...layer_embedded
May7-11, 08:34 PM   #6124
Quote by yakiniku View Post
5月1日の政府・東電統合本部全体会合の議事録。
『このままいくと8日にも高濃度の放出が行われる。』
『細野補佐官から,本件は熱交換機の設置といった次のステップに進む上で非常に重要である,また,(今後,放射性物質が外に排出され得るという点で,) 汚染水排出の際の失敗を繰り返さないよう,関係者は情報共有を密に行い,高い感度を持って取り組んで欲しい,とする発言があった。』"
Translation (non-literal and our understanding):
I received 3 emails with attachments from junior government officials in the energy department.
The first email:
Minutes of meeting between TEPCO and the government on the 1st May.
"If the current situation continues, high density radiation will be released on the 8th May."
"Mr Hosono said: It is very important to go to the next step regarding the installation of the heat exchanger machine. For the concerned parties, be careful of the sharing of information with high sensitivity so that the same mistakes aren't made again like the release of the radiated water previously.
...Checks date - Checks webcam...
May7-11, 09:16 PM   #6125
Quote by Dmytry View Post
Well, don't forget that when the building was engineered, the earthquake of such magnitude was considered unlikely to the point of impossibility*, and so was the explosion. I'd say with 4 out of 4 reactor buildings doing things that previously were considered impossible (the hydrogen explosions), all bets are off.
Clearly those things are not quite an example of stellar engineering.
* the quake was much stronger than what buildings were rated for.
I think we're in agreement here... I still don't believe there is an eminent danger of #4 as a whole collapsing, but would like to see evidence countering the apparent (new) lean portrayed by the live camera viewpoint. I've done some looking but haven't found as of yet. Anyone know of a daily satellite feed or aerial imagery? Barrel distortion is more often associated with wide angle lenses, not telephoto.
btw, looks like there's a new url for the live stream:
http://www.youtube.com/watch?v=FptmoVcgpqg
atm not seeing anything from #3 and #4, and only a bit of white smoke from #2. Lots of atmospheric distortion from daytime heating (wavering images)...
May7-11, 09:50 PM   #6126
Quote by Bodge View Post
Interesting... I don't think there is a fire or anything like that. Could it be concrete dust stirred up by some part of the building collapsing, e.g. the remaining pillars on the sea-side? Or, if that's right after they started pumping water, maybe some kind of steam explosion?
EDIT: As for the mystery May 8th radiation release (supposedly opening of unit 1 airlock), I don't think these unit 3 events have anything to do with that.
EDIT2: TPS camera during daylight shows unit3 pillars on the sea-side are still standing.
May7-11, 09:56 PM   #6127
The first email:
What mistakes is he referring to? The release of the radiated water, or sharing of the information regarding it?
The wording of the translation is ambiguous, but my cynical side says this email looks like a caution to the concerned parties to keep their mouths shut.
May7-11, 10:02 PM   #6128
Quote by Borek View Post
At STP it is wrong, for reasons so obvious I feel ashamed pointing that out.
Call it nitpicking if you like
Uhh, yes at STP you are right that H2O usually prefers not to be in gas form.
But for my defense, I did not specify the temperature and pressure, but I wrote "H2O gas" ...
May7-11, 10:29 PM   #6129
Quote by MiceAndMen View Post
I read the original as saying the opposite: keep "related parties" closely informed, and treat this matter with the great sensitivity, so as to avoid a repeat of the mistakes they made with the water-release.
Recall the water-release problem: they announced publically that they were dumping low-level contaminated water just before they had to do it, and got lots of complaints from fishing groups, neighboring countries, etc. They are saying to keep everybody who might be affected in the loop this time.
May7-11, 10:34 PM   #6130
Quote by NancyNancy View Post
It was suggested that I share this here. A couple of people had mentioned #4 looked like it was falling over or it is an optical illusion of the wide angle lens on the TBS camera. I am not totally convinced it is the camera since there is no oddity on the opposite side of the camera. I also have a screen shot that shows even further right of #4, everything is totally vertical. #3 isn't leaning, as if there was a distortion, it would gradually get worse rather than being sudden in one spot only.
Imho unit 4 is not leaning. An easy way to check would be to look if there is any difference in how unit4 appears compared to earlier footage of that TBS camera. Also there seems to be a lot of atmospheric distortion in those images. My personal impression is that unit 3 also appears slighlty tilted in those images sometimes. As for the one spot only, maybe there is some dirt on the their camera lens...
Assuming for a moment it really is leaning slightly, that could also be related to some discussion further up that the ground there might have moved during the earthquake, and the whole complex seems to have moved down from the point of view of the TEPCO webcam.
May7-11, 11:07 PM   #6131
Quote by rowmag View Post
Yes. If I may, I would like to give you an unpolished translation (one that retains much of the grammar of the original) to give people who do not know Japanese a better idea (of course, we have to change the order of the parts of the sentence or the statement will be garbled to an English speaker):
"Also, (from now on, this is the issue of radiactive material being released to the outside,) I would like authorized people to share information densely/ closely/ tightly/ minutely, in a manner that does not repeat the mistake(s) on the occasion of emitting/ releasing contaminated water, to tackle/ deal with (the) high sensitivity."
Given that he uttered this in public, and given the many (even international) problems that the release of contaminated water have caused, he surely means that he would like those responsible to not repeat the error of the past, which was a lack of information, and to be aware of the sensitivities of other parties concerned.
(edited myself)
May7-11, 11:10 PM   #6132
I don't know about Japan and about the time when the units were built, but at least some (if maybe few) people did consider the effects of a possible hydrogen explosion, see the paper linked to in post #6055.
In general, I would also have expected that NPPs would be engineered a bit safer than that, but they survived the earthquake itself pretty well, as it seems. Too bad they apparently "forgot" about tsunamis...
May7-11, 11:11 PM   #6133
I have not figured out how to quote in posts here yet. In reference to #4 leaning over. I have more images, will have them online tomorrow morning and will also share them here.
I spoke with a couple of reporters in Japan again. One who has been reliable on lots of other information about the plant and has contacts with the workers and technical staff there told me a couple of things.
1. that is not an illusion on the TBS camera, they asked the technical crew running the camera, has a professional direct contact with them. Technical crew says the building is leaning over, it isn't a distortion of the camera lens.
2. the building is leaning over, confirmed it with workers at the plant. They have a company contracted to try to come in and install the cement pillars but didn't have word if that has started or is still in planning (or if it can still happen).
Sorry I can't provide further evidence on these two points. I am lucky to have reliable sources in the media in Japan and they put themselves at risk talking freely. I won't put anyone in possible trouble so take it as you will. These people have been days ahead and right on everything so far, so I am pretty confident in what I am getting for information..
May7-11, 11:13 PM   #6134
The live feed went dead while I was watching it. Can anyone see it right now?
May7-11, 11:17 PM   #6135
Quote by robinson View Post
Live feed works ok for me. http://www.youtube.com/watch?v=FptmoVcgpqg.
May7-11, 11:21 PM   #6136
Thanks. That one is working.
May7-11, 11:43 PM   #6137
Interesting. Looking forward to those new images.
Is the building leaning towards the sea-side? Because the pillars on the south side look pretty much intact below the service floor. I don't think the inner structure such as the reactor and sfp are resting on the outside pillars (that's at least what I would hope), so that it wouldn't really matter much if the outer hull of the building is leaning, unless it is going to collapse and stuff falls into the sfp. Or is the whole unit supposed to lean from ground up?
New Reply
Tags
japan, nuclear
Thread Tools
Similar Threads for: Japan Earthquake: nuclear plants
Thread Forum Replies
8.9 earthquake in Japan: tsunami warnings Current Events 671
New Nuclear Plants Nuclear Engineering 9
Gen IV Nuclear Plants Nuclear Engineering 10
New Nuclear Plants Nuclear Engineering 14
Astronomer Predicts Major Earthquake for Japan General Discussion 65
