New Reply
Japan Earthquake: nuclear plants
Share Thread Thread Tools
May10-11, 08:56 AM   #6444
Quote by Samy24 View Post
Interresting is that the radiation in the SFP should come from the reactor core of unit 3 and not from the fuel in the pool.
How is it possible that the explosion at unit 3 could "extract" fuel from the core to the pool?
http://www3.nhk.or.jp/daily/english/10_30.html
There was those steam plumes coming from the reactor, maybe? Iodine, Cesium - both can travel by steam, AFAIK.
The levels of radiation detected are almost the same as those detected in April in water samples in the fuel pool of the No.2 reactor.
Wait, they had taken samples from SFP#2??
May10-11, 08:57 AM   #6445
Quote by clancy688 View Post
What the heck? Next they'll say that Osama bin Laden dumped them inside the pool.
Here is an old video of Arnie Gunderson regarding the measurements of radioactive substances in the water of SFP #4 and TEPCOs explanation that airborne fallout is responsible.
He's calculating that for an amount of 2000 Bq/cm³ in the water of a SFP, you'll need 30 billion Bq/m² fallout - which's way beyond Chernobyl numbers.
(But that doesn't mean that there's been criticality in the SFP - NUCENG calculated that those numbers could have come from very limited fuel damage inside the SFP).
this same very limited fuel damage would of released over a thousand times the observed amount of Cs-137 (given the ratio of i-131 to cs-137 in the old fuel), or alternatively, this fuel damage (and chemistry) would have to be over a thousand times more selective in releasing the iodine versus cs-137 than anywhere else. I'm not saying it proves criticality in sfp4, they might have used contaminated seawater for cooling (but if so, why did not TEPCO give it as explanation?). I'm saying that it doesn't cut it to handwave about chemistry when it is over 1000 times more selective than anywhere else (drains, ditches, ocean, fish bodies...) . If there is something this good at scrubbing out cs-137, that's be WONDERFUL news because they could use it to clean their nasty water.
edit: also, note. 1 mol of i-131 has 1360 times the radioactivity (in Bq) of 1 mol of cs-137, this rules out compounds such as CsI as explanation for the ratio.
May10-11, 09:07 AM   #6446
Recognitions:
Gold Membership Gold Member
Quote by zapperzero View Post
Where do you get that figure from?
From the scenario, a 1000 tons of water in pool, superheated to about 110 deg C.
This system is unstable, the excess temperature 10 deg. C it is above the boiling point represents the energy available to suddenly vaporize some part of the water.
Water has a heat capacity of 4.18 MJ/ton/degree Celsius, so with 10 degrees and 1000 tons of water, that gives you 4.18*10*1000= 41.8E3 MJ of energy available for vaporization of water.
It takes 2.257E3 MJ/ton to vaporize water, so with 41.8E3 MJ available, this would suffice to vaporize 41.8/2.257 = 18 tons of the water in the pool.
May10-11, 09:12 AM   #6447
Quote by yakiniku View Post
I don't recall seeing mention of the data published on April 23rd by the Center for the Promotion of Disarmament Non-Proliferation Japan. It contains data for a number of radioactive isotopes that might be interesting from the CBTO Takasaki station in Gunma:
http://www.cpdnp.jp/pdf/110427Takasaki_report_Apr23.pdf
http://www.ctbto.org/verification-re...n/page-1-rn38/
I had a closer look at those data now.
The ratio of I-134 to I-137 is almost constant (almost always between 0.85 and 0.90), so there do not seem to be too many typos in those numbers.
The table contains some short-lived isotopes like Te-129 with its 70 minute half-life. But it is present because of Te-129m, which has a 34 days halflife. Generally, the tables show Te-129 activity at about half that of Te-129m. Except for March 15, when it is only 10 %. This could be a typo?
There is also I-132 with its 2.28 hour lifetime. It is the daughter of Te-132 (3.27 day halflife). Generally, the I-132 activity is about half that of Te-132. The largest deviation from that is March 16, when I-132 is listed with a higher activity than Te-132.
The ratio of I-131 to Cs-132 is rather variable. Probably this depends on rain etcetera. But the data point for I-131 on March 22 does not seem reliable.
So what is wrong with the Japanese? Why don't they make plots like the German test ban monitoring people do? Why not provide some interpretation?
May10-11, 09:28 AM   #6448
Quote by AntonL View Post
"That just doesn't happen" under normal circumstance when the pool is cooled,
and H2 and O in solution quickly recombine, but
Attached is the extract regarding radiolysis of a 133 page document Light Water Reactor Hydrogen Manual by Allen L Camp
Wouldn't it also happen in BWR cores then? Boiling water, high radiation would generate lot of hydrogen, which would not recombine (boiling + steam environment). This means cores would generate a lot of hydrogen, a lot more than observed, don't you think?
BTW same for Zirconium oxydation by steam in boiling environment.
May10-11, 09:49 AM   #6449
Quote by Borek View Post
...I never liked the idea of superheating, as there is plenty of objects in the water that should easily help to start local boiling (see http://en.wikipedia.org/wiki/Boiling_chips - that's all about rough surface) and remove excess heat. ...
(all this in reference to SPF4)
Isn't another problem with the superheating scenario the fact that the site was experiencing almost constant aftershocks of varying degrees throughout this time period which would have created disturbances in the water which, along with the many nucleation sites mentioned by Borek, would inhibit/prevent superheating?
May10-11, 10:04 AM   #6450
https://netfiles.uiuc.edu/mragheb/ww...Structures.pdf
"Steam being quenched from the primary vessel into the torus under high pressure would act as a rocket and could cause vessel displacement"
Has the idea that the full top of the unit 3 RPV was blown off already been debunked ?
It would be consistent with the 1 atm pressure reading
source : http://www.abovetopsecret.com/forum/...g2#pid11221435
May10-11, 10:26 AM   #6451
Quote by GJBRKS View Post
There are still living personnel on site, after a month. Such damage would make that site like Chernobyl -> some seconds at work, and then run for safety...
May10-11, 10:27 AM   #6452
Quote by rowmag View Post
Also heard on radio that they are going to try feeding water through a different line at Unit 3 later today, due to the rising temperatures there, since merely increasing the flow rate through the current one is not working, suggesting that the water is not getting where it needs to go for some reason.
It has been suggested salt buildup (from the seawater injection period) at the bottom of the RPV could be insulating corium that deposited there from the partial melting.
May10-11, 10:35 AM   #6453
This non sense has been ruled out in march.
May10-11, 10:37 AM   #6454
Quote by StrangeBeauty View Post
Isn't another problem with the superheating scenario the fact that the site was experiencing almost constant aftershocks of varying degrees throughout this time period which would have created disturbances in the water...?
It occurred to me that *IF* the situation depicted below occurred in an SFP, and *IF* it led to the occurrence of some chain fission, then the water level would be unstable and could start to oscillate. Namely
water level inside assemblies rises --> moderation of neutrons increases --> chain fission increases --> fuel heats up --> steam pressure inside the assemblies rises --> water inside assemblies get pushed down
I presume that if water is boiling inside the assemblies the pressure there would be higher than atmospheric, since the top support plates and the assembly head impede the flow somewhat. Since it would take some time for the extra heat of fission to travel from the fuel to the cladding, the pressure within the assemblies would oscillate in sync with the water level but with some delay --- i.e., the push would be stronger on the way down --- tending to amplify the oscillation rather than to oppose it.
EDIT In fac,t the water level may start oscillating even if there is no chain reaction at first, just from the delay of heating and boiling the water. However, as the top of the wave gets some distance above the surviving boral, then the chain reaction should restart, no?
May10-11, 10:54 AM   #6455
Aren't cesium and iodine volatile components that would travel with the vented steam? It seems to me (lay opinion) that this is entirely consistent with steam venting from the reactor vessel into the primary containment (damaged lines or vessel?) and then into the SFP3 (ie, through the fuel transfer chute).
As for the superheated water being very unstable, heck yes -- but the hypothesis was that the "critical" moment of superheating was immediately followed by the steam explosion, and that the explosion and venting of the contents within the primary containment was, in fact, the "last straw" impetus for the steam explosion that caused that criticality.
Is it also possible that criticality occurred, the water/steam was ejected from the SFP, and the contamination with cesium and iodine occurred either as a consequence of the criticality in the SFP or after the pool was refilled? Maybe. A lot of steam was still leaking at the apparent location of the transfer chute after the explosion.
Irrespective of the exact cause initiating the steam explosion, an open connection from the primary containment of Unit 3 to the contents of SFP3 seems to be supported by the water analysis, right?
May10-11, 11:08 AM   #6456
Quote by Dmytry View Post
They did:
It said the radioactive materials detected in the latest check could have come from seawater sprayed into the pool to cool the reactor.
http://www.asahi.com/english/TKY201104300099.html
Now the really interesting question is are they going to admit this might also have happened in SFP 2 and SFP 3 but in a larger scale. It's a possibility if the hoses for SFP 4 and SFP 2&3 sprayings were located on different places. But not the only theory.
But if they admit it they must also admit that their calculations concerning the leak into the sea might be heavily underestimated. Which might be the problem?
May10-11, 11:11 AM   #6457
http://www.youtube.com/user/Anjiin#p/u/15/1Dcg2_YGtZ0
Sorry to go even further off topic, but... I see stuff in that third video that would never fly on a regular construction site.
From various reports that I have read, it seems that many nuclear plant workers are temporary people "from all walks of life, bartenders etc.", often unemployed or in financial straits; with no special training or previous construction work experience, hired for a very short time and trained to do a very specific task only. Thus it is not surprising if they are clumsy, inefficient and unsafe when faced with an unforeseen event --- such as a stuck crane hook.
May10-11, 11:38 AM   #6458
The analysis this guy is giving is wrong based on the picture on which he is drawing the supposed reactor, simply because he places it at the wrong place! The reactor is normally centered in the middle of the North/South axis (it's normally offset towards the East on the East/West axis) , but the part of the picture where he is drawing the circle is completly offset to the North side.
See there is no metallic structure over the place where he is drawing the circle, while this remaining structure from the roof is present in the middle of the building after the explosion.
I'm not saying anything about the actual condition of the reactor (but at least it seems that some sensors for temps are still working!) but for sure the stuff the guy is showing is NOT the remains of the reacto because it's clearly at the wrong place!
May10-11, 11:50 AM   #6459
Quote by jlduh View Post
Things are at the wrong place in a lot of places ...
Thought so allready , good to have that cleared up
May10-11, 12:03 PM   #6460
One thing that hasn't been mentioned:
D/W radiation sensors are at the top of the containment, near the cap. They wouldn't give any data, not even bogus data, if that part of the reactor would be gone.
New Reply
Tags
japan, nuclear
Thread Tools
Similar Threads for: Japan Earthquake: nuclear plants
Thread Forum Replies
8.9 earthquake in Japan: tsunami warnings Current Events 671
New Nuclear Plants Nuclear Engineering 9
Gen IV Nuclear Plants Nuclear Engineering 10
New Nuclear Plants Nuclear Engineering 14
Astronomer Predicts Major Earthquake for Japan General Discussion 65
