New Reply
Japan Earthquake: nuclear plants
Share Thread Thread Tools
May13-11, 05:48 AM   #7039
I must say I assumed some channelling of unit 3 explosion, or barrel if you like, due to the large piece that is propelled perfectly vertically, and falls almost where it rose from,... though probably slightly (though imperseptibly) to the right (or Southeast) due to the wind, the cloud however moves with the wind, due to it's low density.
That large piece must have been directly ballanced on the balloons centre if we're simply talking bouyancy! and what is it? the floor above the SFP?
May13-11, 05:54 AM   #7040
Quote by zapperzero View Post
If I squint just right, I think I also see some orange light, just before the shock front goes up, obscuring everything. Hey, that's no steam explosion!
When you say orange light, do you mean the fireball to the south of the building thats clearly visible?
May13-11, 05:56 AM   #7041
Quote by SteveElbows View Post
I circled it in the attachment. It's to the south I think, yes.
May13-11, 06:00 AM   #7042
Quote by Borek View Post
I just did some back of the envelope calculations. To cool down water by 1 deg C one have to change 0.186% of that water into gas.
This is just to give some number to make further discussion easier.
or to cool the volume of the SFP by 1oC would release .596 GJ
May13-11, 06:03 AM   #7043
Quote by MadderDoc View Post
However true that is there is still no free lunch as regards the heat of transition.
It must be served, or you will not have any vapour no matter how much you tune down the pressure.
Understood. I was attempting to say that the total amount of heat required for phase change is a constant, but that it would not be correct to think that all of it must be applied instantly, or that very high temperatures are necessary to supply the heat of transition. Heat energy continues to be stored in water undergoing heating at 100ºC even though the temperature does not appear to change. There can be a huge difference in the total energy stored in two pools of water, each at 100ºC and each under the same pressure, unless I misunderstand the concept of the heat of transition and phase change.
Edit: Reference added - http://hyperphysics.phy-astr.gsu.edu...rmo/phase.html
I am not sure what you are saying there. The problem I see is one of size of cloud and one of lifting capability. Water in tiny droplets do not take up much space, and do not contribute to lift.
True, but tiny droplets of water require less total thermal energy (although not per unit volume) than a massive pool of water requires in order to undergo the phase change. Is it not possible that atomized water droplets intermixed with burning hydrogen + oxygen might be efficiently heated and turned into additional steam during the hydrogen explosion itself?
OK, so you don't know that flashing of tons of water to steam was involved. However you do know, I believe, that 'something' propelled a diversity of heavy objects 100s of meters into the air. If a huge amount of water vapour rising didn't do it, what did?
In part, perhaps the hydrogen explosion itself, of course, but I strongly suspect a steam explosion based on what I see, even if I don't "know". I suppose that it is sort of like the old joke about the prostitute (do you know it?) . . . I presume that we have already established, by its characteristics that a large component of the explosion of Unit 3 was a steam explosion. So now, we are just haggling over the "price" (and source) of thermal energy required to fuel it. Anton gave some reasonable calculations, I believe.
Edit: Reference added - http://en.wikipedia.org/wiki/Water_vapor#Lifting_gas
Lifting gas
Due to its low molecular weight, water vapor is a lifting gas under STP conditions; however, it is limited by the low amount of water vapor which can exist in the air at a given point in time. High enough temperatures to maintain a theoretical "steam balloon" yield approximately 60% the lift of helium and twice that of hot air.[9]
Potential sources of thermal energy I can see are these:
1) thermal energy stored in the water of SFP3 transferred from decay heat of spent fuel rods in the pool,
2) thermal energy transferred from burning hydrogen in the building above SFP3,
3) thermal energy from the RPV transferred by explosive venting of steam and hot (radioactive) gasses from the drywell or upper "wet well" or both,
4) thermonuclear energy from sudden criticality occurring in the unspent fuel in SFP.
And say, don't I remember a passive emergency cooling system that operates without electric power driven by a steam turbine that circulates through a cooling pool? Was such a mechanism in operation at Unit 3? Would that have been in any way related to heating SFP3 (ie, was initial emergency cooling of the Unit 3 core at the expense of additional heating of SFP3 or is another water reservoir used for this emergency system, if it was used)?
Are there any other substantial sources of thermal energy that I have not considered?
I remember some earlier, detailed discussion about the calculation of energy released with the explosion of Unit 3 and, I believe that the final conclusion was that it could not even be estimated to within an order of magnitude with any reasonable accuracy. (sigh)
Edit by Borek: TCups, I corrected quote tags so that it is obvious what is a quote and what was your answer. If something is wrong, please contact me by PM and I will correct it again.
May13-11, 06:05 AM   #7044
this is one of the best shots without TV channel stuff covering bit up! could do with some contrasting though
http://www.youtube.com/watch?v=RxAHo...eature=related
May13-11, 06:07 AM   #7045
Concerning SFP's and plugs, did we already have a clear statement about this subject: are the SFPs normally plugged with concrete removable roofs (some kind of anti-missile protection i think?)?
At n°1 i don't see the SFP (maybe under the crane?), so is it plugged with these?
What about N°2 (which we don't see)?
N°3 we know that there is none currently, but what about before the explosion?
For N°4, even if it had some in normal use, it was getting fuel reloading so probably no plug anyway, which is consistent with what we see now.
Again, this subject is fuzzy to me. We can imagine that at N°3 for example, if there was some plug the explosion could be explained much differently.
I was really thinking that SFPs should have plugs for safety (missiles) reasons (which is a problem if cooling is stopped as gases are captured by the way!)
Could this explain the big hole above N°3 SFP, and maybe some big chunks of concrete thrown in the air?
May13-11, 06:10 AM   #7046
The question of putting water in the pools at night has come up several times before. But the official updates give times for pumping & spraying at various pools, and these times indicate that it is extremely rare for any of this stuff to be done during hours of darkness.
Well, some nights the plant's all lit up and steam's coming out. Other nights it's pitch black.
May13-11, 06:12 AM   #7047
No, there is no protection on SFP, they are open.
May13-11, 06:17 AM   #7048
Quote by TCups View Post
REGARDING THE HIGH SPIKE OF MEASURED RADIATION ASSOCIATED WITH UNIT 3'S EXPLOSION
Could there be another plausible explanation? For example:
Could the spike in measured radiation levels be explained by the explosive release of volatile iodine and cesium (or other highly radioactive isotopes) from the explosion and venting of the contents of the drywell of Unit 3, lofted by the associated steam flash? I believe there were smaller spikes in measured radiation during controlled venting. It would seem to make sense that explosive venting would be a much larger spike.
Could some of the contents of SFP3 also have been damaged by an explosion and steam flash and also lofted and scattered, perhaps also contributing to the spike?
The newspaper article says about this bunker:
"The three-story, white bunker had extra-thick walls and two filtration systems designed to keep out radiation."
http://www.bloomberg.com/news/2011-0...fuel-rods.html
An earthquake-proof radiation shelter. Yet the radiation spike was measurable inside.
To me this is rather strong support for Gundersen's theory.
May13-11, 06:19 AM   #7049
Right, exactly. A cumulus cloud needs no barrel, it has direction 'up' due to gravity and it has considerable lifting properties. So why invoke a need for a barrel in the case of the unit 3 cloud?
There was some really big pieces in that cloud, which cannot be explained by just lifting by heat.
Ps.: regarding that radiation spike in the safe bunker: is there even a direct view from the bunker to U3 service floor? To the depths of SFP?
May13-11, 06:34 AM   #7050
Quote by jlduh View Post
The SFP plugs as quoted in the service floor paper are the removable wall making a "channel" from the core to the SPF.
May13-11, 06:35 AM   #7051
Recognitions:
Gold Membership Gold Member
Quote by AntonL View Post
Look at this video of US soldiers blowing up a jungle cocaine factory,
Pillar and mushroom development after a small scale military explosion
http://topdocumentaryfilms.com/cocaine-submarines/
Yes, pillar and mushroom development is not per se a signature of steam explosions. A good sized fireball (or steamball) and it is set to go.
concerning lifting capacity, all held up by air being a couple of degrees warmer
A hot air balloon is usually operated at between 100 and 120oC and will then produce a lift of about 3 N/m3. The lift of hot water vapour is about double of that, more than 6 N/m3. This is mainly because water has a much lower molar mass than atmospheric air. For comparison one of the best buoyancy gases we have, helium, has a lift of about 10 N/m3. IOW water vapour has over 60 % of the lifting capability of helium.
May13-11, 06:38 AM   #7052
Apparently they don't use the concrete shield plugs for the SFPs although those seems to exist (see posts a few pages back). (Still waiting for comments on this issue from those with first hand nuclear plant experience... just a reminder, not being impatient )
But what you write could have applied to the dryer-separator pool. Its shield plugs are much heavier than the SFP ones, and they might have put them in place just to have more floor space available. Maybe that could be related to the heavy floor damage in the NW corner of unit 3. Otoh, although we know there is steam venting from the side of the concrete blocks separating the DS pool from the reactor well, those blocks themselves seem undamaged.
EDIT: See post http://www.physicsforums.com/showpos...postcount=7054 which came up while writing this. That would make sense, as they are supposedly rather light. But do you know for sure, any documents where that's stated (might be in the whole document, I just looked at the two extracted pages so far)?
May13-11, 06:45 AM   #7053
But you don't want to imply that those large concrete chunks thrown upwards in the explosion are floating on some kind of hot gas?
May13-11, 06:48 AM   #7054
Quote by pdObq View Post
concrete chunks - I would say roof sheets judging by there size
New Reply
Tags
japan, nuclear
Thread Tools
Similar Threads for: Japan Earthquake: nuclear plants
Thread Forum Replies
8.9 earthquake in Japan: tsunami warnings Current Events 671
New Nuclear Plants Nuclear Engineering 9
Gen IV Nuclear Plants Nuclear Engineering 10
New Nuclear Plants Nuclear Engineering 14
Astronomer Predicts Major Earthquake for Japan General Discussion 65
