New Reply
Japan Earthquake: nuclear plants
Share Thread Thread Tools
May15-11, 09:00 AM   #7277
Recognitions:
Gold Membership Gold Member
Quote by elektrownik View Post
reactor 3 water level going down (-1950 -2300), temperature up, and they injecting 15,5m3/h now...
The experience to date and the reactor 3 temperature data suggests a lump of partly melted core material, mixed with salt, encrusted near the bottom of the RPV. Presumably the worst case event would be a melt through with the core lump deposited into a flooded drywell, generating a large steam explosion.
Is this a realistic scenario and is there enough data that the scale of the steam generation can be modeled?
May15-11, 09:23 AM   #7278
[QUOTE=clancy688;3303106]Despite raised water inflow the temperature is rising, the water level is decreasing and now they are injecting boron.
[QUOTE]
May this be an indication the holes in the bottom of the RPV are getting larger and the leak rate has now exceeded the refill rate? If so, eventually the RPV will drain completely no matter how much water is injected.
Any opinions on what happens then?
May15-11, 09:29 AM   #7279
Quote by etudiant View Post
But the "lump" is already sitting in a pool of water with no steam explosion. If it has been dripping through the holes in the RPV until now, and even if it drops in a lump, it still is going from one water medium to another. Would a steam explosion require a dry lump of corium super heated to several thousand degrees prior to being introduced into a water pool?
May15-11, 09:37 AM   #7280
REGARDING THE VISIBILITY OF THE FIREBALL AND IGNITION OUTSIDE OF BLDG 3 CONTAINMENT
Quote by MadderDoc View Post
I think no one can claim to have actually seen the ignition. It would seem to me to be an extraordinary claim that the ignition point was outside the building. I would like to hear about the supposed mechanism for such occurrence before even considering it.
IMO, I believe I could see ignition occurring outside of Bldg 3. See the prior images I posted some time back. The nature of video compression and image compression is complicated. It is interesting to me that I am not able to reproduce this resolution on one of the later generations or perhaps different copy of the explosion of Unit 3, but my initial review of the video, IMO, was pretty clearly a white puff then a very brief expanding and contracting fireball quite distinct and separate from the other components of the explosion. A discussion of this and other observations about the video and a link to the original video, preceded the quotation with images below, I believe.
Quote by TCups View Post
REGARDING COMPRESSION ARTIFACT AND RESOLUTION
Just for grins, here are the actual pixels I am able to resolve, not from the video, but from the links to the frame grabs I posted. ROI is the initial white puff and red fire ball.
http://i306.photobucket.com/albums/n...Picture2-1.png
http://i306.photobucket.com/albums/n...Picture3-1.png
http://i306.photobucket.com/albums/n...Picture4-1.png
Not great, but more than 8 pixels for sure. Plus the tower just to the left will give an idea of edge artifact and contrast resolution.
"Seeing" is different from confirming and explaining the mechanism, I suppose. But my simple explanation would be that the oxygen available for the initial explosion in the primary containment (if that is what had occurred) had been consumed, that very hot steam and hydrogen gas were being jetted, and that contact with air outside of the building with a higher concentration of oxygen outside of the building allowed ignition (re-ignition?) of the ejected gas. Someone earlier posted a video of a similar effect observed in a fireball exiting a mine explosion, I believe.
May15-11, 09:38 AM   #7281
Recognitions:
Quote by mrcurious View Post
The thought is that the transition from the RPV to the drywell breaks up the lump and exposes the molten material currently inside a crust. So the question is how much impact from the heat in 50-100 tons of molten reactor fuel, not assuming any incremental contributions from implausible recriticalities.
May15-11, 09:55 AM   #7282
Meltdown occurred at Fukushima No. 1 reactor 16 hrs after March 11 quake
TOKYO, May 15, Kyodo
A nuclear fuel meltdown at the No. 1 reactor of the crisis-hit Fukushima Daiichi power plant is believed to have occurred around 16 hours after the March 11 quake and tsunami crippled the complex in northeastern Japan, Tokyo Electric Power Co. said Sunday.
http://english.kyodonews.jp/news/2011/05/91207.html
May15-11, 10:11 AM   #7283
That's odd.
3/11 - 14:46: Tohoku earthquake
3/11 - 15:41: Tsunami impact
3/11 - 16:36: Battery failure in Unit 1
3/11 - 17:07: Isolation Condenser active in Unit 1
3/12 - 05:30: Unit 1 primary containment pressure 820 kPa
3/12 - 06:46: +16 hours
3/12 - 10:17: Venting of Unit 1
3/12 - 11:20: Fuel rods 90 cm exposed in Unit 1
3/12 - 15:36: Explosion of Unit 1
The meltdown occured before venting and before the fuel rods got exposed?
May15-11, 10:12 AM   #7284
"A nuclear fuel meltdown at the No. 1 reactor of the crisis-hit Fukushima Daiichi power plant is believed to have occurred around 16 hours after the March 11 quake and tsunami crippled the complex in northeastern Japan, Tokyo Electric Power Co. said Sunday."
That was when all the industry experts told us in TV that such a thing was impossible.
May15-11, 10:22 AM   #7285
Quote by PietKuip View Post
Then you should've watched german tv... quite the opposite.
May15-11, 10:22 AM   #7286
Understood. But the exposed molten material is dripping into the containment filled with water in small portions, not in one 50-100 ton mass. Will that make a difference?
If the majority of the large mass is still in the RPV, is there a possibility it could burn through the bottom in one quick event and if so what temp might that mass be when it drops into the water pool in the containment?
I guess I'm trying to determine the possibility of a large steam explosion sending the corium into the atmosphere. Next up might be determining if and when the corium mass burns through the concrete in the PCV and onto the floor of the reactor building, then from there into the basement with the 4.2 meters of standing water.
May15-11, 10:41 AM   #7287
Quote by clancy688 View Post
That's odd.
Someone on this thread found some reactor data from early on, and it shows far more detail about when the fuel rods were exposed. The last reading where the level was above the top of the fuel was at 07:30, showing +600mm and +200mm. There was then a gap in the readings, and the next available ones at 08:30 showed reading A at 0mm and reading B at -400mm. By 08:49 it was measured at -300mm and -550mm. So the 11:20am levels were not the beginning of fuel exposure.
May15-11, 10:49 AM   #7288
Quote by SteveElbows View Post
Of course not. But even with the readings cited by you, meltdown would have occured before the fuel rods got uncovered.
May15-11, 10:51 AM   #7289
That's odd.
obviously, they are using a different data set:
http://www.tepco.co.jp/en/press/corp.../110515e10.pdf
water level at bottom of fuel at 19:30 on 3/11
i am not sure, where the other data set, that stolfi et al are using originates from.
'On the other hand, as the temperature of the RPV of Unit 1 is in the range of 100°C - 120°C, stable cooling is being achieved'
looking at the #3 data, this is a little scary....
May15-11, 11:02 AM   #7290
Quote by bytepirate View Post
It may well be the same data, but recalibrated.
The data I was going on about which showed fuel uncovered by 08:30 on the 12th, did have very big gaps in it the previous evening. And now that they have recalibrated the A readings, the subsequent data which showed levels above the top of the fuel was likely totally wrong, and they have adjusted accordingly.
Thanks for finding the official document about this stuff, its very interesting, and we should just forget all about the '16 hours' that Kyodo story mentions.
May15-11, 11:06 AM   #7291
Oops, I worded that badly. What I meant is that 16 hours is not when fuel began to be uncovered, the document shows that this is when they think the fuel fell to the rpv bottom.
May15-11, 11:08 AM   #7292
Thank you very much! That data sheet is VERY interesting. I think the data Stolfi and others used came from NISA or TEPCO.
For me it's rather scary what happens with a BWR/3 when emergency power supply fails - it's immediately doomed.
Fast decrease in water height started only minutes after power failure. Only two hours later the top of the fuel was uncovered. And three and a half hours later the fuel was completely uncovered. Which means that the passive cooling equipment (Isolation Condenser) was totally useless. There are not many BWR/3 or older in use... I asked wikipedia, one is in spain, the rest in the USA: Dresden NPP (2x), Monticello NPP (1x), Nine Mile Point NPP (1x, BWR/2), Oyster Creek (1x, BWR/2), Pilgrim NPP (1x), Quad Cities NPP (2x) and Santa Maria de Garona NPP in Spain (1x). I think the operators of those plants should make sure now that there's always emergency power available... without relying on passive cooling systems.
Now I'm interested in such a report regarding Unit 2 and 3... showing if the BWR/4 design with RCIC was considerably better in providing emergency cooling.
One question for the physicists: core temperature began rising very fast, but once it reached 2900 degrees it suddenly stopped rising. Why? I'd expect a temperature graph resembling a function of ln(x), not such a sudden stop.
And another question (for everybody): What's the data TEPCO used for that sheet, and where did it come from? It doesn't seem to be an estimate, since there are bumps in those graphs, indicating they are build on accurate data.
But the document states exactly that 16 hours after the earthquake, the core had totally molten down. Look at the four images at page 3.
May15-11, 11:13 AM   #7293
It might help to recall the details with this excerpt from the accumulated information on the related wikipedia page:
On 11 March at 14:46 JST, unit 1 scrammed successfully in response to the earthquake though evacuated workers reported violent shaking and burst pipes within the reactor building. All generated electrical power was lost following the tsunami leaving only emergency batteries, able to run some of the monitoring and control systems. At 15:42, TEPCO declared a "Nuclear Emergency Situation" for units 1 and 2 because "reactor water coolant injection could not be confirmed for the emergency core cooling systems." [...]
After the loss of site power, unit 1 initially continued cooling using the isolation condenser system; by midnight water levels in the reactor were falling and TEPCO gave warnings of the possibility of radioactive releases. In the early hours of 12 March, TEPCO reported that radiation levels were rising in the turbine building for unit 1 and that it was considering venting some of the mounting pressure into the atmosphere, which could result in the release of some radioactivity. Chief Cabinet Secretary Yukio Edano stated later in the morning the amount of potential radiation would be small and that the prevailing winds were blowing out to sea. At 02:00 JST, the pressure inside the reactor containment was reported to be 600 kPa (6 bar or 87 psi), 200 kPa higher than under normal conditions. At 05:30 JST, the pressure inside reactor 1 was reported to be 2.1 times the "design capacity", 820 kPa.Isolation cooling ceased to operate between midnight and 11:00 JST 12 March, at which point TEPCO started relieving pressure and injecting water. One employee working inside unit 1 at this time received a radiation dose of 106 mSv and was later sent to a hospital to have his condition assessed.
Rising heat within the containment area led to increasing pressure. Electricity was needed for both the cooling water pumps and ventilation fans used to drive gases through heat exchangers within the containment. Releasing gases from the reactor is necessary if pressure becomes too high and has the benefit of cooling the reactor as water boils off but this also means cooling water is being lost and must be replaced. If there was no damage to the fuel elements, water inside the reactor should be only slightly radioactive.
In a press release at 07:00 JST 12 March, TEPCO stated, "Measurement of radioactive material (iodine, etc.) by monitoring car indicates increasing value compared to normal level. One of the monitoring posts is also indicating higher than normal level." Dose rates recorded on the main gate rose from 69 nGy/h (for gamma radiation, equivalent to 69 nSv/h) at 04:00 JST, 12 March, to 866 nGy/h 40 minutes later, before hitting a peak of 0.3855 mSv/h at 10:30 JST.
At 13:30 JST, workers detected radioactive caesium-137 and iodine-131 near reactor 1, which indicated some of the core's fuel had been damaged. Cooling water levels had fallen so much that parts of the nuclear fuel rods were exposed and partial melting might have occurred. Radiation levels at the site boundary exceeded the regulatory limits. [...]
At 15:36 JST on 12 March, there was an explosion in the reactor building at unit 1.
The press release came out at what is now considered the approximate time of the meltdown - during the period of increased gamma radiation.
New Reply
Tags
japan, nuclear
Thread Tools
Similar Threads for: Japan Earthquake: nuclear plants
Thread Forum Replies
8.9 earthquake in Japan: tsunami warnings Current Events 671
New Nuclear Plants Nuclear Engineering 9
Gen IV Nuclear Plants Nuclear Engineering 10
New Nuclear Plants Nuclear Engineering 14
Astronomer Predicts Major Earthquake for Japan General Discussion 65
