| New Reply |
Japan Earthquake: nuclear plants |
Share Thread | Thread Tools |
| Jul11-11, 10:22 PM | #10609 |
| Jul12-11, 03:06 AM | #10610 |
http://www.asahi.com/national/jiji/JJT201107120052.html At 8:40 AM on 12 July, a leak was observed on a surveillance camera, and the water treatment facility was manually stopped 10 minutes later. The leak location is in the Areva system, in the close proximity of the leak that occurred and was repaired on 10 July. The desalination facility is still running. Repairs are shown on http://www.tepco.co.jp/nu/fukushima-...10712_02-j.pdf (top picture is before repair, bottom picture is after repair).
http://www.nikkei.com/news/headline/...E3E2E2E2E2E2E2 The leaked volume was 10 l. The leak location was exactly the same as two days ago. The facility was started again at 4:58 PM after changing the fitting for a stainless steel one. It is thought that the zinc-coated cast iron one installed two days ago was corroded by the ferric sulfate flowing in the hose. http://www.asahi.com/national/update...107110485.html For the purpose of breakwater reinforcement work repairing the tsunami damages at the south of the water inlet, the silt fence will be opened 36 times for two hours each time in the upcoming 3 months to let the steel sheet pile driving boat to come and go. This rises the fear that some of the 1.2 terabecquerels in the water inlet could flow into the sea. The silt fence opening time being limited, Tepco says the consequence on the periphery is limited. Radiation measurements in the sea will be intensified. Local governments have been notified. http://news.tbs.co.jp/newseye/tbs_newseye4773907.html the nitrogen hose will be connected on unit 3 on 12 July afternoon. The nitrogen injection will start at unit 3 this week (nitrogen injection is already being performed at units 1 & 2). http://www.yomiuri.co.jp/science/new...OYT1T00502.htm Minister Goshi Hosono said the details on a new middle to long term study team whose purpose is to study the decommissioning of Fukushima Daiichi will be announced on 19 July. They will have to find a solution so that the final disposal is located elsewhere than in Fukushima prefecture. http://www.ustream.tv/recorded/15943265 NISA press conference, 12 July : The original heat exchanger at unit 1 SFP can be reused. Tepco hopes the SFP cooling system can be started at the end of July or within the first decade of August. http://www.tepco.co.jp/nu/fukushima-...10712_01-j.pdf page 2 : water injection into unit 4 reactor well and dryer storage pool started at 11:22 AM on 12 July. It had to stop at 12:03 because of a leak in the connection of the injection line. |
| Jul12-11, 03:33 AM | #10611 |
| Jul12-11, 04:16 AM | #10612 |
http://pbadupws.nrc.gov/docs/ML1109/ML11098A049.pdf You are correct about type T range. Thanks for the correction. |
| Jul12-11, 09:05 PM | #10613 |
The actual current heat output should be considerably less than those figures. From your source: #9044 Jorge Stolfi |
| Jul12-11, 10:45 PM | #10614 |
Thanks for pointing that out. I had forgotten about that...
So assuming the cores completely melted in all three units, the current heat output of the cores should be more like 1.2 MW in unit 1 and 2.1 MW in units 2 and 3. The balance of 2.5 MW in unit 1 and 4.2 MW in units 2 and 3 should mostly be in the leaked water, on RPV and containment walls and around pipes, wherever evaporated volatile isotopes could condensate or get leached out. Does anybody remember how many curies of Cs-134 and Cs-137 were leaked into the atmosphere according to NISA estimates? |
| Jul12-11, 10:47 PM | #10615 |
There is a lot that is unknown about thermal properties during a core melt event. http://www.tec-sim.de/images/stories...-phenomena.pdf On page 16 of that document: |
| Jul13-11, 12:41 AM | #10616 |
But with the good comes the bad - more from Jorge: In effect, we are now at the same point a plant which had a normal shutdown would have been - several decades later. |
| Jul13-11, 01:55 AM | #10617 |
| Jul13-11, 02:09 AM | #10618 |
I'll have to do some more research and see if I can identify the magnetic material used. Omega sells several type of magnetic thermocouples. The only note I could find stated "Magnet Will Retain 90% of Its Pull at 370°C (700°F)" |
| Jul13-11, 04:39 AM | #10619 |
http://www.nikkei.com/news/category/...0E2E2E2;at=ALL Tepco will install a new mainly-Toshiba-made backup system using zeolite for the water treatment facility, setting August as the target date. In addition to the present reverse osmosis desalination system, evaporation-enrichment systems will be installed in August and in October. Unit 4's SFP cooling system will be started in the last decade of July. Unit 1's SFP cooling system in the first decade of August.
http://www.meti.go.jp/press/2011/07/...10711008-1.pdf This is a formal NISA request requiring Tepco to write a report about its plans concerning the safety of the SFP cooling systems for unit 1 and unit 4, reminding Tepco the deadline of July 17th as part of the "step one" of the "roadmap". http://www.tepco.co.jp/cc/press/11071309-j.html (not yet translated into English) Tepco's report on the SFP cooling systems for unit 1 and unit 4, as a reply to the above NISA request. http://www.tepco.co.jp/en/press/corp...1071109-e.html Tepco's report on the safety of the nitrogen injection at unit 3. http://www.tepco.co.jp/en/press/corp...1071212-e.html this press release is simply called "Water leakage in the reactor building (non-controlled area)". It turns out it is not in Fukushima Daiichi but in Kashiwazaki-Kariwa unit 5. http://www.tepco.co.jp/cc/press/11071302-j.html (not yet translated into English) This is the second installment of the "Study regarding current seismic safety and reinforcement of reactor buildings at Fukushima Daiichi Nuclear Power Station" and it is about unit 3. The first installment, published on 28 May, was about unit 1 and unit 4 : http://www.tepco.co.jp/en/press/corp...1052801-e.html Do you remember the figure page 78 of http://www.tepco.co.jp/en/nu/fukushi...10525_01-e.pdf (a slideshow on the "Effects of the Earthquake and Tsunami on the Fukushima Daiichi and Daini Nuclear Power Stations" published in May) showing "Installation of a Backup RHRS pump" to provide sea water cooling for unit 5 or unit 6 ? Whenever I was looking at that picture, I had the painful feeling that the hose would break on the sharp edge of the water intake bank. The artist who drew the picture was not wrong. This is really what happened on 3 July and you probably still have the "hose turned into a fountain" picture released on that day : http://www.tepco.co.jp/en/news/11031...s/110703_1.jpg in your mind. Here is a follow-up : http://www.tepco.co.jp/nu/fukushima-...10713_01-j.pdf (page 1) Flushing was started at 11:00 AM on 13 July. While flushing was being performed, a leak was found near the coupling part of a chemical injection line at the coagulation-sedimentation facility at 01:07 PM. But it is a different location from the leak that occurred on July 10th and July 12th. Flushing has been stopped and the leak is being investigated. http://www.nikkei.com/news/headline/...E39F9FEAE2E2E2 the leaked volume is 5 l. Another PVC fitting is being changed for a stainless steel one. The target utilization rate of the facility is lowered from 80% to 70% for July. However 90% is set as the target for August. With an 80% rate, it would become impossible to reach the goal of treating all the 200,000 tons within this year. http://www.asahi.com/national/update...107130512.html the utilization rate for the week from 6 July to 12 July was 73%, which is 3 points lower than the 76% achieved a week earlier. http://www.tepco.co.jp/nu/fukushima-...10713_01-j.pdf (page 2) At around 01:00 PM, the portable monitoring post at the main gate was displaying a zero value. After checking there was nothing abnormal there, the power supply at the seismic-isolated building was restarted at 02:55 PM, which restored a normal value. |
| Jul13-11, 05:25 AM | #10620 |
Cs-137: 1.5E16 Bq, ~405.000 Curie Source: http://www.kantei.go.jp/foreign/kan/...ttach_04_2.pdf |
| Jul13-11, 06:15 AM | #10621 |
| Jul13-11, 06:49 AM | #10622 |
| Jul13-11, 12:03 PM | #10623 |
Responding to a message of the Science Council of Japan, and with the purpose of learning the lessons from Japan, the French Académie des Sciences is publishing a report on the seismic and nuclear events in Japan. The first 2 parts on the earthquake and on the nuclear accident were published on 28 June with a number of attachments at http://www.academie-sciences.fr/acti...t/rads0611.htm . A third part on the medical consequences is not ready yet.
It is written in French, but an English translation is provided for the main text. Here is an excerpt : |
| Jul13-11, 01:52 PM | #10624 |
I'm not sure the engineers of 40 years ago had the tools we are using to critique thier reasoning.
| Jul13-11, 02:19 PM | #10625 |
Tsunamis are a well known feature of the Pacific rim, especially Japan. October 1707 an 8.4 earthquake and tsunami 25.7 meters high hit the Kochi Prefecture April 1771 earthquake magnitude 7.4 near Okinawa - tsunami is thought to have killed about 12,000 people, the highest seawater runup on Ishigaki Island, range between 30 meters and 85.4 meters. Nov 1854 The Ansei Quake on the south coast of Japan, was actually 3 quakes, two magnitude 8.4 quakes and a 7.4 quake. The first on near what is today Aichi Prefecture and Shizuoka Prefecture with tsunami. maximum wave of 28 meters at Kochi, Japan, the earthquake and tsunami killed 3,000 people. June 1896 earthquake in northeastern Honshu - tsunami reached a height of 100 feet, 1896 (magnitude 7,2 / wave height 36m) September 1923 The Great Kanto Earthquake - eastern Japan devastated Tokyo, Yokohama and the surrounding areas, caused tsunamis with waves reaching 12 meters. 1933 (magnitude 8,4 / wave height 28m): http://en.wikipedia.org/wiki/1933_Sanriku_earthquake 1964 in Alaska (at the time Fukushima was being designed) Mag 9.2, tsunami 27-foot (8.2 m) The waves produced by the 2004 Indonesian tsunami were (27m) high and killed 230,000 people, that seems a fair warning to the current generation. I agree that we should let bygones be bygones, but let's not make excuses for bad decisions. |
| New Reply |
| Tags |
| japan, nuclear |
| Thread Tools | |
Similar Threads for: Japan Earthquake: nuclear plants
| 8.9 earthquake in Japan: tsunami warnings | Current Events | 671 | ||
| New Nuclear Plants | Nuclear Engineering | 9 | ||
| Gen IV Nuclear Plants | Nuclear Engineering | 10 | ||
| New Nuclear Plants | Nuclear Engineering | 14 | ||
| Astronomer Predicts Major Earthquake for Japan | General Discussion | 65 | ||
