| New Reply |
Japan Earthquake: nuclear plants |
Share Thread | Thread Tools |
| May24-12, 02:18 PM | #13329 |
| May24-12, 03:33 PM | #13330 |
(Btw, this seems a tight fit for the size of the building, it seems not much more than 1 ton of hydrogen can be realistically imagined to have been combusting inside it) Anyways, after the combustion of the 50000 cubic meters of fuel mixture, we end up with that volume minus the volume of oxygen consumed = about 43000 cubic meters of combustion gases. (14400 cubic meters of steam mixed with 28800 cubic meters of nitrogen). That would be a sphere roughly 22 meters in radius. But the mushroom cloud is bigger than that. Air, we can entrain some air! However, not too much, entraining air means our cloud looses buoyancy, without which there can be no Rayleigh-Taylor instability, hence no mushroom cloud. |
| May24-12, 04:15 PM | #13331 |
| May24-12, 05:35 PM | #13332 |
Don't forget the explosion energy will heat & expand the gases significantly (well, pressurize them first, then expand them). Hydrogen burning in air is up to about 2300K ~ 8x volume at atmospheric, less the decrease from oxygen consumption, -> ~7x, by my rough calculation. |
| May24-12, 05:57 PM | #13333 |
| May24-12, 06:33 PM | #13334 |
In a funny way the video of the Unit 3 explosion indicates the possible behaviour of combustion gases from a hydrogen explosion by its kind exposure to our view of the fire phenomenon in the SE corner -- and the ensuing development of a knob of the condensed steam from that combustion, at the downwind side of the stem of the mushroom cloud.
Unfortunately Internet has been thoroughly cleaned of the best videos of the explosion, but if you can get your hands on one still, and it has more than the first dozen of seconds after the blast, this knob of steam from the explosion in the SE corner can be followed, as it travels downwind along with the mushroom. It stays low, and appears to have little tendency to rise, rather it just slowly grows and thins out by entraining air, and gradually disperses, much like the behaviour of the clouds we saw going with the wind from unit 1. ![]() Image above is the last frame from this Unit 3 explosion animation |
| May24-12, 07:27 PM | #13335 |
What is the source of the hydrogen that is believed to have caused the explosions?
| May24-12, 08:57 PM | #13336 |
| May24-12, 11:21 PM | #13337 |
And anyone who knows more about the physics of explosions should jump in and correct me, incidentally, since I'm definitely no expert. |
| May25-12, 05:27 AM | #13338 |
| May25-12, 05:29 AM | #13339 |
| May25-12, 05:40 AM | #13340 |
Also, initially there would have been, oh, however many meters of hydrogen-air mix the building can fit :). |
| May25-12, 06:15 AM | #13341 |
To illustrate, here's an animation of 17 frames, one for each of the first 17 seconds of the explosion. Images are heavily color enhanced to allow better distinction between the different cloud formations. |
| May25-12, 06:57 AM | #13342 |
I see the reactor 3 TIP room investigation was a bit of a failure, due to door etc debris.
http://www.tepco.co.jp/en/nu/fukushi...20524_06-e.pdf Given that a human was able to visually inspect one part of the room, I am less than impressed about a lack of photo of this area. It makes me curious about the nature of any debris inside the room. |
| May25-12, 07:20 AM | #13343 |
The theoretical mass of steam that can be produced by the depressuring can be fairly easily estimated. It is directly proportional to the difference between the initial temperature and the boiling temperature at the new lower pressure, and directly proportional to the amount of water present. The proportionality factor is about 0.002K-1. Mass(steam)=0.002*(Twater-Tsat)*Mass(water) Example: You have a pressurised PCV filled with saturated steam and 4000 m3 of liquid water at 150 deg C. Swiftly release the containment lid and jump back a mile. Don't try this at home. Mass(steam)=0.002*(150-100)*4000 = 400 tons |
| May25-12, 08:03 AM | #13344 |
| May25-12, 08:26 AM | #13345 |
| New Reply |
| Tags |
| japan, nuclear |
| Thread Tools | |
Similar Threads for: Japan Earthquake: nuclear plants
| 8.9 earthquake in Japan: tsunami warnings | Current Events | 671 | ||
| New Nuclear Plants | Nuclear Engineering | 9 | ||
| Gen IV Nuclear Plants | Nuclear Engineering | 10 | ||
| New Nuclear Plants | Nuclear Engineering | 14 | ||
| Astronomer Predicts Major Earthquake for Japan | General Discussion | 65 | ||
