| New Reply |
Kn value of a specific transistor given spec sheet |
Share Thread | Thread Tools |
| Mar11-11, 11:15 PM | #1 |
Hi,
Working on a project, I am told to find the K,n value of a specific transistor (2n7000), given the spec. sheet. I know K,n can be found from the formula: I,d = K,n * (V,gs - V,tn)^2 I'm close, from the spec sheet, I can use a V,gs value and a corresponding I,d value, however not sure what value to use for V,tn to complete the equation and solve for K,n. Any help? Thanks for your time |
| Mar12-11, 10:48 AM | #2 |
That's a thermal voltage that depends on temperature. It's approximately 26 mV at room temperature.
| Mar13-11, 03:54 PM | #3 |
That is V,t which is 26mV like you said but what I am looking for is K,n which is in units if mA/V
I believe |
| Mar13-11, 04:30 PM | #4 |
Look up a spice model for the transistor. It should be there. And the units should be A/V^2
| Mar13-11, 04:42 PM | #5 |
Thanks, tried this - I placed the 2n7000 in the circuit and clicked "Edit Properties" on it but I can't find ANYTHING in the property editor
Any help is appreciated |
| Mar13-11, 05:30 PM | #6 |
Simple google results:
Code:
*ZETEX 2N7000 Spice Mosfet Subcircuit Nodes D G S Last revision 11/91 *ZETEX 60V 200mA pkg:TO-92 .SUBCKT X2N7000 3 4 5 M1 3 2 5 5 MOD1 L=1 W=1 RG 4 2 343 RL 3 5 6E6 D1 5 3 DIODE1 .MODEL MOD1 NMOS VTO=2.474 RS=1.68 RD=0.0 IS=1E-15 KP=0.296 +CGSO=23.5P CGDO=4.5P CBD=53.5P PB=1 LAMBDA=267E-6 .MODEL DIODE1 D IS=1.254E-13 N=1.0207 RS=0.222 .ENDS X2N7000 If you are using LTSpice, go to the LTSpice directory and find folder lib/cmp and look under mosfets. |
| Mar13-11, 05:39 PM | #7 |
Thanks. I have no idea what LTspice is, but doesn't look like it's installed on my school's computers. Part of the assignment is to enter these characteristics (K,n V,t W, L etc ) into one of the regular Mosfet Ntype transistor models so it acts as a 2n7000, rather than using the 2n7000 model itself... Waht, is there any chance you could tell me how I would do that? I dont see how to do it at all.
Thanks EDIT: Seems like I need to use the PSpice model editor, and type in the values of the 2n7000. I'll try and figure the rest out. Thanks a lot |
| New Reply |
| Thread Tools | |
Similar Threads for: Kn value of a specific transistor given spec sheet
| how can i know the current gain of transistor fom its data sheet?? | Electrical Engineering | 3 | ||
| Mass Spec | Biology, Chemistry & Other Homework | 2 | ||
| Solvent and UV/V spec | Chemistry | 4 | ||
| Mass Spec | Introductory Physics Homework | 4 | ||
| engineering spec. molecule | Chemistry | 1 | ||
