Register to reply
Leaking AA batteries
by Carl Pugh
Tags: batteries, leaking
Share this thread:
Carl Pugh
#1
Mar12-11, 12:23 AM
P: 384
I have always preferred Duracell batteries because I believed that they were less likely to leak.
However the Duracell battery in mouse leaked and damaged the mouse, and the Duracell battery in a clock also leaked damaging the clock.
The mouse was used every day and changed as soon as it quit working.
The battery in the clock was changed as soon as the clock started losing time.
What is your experience with batteries leaking?
Phys.Org News Partner Engineering news on Phys.org
Amazon worker piloted drone around Space Needle
Five next-generation technologies for positioning, navigation and timing
Hoverbike drone project for air transport takes off
MATLABdude
#2
Mar12-11, 05:48 AM
Sci Advisor
P: 1,724
In my experience, alkalines will leak after they're run down and past the expiry date (e.g. in the graphing calculator which sits in my desk, getting used once every 4 to 6 months).
After wiping down the mess (the layer usually chips off using a fingernail or knife, and would probably dissolve quite readily in vinegar), the devices should work just fine. CAUTION: the white stuff is probably quite alkaline (basic), make sure you wash your hands thoroughly with soap after finishing. Stop immediately if you feel a burning sensation handling the materials--on second thought, gloves might not be a bad idea.
Register to reply
Related Discussions
Replacing UPS Batteries with Marine/RV Batteries Electrical Engineering 16
What are the main differences between batteries in parallel vs. batteries in series? Introductory Physics Homework 1
Leaking air? Introductory Physics Homework 2
Sealed Batteries vs. Unsealed Batteries General Engineering 0
