Commutator of square angular momentum operator and position operator
The discussion revolves around the commutation relations involving the square angular momentum operator \(\vec{L}^{2}\) and the position operator \(\vec{r}\). Participants are tasked with demonstrating a specific commutation relation and exploring the implications of established results in quantum mechanics.
  • Participants discuss the established result of the commutator \([\vec{L}^{2},\vec{r}]\) and express uncertainty about how to proceed from there. Some suggest using vector component notation or matrix notation to simplify the problem. Others question how to relate specific components of the angular momentum to the overall commutation relation.
There is ongoing exploration of various approaches to the problem, with some participants offering insights into vector notation and the use of the triple product expansion. However, there is no explicit consensus on the next steps, and some participants express confusion about the progression of the solution.
Participants note the complexity of the problem and the potential need for additional background in vector notation or commutation relations. There is an acknowledgment of the linearity of the commutator and its product rule, which may influence the direction of the discussion.
elmp
can someone please help me with this. it's killing me.
to show [tex]\left[\vec{L}^{2}\left[\vec{L}^{2},\vec{r}\right]\right]=2\hbar^{2}(\vec{r}\vec{L}^{2}+\vec{L}^{2}\vec{r})[/tex]
I have already established a result (from the hint of the question) that
[tex]\left[\vec{L}^{2},\vec{r}\right]=2\imath\hbar\vec{r}\times\vec{L}+2\hbar^{2}\vec{r}[/tex]
but where to go from that?
basically I will need to show either one of (4.55) from http://www.eng.fsu.edu/~dommelen/quantum/style_a/commute.html, but I am running out of clues.
if you know vector component notation (look it up) then this is a pretty simple problem
[tex]\vec{r} \times \vec{L} = \epsilon_{ijk} r_j L_k[/tex] where [tex]\epsilon_{ijk}[/tex] is the levi-civita tensor (look it up)
if you don't you could use the triple product expansion
[tex]\vec{r} \times (\vec {r} \times \vec{p}) = \vec{r} (\vec{r} \cdot \vec{p}) - \vec{p}( r^2)[/tex]
and then apply all the other commutation relations you know, but that is tedious
Hm, I'm interested in this now as well, but in the OP's post I don't see how quite to arrive at:
I can find that
[L^2,z]=2i\hbar(xL_y-yL_x-i\hbar z)
and the equivalents for x and y, but how do you relate that to the commutator
[tex]\left[\vec{L}^{2},\vec{r}\right][/tex]
Nevermind my last post, if you do everything in vector notation (or matrix notation, things work out peachy keen.
hmmm, i must be really stupid, but i still don't see how to proceed
Use that fact that the commutator is linear and its product rule, so you get
[tex]\left[\vec{L}^{2}, \left[\vec{L}^{2},\vec{r}\right]\right] = \left[\vec{L}^{2}, 2\mathrm{i}\hbar\vec{r}\times\vec{L}+2\hbar^{2}\vec{r} \right] = 2\mathrm{i}\hbar \left[\vec{L}^{2}, \vec{r}\times\vec{L} \right] + 2\hbar^{2} \left[\vec{L}^{2}, \vec{r} \right] = 2\mathrm{i}\hbar \vec{r}\times \left[\vec{L}^{2}, \vec{L} \right] + 2\mathrm{i}\hbar \left[\vec{L}^{2}, \vec{r} \right] \times\vec{L} + 2\hbar^{2} \left[\vec{L}^{2}, \vec{r} \right][/tex]
Then you are almost done, to have a nice result you need the triple product expansion given before.
  • · Replies 20 ·
