Puzzle of scalar dynamic in the early universe
The discussion revolves around the dynamics of a scalar field in the early universe, specifically focusing on the equation of motion for the scalar field and the implications of including energy and temperature effects. Participants explore the mathematical formulation and physical interpretations of the scalar field's behavior, including its energy density and interactions with other matter fields.
  • Some participants discuss the equation of motion for the scalar field and express confusion regarding the application of the energy operator, suggesting a need to incorporate the universe's energy or temperature.
  • Others propose that the scalar field should include both mass and kinetic energy terms, emphasizing the importance of calculating the stress-energy tensor to understand the energy of the system.
  • There is mention of the necessity for a second solution to the differential equation to accurately describe the motion of the field.
  • Some participants argue that the Hubble parameter acts as a damping factor in the amplitude of the scalar field, affecting the energy calculations.
  • Concerns are raised about the validity of the proposed solution \(\phi = Ae^{imt}\) due to the Hubble term's influence, with suggestions to reference specific equations from literature for clarification.
  • Participants discuss the implications of neglecting the Hubble parameter and its potential impact on energy calculations, indicating that assumptions about its smallness may not hold.
Participants express differing views on the correct formulation of the scalar field's dynamics, particularly regarding the inclusion of energy terms and the validity of specific solutions. The discussion remains unresolved with multiple competing perspectives on how to approach the problem.
Limitations include assumptions about the Hubble parameter's smallness, the dependence on the definitions of energy and temperature, and the unresolved nature of the scalar field's equation of motion in the context of the universe's dynamics.
Accidently
Sometimes we need to calculate the evolution of the scalar field [tex]\phi[/tex] with the equation of motion
[tex]\frac{\partial^2 \phi}{\partial t^2}+3H\frac{\partial \phi}{\partial t}+m_\phi^2 \phi = 0[/tex].
And we can get the field
[tex]\phi=Ae^{im_\phi t}[/tex]
where A is the amplitude of the scalar field (damped by the Hubble parameter in this case).
But when we apply the energy operator [tex]i\frac{\partial}{\partial t}[/tex] on the field, what we get is [tex]E=m_\phi[/tex]
This is incorrect. And it seems that we should include the energy/temperature of the universe somewhere, but do not know how.
Space news on Phys.org
The equation you are studying is that of a decoupled scalar field -- i.e. it is not interacting with anything in the universe other than gravity. As far as this system is concerned, all the energy in the universe is contained in the scalar field matter. Strictly speaking, you should be calculating the stress-energy tensor of the scalar field (or its quantum expectation value) to answer this question to get at the energy of the system.
More realistically, you will want to include all couplings between the scalar field and other matter sectors of the theory -- then you will see a dependence of the total energy on these other matter fields.
I think what he means is that this field should not only contain the mass term, but also a kinetic energy term.
I'd also like to mention, however, that any second-order linear differential equation has two solutions, so you need a second solution to get the correct motion of the field. Accidentally, you might also do better at understanding the energy of the particle by using the Hamiltonian operator.
I see. Consider calculating the [tex]T_{00}[/itex] component of the stress-energy tensor -- this gives you the energy density, [itex]\rho[/itex], of the gravitating stress-energy content of the universe. With scalar field matter, you find <br /> [tex]\rho = \frac{1}{2}\dot{\phi}^2 + V(\phi)[/itex]<br /> where the first term is the kinetic energy, and [itex]V(\phi) = m^2\phi^2[/itex] for a polynomial potential energy function.<br /> <br /> If you have other relevant fields in the theory, including any couplings between them, they will also contribute to the overall energy density.[/tex][/tex]
Yes, that is exact what I mean. I know I oversimplified too many things here. I just mean for a stable scalar field, the solution should look like that.
That's what I thought. The problem here is that the time derivative of the scalar field is just a constant times the scalar field, so that your sum of the kinetic and potential energy terms can be wrapped back into a constant multiple of the field itself (in fact, this is necessarily the case as long as it's in an energy eigenstate). I think that is what is hiding the kinetic energy component in the way you're approaching it.
To get the kinetic energy component explicitly, just use the Hamiltonian operator instead of the time derivative. You should be able to both verify that the kinetic energy term is there, and that it reduces to the simple time derivative when evaluated (that is, you should be able to replicate what bapowell posted above).
bapowell said:
[tex]\rho = \frac{1}{2}\dot{\phi}^2 + V(\phi)[/itex][/tex]
[tex] Yes, this makes sense. <br /> <br /> So, if we write the scalar field as<br /> [tex]\phi=Ae^{-iat}[/tex],<br /> it is not necessary to say [tex]a=E[/tex] or [tex]a=T[/tex], with [tex]E[/tex] and [tex]T[/tex] the energy of the field and the temperature of the universe, (if the field is in equilibrium). Is this right?<br /> <br /> Thanks for all your replies.[/tex]
Looking back at your initial post, I'm confused by your assertion that [itex]\phi = Ae^{imt}[/itex] is a solution to the scalar field EOM. It isn't, because of the Hubble term. The Hubble term is itself a function of [itex]\phi[/itex] and [itex]\dot{\phi}[/itex].
I think the Hubble parameter acts as a damping factor in the amplitude. And we can separate [tex]e^{imt}[/itex] in the solution. for example eq. (7.9.2) and (7.9.3) in hep-th/0503203[/tex]
[tex] OK, but then when you apply [itex]i\frac{\partial}{\partial t}[/itex] to the field how is it that you can ignore the time-dependent amplitude?[/tex]
I know, I have assumed that the Hubble parameter is small and neglectable. I should have said that. sorry. I think even with the Hubble parameter in the field, we still cannot get a correct energy, so ignored that...
  • · Replies 17 ·
  • · Replies 55 ·
  • · Replies 36 ·
  • · Replies 27 ·
