If a uniform beam was in space and only was applied a force on one side (Stress)
The discussion revolves around the behavior of a uniform beam in space when a force is applied to one side. Participants explore whether the beam experiences stress and deformation under these conditions, considering various scenarios such as the beam being free-floating or simply supported. The conversation includes theoretical implications of stress distribution and the effects of acceleration on the beam.
  • One participant questions if a beam in space with a force applied to one side experiences stress and seeks clarification on the nature of that stress.
  • Another participant argues that if the beam is floating in space, it would not experience stress, while also noting that if simply supported, the stress would be F/A far from the point of application.
  • A different viewpoint suggests that the beam would accelerate due to the applied force, leading to a gradient of stress within the beam.
  • Some participants propose that stress exists at the point of force application and decreases linearly to zero at the other end of the beam.
  • There is a discussion about the concept of equilibrium within the beam, with some asserting that the beam is not in equilibrium due to acceleration.
  • One participant reflects on the reasoning that each segment of the beam must feel a tensile stress due to the pulling force applied at one end, suggesting a collective response among the segments.
  • Another participant emphasizes that stress is present in the region of force application but diminishes with distance from that point.
  • One participant mentions that any force applied to an object will cause stress and deformation, introducing the concept of the speed of sound in materials affecting how motion propagates through the object.
Participants express conflicting views on whether the beam experiences stress when a force is applied to one side. Some assert that stress is present, while others maintain that it is not, leading to an unresolved debate on the topic.
Participants highlight the importance of defining constraints and conditions under which the beam operates, such as whether it is floating or supported, which influences the discussion on stress and equilibrium.
gladius999
If a uniform beam was in space (no gravity or resistance of any kind) and only was applied a force F on only one side, does the inside of the beam feel a stress and deform? If so, what does the stress equal? Can you explain why/why not the beam feels a stress or not?
I know that that if applied a force on both sides, the stress would just be F/cross sectional area of beam. But in this case the force is only on one side.
I believe that if I imagine the beam to consist of 2 parts joined up (part A and part B), if say a pulling force was applied to the part A, part A would pull on part B. But then part B would also exert a force equal in magnitude but opposite in direction on part A (Newton's third law). Would'nt part A feel a tensile stress then as it would have a force pulling it in one direction and another pulling it towards B in the opposite direction? Can someone correct me on this?
Thank you very much
Well if you want a true answer to this question you have to define your constraints. If the element was simply floating in space and a force applied on one side then there would be no stress.
If it is simply supported on one end and a force applied to another the resulting stress far away from the point of application is F/A. (In technical terms this element is now a rod).
Even if you left the rod floating and applied precisely the same force on both ends the stress would remain F/A. At any cut along the rod, forces must remain in equilibrium for this to remain true.
Imagine the rod as one continuous element and at any point equilibrium must hold. So all sections should either be in a tensile or compressive state.
That is wrong. The element would accelerate. From Newton's laws of motion there is a force on each particle causing it to accelerate. That force comes from the gradient (rate of change) of stress in the body. In other words, it you consider a small part of the body, the different stresses on each side of it create different forces acting on it, and the difference between the forces = mass x acceleration.
No. If the force is applied at one end of the rod in the direction along its length, the stress is F/A at the end where the force is applied, and decreases linearly to 0 at the other end.
The rod is not in equilibrium. It is accelerating.
AlephZero said:
That is wrong. The element would accelerate. From Newton's laws of motion there is a force on each particle causing it to accelerate. That force comes from the gradient (rate of change) of stress in the body. In other words, it you consider a small part of the body, the different stresses on each side of it create different forces acting on it, and the difference between the forces = mass x acceleration.No. If the force is applied at one end of the rod in the direction along its length, the stress is F/A at the end where the force is applied, and decreases linearly to 0 at the other end.The rod is not in equilibrium. It is accelerating.
Thanks for both your replies. It appears to me that there seems to be some contradiction between you two.
So what I'm getting here is, that if a uniform bar is in free space(with no gravity, resiistance) and no end fixed but only one end being pulled by a force F, the bar does feel a stress at the end being pulled at a pressure of F/A and decreases along the bar linearly to zero?
I think it makes sense to have a stress in the bar even if only pulled by one side because if we view the bar as consisting of many small bars added together, when a force is applied to one end, all of the bars must feel a pulling force, but each bar also has to pull the bar behind it, therefore each bar should be feeling a tensile stress?
Can someone point out the flaws in my reasoning?
Ok true, within the region of application yes there is a stress, however, very small.
You are correct however, I mentioned two forces equal and opposite. Equal and opposite forces applied at both ends make the rod a two-force member. Regardless if its on Earth or in space.
In the region of application the stress is not F/A, sufficiently far away it is ( Re: Saint Venant's region...).
Maybe I should've been more specific, forces inside the rod must maintain equilibrium up to fracture, i.e. regardless of the reference frame forces inside add up to zero as long as it is not buckling, warping or under any other effect which it is continually deforming...
Good sir, would you say my reasoning(shown below) is correct?:
yes, there is a contradiction. Viscousflow is wrong, AlephZero is right.
Any time any force is applied to any object, the object will undergo stress and will deform. The motion will only propagate through the object at the object's speed of sound, which is very finite.
The only circumstance in which this would not occur is in an non-Einsteinian universe, where ideally-rigid objects can exist and forces can be transmitted at infinite speed.
  • · Replies 18 ·
  • · Replies 19 ·
  • · Replies 69 ·
