| Thread Closed |
Brains create consciousness? |
Share Thread | Thread Tools |
| Mar21-11, 01:29 PM | #18 |
Brains create consciousness?Neutral monism (if it means that the mental and physical are both actually something else that is neither mental nor physical), seems to require two instances of emergence. Im curious what the big problems with panpsychism are. I have seen people argue that it is ridiculous, but that just seems like a rejection based on emotion. |
| Mar21-11, 02:20 PM | #19 |
1) there is no physical property of "pressure" left to describe 2) there is still some physical property of "pressure" left to describe (this would mean pressure is irreducible) If (1) then supervenience is psychological (this is what i think) and this means there is nothing physicalist about the idea that C supervenes on the brain. I think it would fall in the same category as the idea that C is an illusion of the brain. |
| Mar21-11, 04:49 PM | #20 |
Panpsychism is based on a material or substance ontology. Substance is material existence which possess (locally, inherently) a set of properties. But the systems view is a process ontology - one in which substance and form are in interaction. And Koch/Tononi would be seeking the minimum notion of a process. They talk about the process being differentiation~integration, and the fact it is synergistic. Differentiation~integration is a standard systems dichotomy. It is making the local~global, construction~constraint, distinction in talking about "the production of local variety" vs "the production of global cohesion". The systems view does have a version of panpsychism I guess in pansemiosis. This makes the claim that everything that exists - no matter how small or minimally formed - is a bootstrapping process. So even atoms of matter would really be a minute scrap of synergistic process. I'm not sure why Koch calls Tononi's approach panpsychic. He often makes philosophical statements that seem at odds with his neuroscientific insights. But I think there is an obvious distinction to be made between the idea of "properties of atoms" and "atoms of process". One reduces properties to local substance. The other treats the interaction between substance and form as an irreducible property! |
| Mar21-11, 05:13 PM | #21 |
Then we decide to turn it round and objectify ourselves as well. The modeller also wants to be modelled, the observer also to be the observed. For as long as the observer tries to maintain the fiction that observables have objective existence, the exercise does not go very well. Because the notion of objective existence is based on the "view from nowhere" and what we are trying to observe is precisely "a point of view". If instead we take a different approach, one that sees "point of view" as a dynamic process, an act of epistemic cut forming, then we can start to make models that include both the modeller and the modelled in some properly objective way. So reductionism reduces subjectivity (POV) to the objective view from nowhere - a realm without observers. Then finds it cannot model POVs in a causal language that has been rendered observerless - where observerhood has been made a paradox as observers no longer seem causally essential to "what exists". To get out of that bind, we have to instead start with a model of the modelling relation - the dynamical connection between observer and observed. Then reduce that relationship to its essence. We would then have a theory of how POVs form their "mental" worlds. Heidegger: "The stone is worldless, the animal is poor in world, man is world-forming." |
| Mar21-11, 05:49 PM | #22 |
I’d agree with Ferris in quoting Chalmers where Chalmers states that (weak) emergence is a “psychological” property. I think that might be a bit confusing though....
The punch line is exactly as you say then. If C is supervenient on the interaction of neurons, our theory of mind falls into the same category as the idea that C is an illusion, C is irrelevant, and C is not knowable. But very few people really accept that. Most, including Chalmers and Bedau, will then step back and say C must be strongly emergent. |
| Mar22-11, 08:00 AM | #24 |
I took a look at this article about Tononi. It’s a good illustration of the confusion I was talking about above, in that it treats “consciousness” as an objective characteristic of certain very complex systems, and attempts to quantify it. Okay, if we can do that, then of course somewhat less complex systems will have somewhat less “consciousness”, and there could be a very small amount of it in quite simple systems too. The only objection I have to this is that the article pretends that it’s addressing the nature of subjectivity. Referring to robotic vacuum cleaners, bees and newborn babies, it says – “The truth is that we really do not know which of these organisms is or is not conscious. We have strong feelings about the matter... But we have no objective, rational method, no step-by-step procedure, to determine whether a given organism has subjective states, has feelings.” So on the one hand we’re talking about objective properties of systems, and on the other hand whether the system “sees from inside”, so to speak. And I think this is the reason there’s such a “hard problem” with “consciousness” – that we talk as though "its own viewpoint" were some mysterious characteristic that a system might or might not have. A baby or a bee or a vacuum cleaner certainly “has” its own point of view on the world. If that’s all “panpsychism” means, then it doesn’t mean much. A tree or a rock or an atom surely “sees” the world around it, in that it receives and responds to information in its physical environment. Does anyone question that? But what do these different kinds of systems do with the information they receive? So far as I know, only humans do this thing of building a world in their heads that they talk to themselves about, and compare with how others see the world. So only humans are in a position to say, “Yow, that hurts!” or “I really like that.” If you want to ask whether a rock or a robot or an insect “has feelings” – well, of course they don’t have feelings like ours, and they don’t have the capacity for noticing and relating to their own feelings that we humans have. But this difference is clearly not mainly about sensory systems or brain complexity, since our brains aren’t that different from those of other animals. It’s mainly about being able to talk to ourselves and with others. Now as a matter of fact – to digress for a minute – I think it would be a very good thing for physicists to ask what the world looks like from the point of view of an atom. I think the main reason why combining Relativity and Quantum theory presents such a deep problem for physicists is that they don’t take “the viewpoint of the observer” seriously enough. In contrast to the objective reality we imagine is out there, the physical world we all actually experience is made of real-time interactions that communicate information between different points of view. And we don’t yet have the language to conceptualize this kind of system of relationships. I think both Relativity and QM, in different ways, are talking about the structure of the kind of system that we (and atoms) see “from inside.” These theories seem so “counter-intuitive” because of our very strong tendency to conceive the world as made of things-in-themselves with intrinsic properties that are independent of any interaction... and that objective view just doesn’t work, at a fundamental level. But I would never describe this as “panpsychism”. An atom “has a point of view” only in the sense of being in this particular place at this particular moment, interacting with the world. To that extent, it’s just like each of us. But there’s no big mystery about “subjectivity” in this sense, and it has nothing to do with what goes on in the brain. |
| Mar22-11, 08:15 AM | #25 |
panpsychism doesn't really bother me, much like I'm not concerned about free will.
The question of subjective experience though... I don't think we really have a clue how that arises. Not even an inkling. The more we probe the brain and gene expression, the more evidence we find that our behavior is part of the causal chain of determinism, that free will isn't really necessary to explain behavior. I'm fascinated with weak emergence as a general property of the universe, but I'm still dumbfounded as to how you'd manifest a subjective experience from our known laws. And even more dumbfounded as to how you'd inject free will into a deterministic system. What is free will? The ability to choose? But choices aren't arbitrary, they're based on a compressed collection of stimuli from our ancients (genetics) and the history of stimuli on our own receptors. So what is free will then? |
| Mar23-11, 05:21 AM | #26 |
I’m going to try to respond to this in terms of what I tried to say above, that subjectivity is purely an issue of viewpoint. Here you are taking a purely objective view of the world, and then asking where “experience” and “free will” fit into that picture. But they don’t fit into it – because you’re imagining the world as if you could stand “outside” of it and inspect it the way you view an object. Subjective experience and free will only exist from the point of view of whomever or whatever is doing the existing. And this is never done independently of the rest of the world. To try to unpack that – first of all, the issue of “determinism” is irrelevant. My own view is that it’s hardly sensible to talk about “causal chains of determinism” as a basic feature of the world, when we know this is not a good description of submicroscopic processes. But let’s go ahead and assume everything is rigorously determined and nothing ever happens by chance. So I'm sitting here thinking about something and trying to make a decision. A cosmic particle flies in from a distant star and gets absorbed by a neuron in my brain, causing it to fire... and this results in my deciding a certain way. That’s the objective viewpoint. My subjective experience is that I made the decision. I don’t understand why these two descriptions of the situation are in any way contradictory. Would I be more “free” in my decision if all the physical events involved in it had occurred inside my head? Or if there were no external circumstances whatever involved in it? I don’t think I ever make any such decisions. When I say “I” made the decision, I’m not referring to some mysterious psychic entity that’s somehow independent of the physical world. I mean me, including my brain and my body and all the relevant influences of all kinds that go into my being who I am, right now. What else could I mean? From the point of view of the person doing the deciding, it’s “free” only in the sense that the decision is up to them – including all the relevant influences and “determining causes” that make up who they are. It makes no difference whatever whether we assume there’s some degree of chance involved in those “causal factors”. So now, as to the question of “how you'd manifest a subjective experience from our known laws.” Evidently the laws support all kinds of more and less complex systems, each of which has its own point of view on the world, to the extent that it exists at a certain place and time in the web of ongoing interaction. Some of these systems do a lot more internal processing than others, and can interact with their environments more autonomously. Whether or not this processing is perceived as “subjective experience” is not a question that can be meaningfully asked “from the outside”, objectively. So far as we know, only humans have the ability to ask or answer questions about their own experience. Our brains have become bigger and more complex in response to the many new possibilities language opens up. But there’s no reason to think there’s anything else going on that objectively distinguishes our internal processing from that of other systems. To ask whether subjectivity exists, objectively, in a given system, is the “category error” I discussed above. We would be making the same mistake if we said that subjectivity – along with its sense of being free or being constrained – is merely an “illusion”, merely “imaginary”, as though it were supposed to be something else. |
| Mar23-11, 06:12 AM | #27 |
Apeiron – once again, we’re clearly wrestling with similar issues. And I don’t disagree with what you say... but you seem to be trying to make an objective model that can adequately include “points of view”, by describing them in process-language rather than thing-language. That kind of description may or may not prove useful in some way – but I don’t think we need an objective model that includes subjectivity. What we need is to grasp the basic difference between an objective description and a description from a point of view in the world. That is, we need to free ourselves from the assumption that a view “from outside” should be able to include everything important about the world. My goal is not a view “from outside” that includes everything, even our mental experience, as “objectively real”. My thought is closer to Fra’s in the “Beyond” forum – that we need to develop ways of describing the world “from inside”, not to replace the objective description but to complement it. There’s a lot about the world that’s well described objectively, often even “deterministically”. But there’s another aspect of the world’s structure that’s only visible “from inside” the web of communicative connections between different points of view. This is basically a structure that lets each interaction be meaningful in the context of other kinds of interactions – that lets interactions be “measurements”, in the language of QM. This is certainly a dynamic structure, but I don’t think it’s one that can be succesfully “modeled” from a standpoint outside the system. I don’t think we will understand either QM or the nature of “consciousness” until we have better ways of thinking about what Heidegger called “being here” (Dasein) – existence from the standpoint of things “doing the existing” within this web of real-time connection. |
| Mar23-11, 01:08 PM | #28 |
| Mar23-11, 09:11 PM | #29 |
But then you may just mean that "objective" is a mistaken term for what we do when we model. And I would agree to that. I see the task as generalising. So we have a very particular and subjective POV. And to move out of that, we seek the most general and hence objective POV - the god's eye view in some sense. Nozick called it seeking the invariances of nature. The maximal symmetries. Reductionism has been about the search for the fundamental substance - the atoms, the matter, the general physical stuff of which a material world is made. But you are talking about generalising something else - the notion of relationships. And that is really the systems approach. It is certainly exactly the Peircean semiotic approach. So I don't think you are doing something different when it comes to the modelling, just focusing on something different as the central thing to objectify or generalise. Our subjective POV is based on a hierarchical interaction between general ideas and particular impressions. Our ideas are the longrun context that frames our moment to moment impressions (just as these impressions accumulate over time to become generalised as ideas). So all we are talking about in "objectifying" our understanding of reality is forming ever more general ideas about the world. And these ideas in return lead to ever more particular impressions. If I learn for example that reality is fundamentally composed of material particles, then this general idea will shape my impressions - it will be the expectation that drives even what I look to find. And the same if instead I have a general idea that the world is composed of relationships. Now that leaps out at me at every turn. So all understanding remains subjective. But generalisation is a way of structuring our subjective experience so it seems more universal, more objective. And that would not change if our ideas are based on notions of atoms or notions of relationships. I know there is a debate concerning internalism vs externalism in philosophy. There is a difference between the two in that one sees the boundaries of a system as something that "exists" (if you can stand outside looking at it, then it exists), while the other sees boundaries in terms of limits - the limits of a process. So from the inside, there is only the limit where things cease to be. And so the boundaries themselves "don't exist". I would take the internalist position here. Yet still, internalism does not equal subjective (and externalism = objective). Both are general ideas framed within out minds (in an attempt to go beyond our particular physically local and emboddied POV). Although the internalist view of boundaries is probably more in keeping with the view that, after all, our understanding is from "inside the system". |
| Mar24-11, 01:57 AM | #30 |
What you really mean with "emergence" here is better illustrated with the protein example. A protein may fold in many different ways, just like a molecule may move up, down, left, right, follow a circular or figure 8 pattern, etc. However, no matter how complex the motion gets, there is a simpler version. Motion has been around at least since the big bang. You will find that the same is true for the "signal" and anything else physical you can find in the universe. If we drop all those arbitrary (higher level)descriptions, we end up with the lower level descriptions of the basic physical ingredients (as identified by physics). We may arbitrarily feel that "stupid" is not a suitable description for a rock, but we can indeed say (at least if one is a physicalist) that a rock really just consists of a collection of basic physical ingredients, as do humans. |
| Mar24-11, 07:51 AM | #31 |
Whether or not we can call it as humans, there is a threshold of complexity AND the action of those complex ingredients that forms the line between living and inert, never mind conscious. A simple way to look at this would be that unlike your pile of sand, you can pick out neurons from a brain one by one, and whether you like it or not, it will cease to be a brain. When exactly you reduce it to the point of being dead or inert is something you'll discover, but it doesn't depend on how we view it, or define it. You can't look at a rock and call it stupid, because stupidity is a function of non-inert, thinking matter. A rock isn't even a definition that means much... a rock of what exactly?... granite? Sandstone? Cocaine?! In the same way, I'm not touching "conscious", because we only have ourselves at the "top" example, and can only compare ourselves to other animals, fungi, rocks... etc. You can get a rock we call a planet, which is incredibly complex and dynamic, but it's still not thinking; two neurons do more thinking than Jupiter ever will. There is plenty of physical "noise" in a rock, but no signal, and I'd say it's the capacity to produce signals that is the big difference, the yardstick we can use. |
| Mar24-11, 08:18 AM | #32 |
Thanks for putting this so clearly. There’s a fundamental issue here that’s difficult even to state, because we have such excellent conceptual tools for dealing with the world of things (including “systems” of all kinds), and few attempts have even been made to deal with the relationships between things. So for example, we refer to “consciousness” as a characteristic of certain kinds of things, as maybe “emerging” in certain types of complex systems. I think it would be better to think of consciousness (in the human sense) as an aspect of the talking-relationships people learn to have with each other (and then later with themselves), as they grow up. The issue is that the modeling / generalizing mode of thought that we’re so good at is inherently “objectifying”. To think this way is to step out of our connections with things and imagine them “in themselves” – even if when we’re imagining is a “system of relationships” or a “web of real-time interaction”. This is why I don’t identify with “systems thinking” or the kind of “internalism” that you refer to above... even though I recognize that they’re genuine attempts to find language for the “relational” aspect of existence. Even when what they’re trying to model is the “observer / observed relationship” itself, to my mind this kind of thinking remains within the traditional paradigm, of the disengaged thinker building models of reality in his head and checking if they correspond to the appearances. This paradigm is excellent, but limited. It does not work for clarifying what’s at the basis of the physical world, or for clarifying what we mean by “consciousness”. There’s another paradigm – I’m thinking of Phenomenology – that tries to describe the world of subjective consciousness itself. But to my mind this doesn’t get at what’s fundamental either, because the self-enclosed world of the self-observing consciousness also tends to miss the deeper dimension of communicative connection with other people. We don’t yet have a paradigm adequate to “the between” out of which I think our conscious selves emerge. Heidegger is one of the few philosophers who understood this. You can’t “generalize” about existence, because there is never more than one’s own existence to deal with. Nor are relationships like things, that have properties and can be described “from outside”. Relationships (in the sense I think is fundamental) only exist for the two who are in the relationship – and even they have opposite viewpoints on it. Heidegger saw that we need a different kind of category-system to deal with the aspect of the world that we “see from inside”, only from this unique perspective each of us has, and that goes deeper than our own self-hood. Instead of “generalizing” – which abstracts from the uniqueness of existence rooted in real-time connection. In Being and Time he called this kind of category “existentials” – attempts to articulate the structure of “being-in-the-world” from one’s own point of view. It’s relatively easy to explain why the traditional model-building paradigm is limited, and Heidegger was good at that. It’s not easy at all to see what a different paradigm would look like. Being and Time made a remarkable start at this, but Heidegger was unable even to complete that work as he’d originally projected it. And neither his later writing nor that of his “followers” got much further, in my view. So while I’m sure many philosophers see this as a closed chapter in our story... for me, it’s still the basic unresolved issue, if we're trying to understand the basis of our own existence. |
| Mar24-11, 08:22 AM | #33 |
I think pftest is making a basic point about language, which is actually very important to recognize because language is all we have here. Language involves hanging labels on things, but what are these "things"? They are the only things we are in any position to hang labels on: shared experiences. Period, that's what language is, hanging labels on experiences that we (assume we) share. So we cannot actually label the object "table", all we can label are the shared experiences we have around that object. This is quite important when we come to physicalism, and the OP question of whether or not a brain "creates" consciousness.
Both brain, consciousness, and create, are words, so can be nothing but hanging labels on shared experiences. We are looking for connections between these shared experiences, to make sense of them. Just like with cause and effect, we are looking for basic relationships, and also just like with cause and effect, we cannot actually demonstrate that the cause "creates" the effect, all we can say is the former gives us a way to make sense of the appearance of the latter, given that we experience things in temporal order. Using precise language like that saves us from making wrong terms based on assumptions we have made that we cannot actually demonstrate are true, and the same holds for claims that brains create consciousness, or are the "source" of consciousness, whatever we imagine a "source" is. |
| Mar24-11, 08:23 AM | #34 |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Brains create consciousness?
| Moving consciousness inside the brain | Medical Sciences | 32 | ||
| Pain and the brain/consciousness | Medical Sciences | 1 | ||
| Brain consciousness | Biology | 22 | ||
| Consciousness and The Brain | Biology | 0 | ||
