Register to reply
Quick Python question - how to change input to *
by zeion
Tags: input, python
Share this thread:
zeion
#1
Mar19-11, 09:00 PM
P: 467
Hello,
Just a quick question here for Python.
I'm using raw_input to get the user to type in a string, but I want the letters to display as * (like when you enter a password) as they type it. (But not actually register as *). Is this doable in Python?
Thanks.
2. Relevant equations
3. The attempt at a solution
Phys.Org News Partner Science news on Phys.org
Physicists discuss quantum pigeonhole principle
Giant crater in Russia's far north sparks mystery
NASA Mars spacecraft prepare for close comet flyby
jhae2.718
#2
Mar19-11, 09:13 PM
PF Gold
jhae2.718's Avatar
P: 1,153
You could probably copy and modify the getpass module, which doesn't echo any input to the screen, to echo asterisks instead.
That might only work for terminals, though.
zeion
#3
Mar19-11, 09:32 PM
P: 467
Yeah.. can't seen to work on a PC.
Getting this:
Warning (from warnings module):
File "C:\Python27\lib\getpass.py", line 92
return fallback_getpass(prompt, stream)
GetPassWarning: Can not control echo on the terminal.
Warning: Password input may be echoed.
zeion
#4
Mar19-11, 09:32 PM
P: 467
Is there a way to do it with the curses module?
jhae2.718
#5
Mar19-11, 09:34 PM
PF Gold
jhae2.718's Avatar
P: 1,153
Are you using IDLE? You might have to use cmd for that to work.
Otherwise, if you are using stdin, you might be able to use sys.stdin or the msvcrt module to print asterisks instead of input.
What are you trying to do?
You could probably work something out using curses.
zeion
#6
Mar19-11, 09:41 PM
P: 467
Actually I'm just trying to write a game where the other player cannot see what was typed. Is there a way to just delete a line that was displayed?
jhae2.718
#7
Mar19-11, 09:52 PM
PF Gold
jhae2.718's Avatar
P: 1,153
Are you doing it in terminal or GUI?
jhae2.718
#8
Mar19-11, 09:52 PM
PF Gold
jhae2.718's Avatar
P: 1,153
Tkinter, IIRC, has an option for a text entry box where you can mask input with asterisks.
zeion
#9
Mar20-11, 09:08 AM
P: 467
Quote Quote by jhae2.718 View Post
I'm doing it in GUI..
Sorry I don't know what those are. Are they Python modules?
jhae2.718
#10
Mar20-11, 09:10 AM
PF Gold
jhae2.718's Avatar
P: 1,153
Tkinter is the default GUI toolkit for Python. Sys and msvcrt are Python modules, but if you are doing GUI, the toolkit should have a provision for password entry which should suit your needs.
What toolkit are you using?
Register to reply
Related Discussions
Compile Python, Matlab and Python Programming & Computer Science 3
Quick Question on maximum pressure change in a stationary wave Introductory Physics Homework 3
Change battery input with a power adaptor Electrical Engineering 8
Python question Engineering, Comp Sci, & Technology Homework 2
Logic question, 3 input OR to 2 input OR Electrical Engineering 9
