Register to reply
Fluid Mechanics, Find the coefficient of discharge in laboratory setting
by UserUndecided
Tags: coefficient, discharge, fluid, laboratory, mechanics, setting
Share this thread:
UserUndecided
#1
Mar20-11, 08:39 PM
P: 1
Well, first of all, thank you for reading this, as you may see this is my first time posting, but I've been reading threads here for a while and found it really helpful, this time I find myself stuck and hope you can push me in the right direction.
In the laboratory we will measure the coefficient of discharge for a graduated cylinder filled with water.
A drawing of said container:
The tools we can use are:
  • The graduated Cylinder (kinda obvious right?)
  • Vernier scale (To measure the diameter of the cylinder and a small orifice near the bottom)
  • A cronometer
The procedure we were advised to use is:
  1. Cover the small orifice.
  2. Fill the cylinder (up to the 1000cc mark)
  3. Release the the small orifice and start the cronometer
  4. When the level of the water reaches a 100c mark stop the cronometer
  5. Annotate in a table both the volume discharged and the time it took
This should give us a table like (Thanks for reading this far):
Meas.   Height dropped (mm)/vol discharged(cm3)  Time (s)
1                     100cc                        2.02
2                     200cc                        2.5
3                     300cc                        3.025
Variables' names that I will use:
The level of reference to measure h_i is the initial level of the water
As can be noticed the pressure at the top of the water level (P_1) and the pressure at the orifice (P_2) are both the same (Atmospheric).
(Forgot on pic, but also d_h2o for the density of the liquid, I'm not experienced in LaTeX, sorry for the weird notation)
After all that we have three tasks
  1. Find the v_2 as a function of h_i
  2. Find discharge Q as a function of h_i
  3. Apply least squares to find the coefficient of discharge C_d
  4. Plot the discharge Q as a function of height h_i
2. Relevant equations
Bernoulli's Principle in the form:
P_1 + d_h2o*g*h_i + 1/2*d_h2o*v_12 = P_2 + d_h2o*g*h_j + 1/2*d_h2o*v_22
Continuity of Fluids:
A_1*v_1 = A_2*v_2
Definition of discharge:
Q = V/t (where uppercase v is volume and t is time)
Q = A*v (where lowercase v is velocity and A is area)
Definition of coefficient of discharge:
Qe=C_d * Qi (where Qe is the experimental result and Qi is the ideal result)
I think that the least squares is applied to this last one
3. The attempt at a solution
For the first task I just took Bernoulli's, canceled the pressures since they're the same and canceled the first member's height since I'll consider that the level from which the distance to the other one will be measured.
After that I isolate v_1 from the continuity equation and replace it in the result of the previous one.
As a result I get v_2 = sqrt(2gh/(1-(A_2/A_1)2))
That would complete task one
For the next one is where the confusion begins, what would be the best way to find the Discharge as a function of height? and even if I do find the Discharge, how would I go about find the coefficient of discharge? according to the formula I'd need to find both an ideal discharge and a experimental discharge, if I assume that discharge is A_2*v_2 I have relied on h_i to find v_2 so it doesn't seem ideal anymore.
The other things I can think of are:
Since the h_i is measured from the initial level of the water, and the velocity v_2 is at the top when the container is full then the resulting formula of Discharge as a function of height is something like Q = constant * h-something
Because:
Hopefully some of you have time and can help, thanks in advance for your time.
Obligatory disclaimer: If there are anything unclear or something that you don't understand (notation, bad english) don't doubt on asking, English is not my mother tongue.
Phys.Org News Partner Science news on Phys.org
NASA team lays plans to observe new worlds
IHEP in China has ambitions for Higgs factory
Spinach could lead to alternative energy more powerful than Popeye
Register to reply
Related Discussions
Venturi meter/ coefficient of discharge experiment Advanced Physics Homework 2
Mechanics - find the coefficient of friction Introductory Physics Homework 2
Fluid Mechanics - Find the required power Engineering, Comp Sci, & Technology Homework 0
Discharge coefficient General Engineering 1
Fluid Mechanics - Drag coefficient and Pressure coefficient Mechanical Engineering 1
