Find the Minimum Volume of cone, answer does not make sense
by Brown Arrow
Tags: cone, minimum, sense, volume
Brown Arrow
Brown Arrow is offline
#1
Mar22-11, 12:27 AM
P: 101
Find the Dimensions of the right circular cone of minimum volume which can be circumscribed about a sphere of radius 8 inches.
2. Relevant equations
N/A
3. The attempt at a solution
So this is my try, i did the question to find the minimum volume of the cone,
For Larger Size: http://i54.tinypic.com/29yqyiw.jpg
As you can see the minimum value is when h=0 , thus volume is equal to 0, it makes sense the minimum volume would be 0, but i think i did the question wrong, can you tell me where i've gone wrong.
Please help
Phys.Org News Partner Science news on Phys.org
Simplicity is key to co-operative robots
Chemical vapor deposition used to grow atomic layer materials on top of each other
Earliest ancestor of land herbivores discovered
LCKurtz
LCKurtz is offline
#2
Mar22-11, 12:29 AM
HW Helper
Thanks
PF Gold
LCKurtz's Avatar
P: 7,177
Your picture shows a cone that is inscribed inside a sphere, not circumscribed outside as the problem asks.
Brown Arrow
#3
Mar22-11, 12:35 AM
P: 101
so is it suppose to be like this then i try to minimize the volume of the cone,
sorry i didn't get what it meant mean circumscribed , i though it would be inside
I like Serena
I like Serena is offline
#4
Mar22-11, 04:01 AM
HW Helper
I like Serena's Avatar
P: 6,189
Quote Quote by Brown Arrow View Post
N/A
Please help
Your calculation (given your drawing) is completely correct.
It's only your graphic interpretation with a parabola that is incorrect.
The volume is not given by a parabola but by a third power.
So the maximum volume is at h=32/3.
Btw, the volume becomes zero at h = 16, which is the solution for V=0.
LCKurtz
LCKurtz is offline
#5
Mar22-11, 11:51 AM
HW Helper
Thanks
PF Gold
LCKurtz's Avatar
P: 7,177
Yes. But your picture needs a little work. The bottom of the sphere would touch the center of the base of the cone.
Register to reply
Related Discussions
Does this answer make sense? Precalculus Mathematics Homework 4
Pressure volume curve for lung doesn't make sense? Biology 8
Does this answer make sense? Introductory Physics Homework 3
Minimum number of books I'd have to buy to make more sense of life? General Discussion 4
Yo-YO being pulled - does my Answer make Sense? Introductory Physics Homework 19
