Which Marble Bounces Higher, Steel on Steel or Steel on Glass?
  • Context: Undergrad
  • Thread starter Thread starter buffgilville
    Collisions
The discussion centers on the comparative bounce heights of a steel marble dropped on steel versus glass surfaces. It concludes that a steel marble will bounce higher on a steel plate due to the nature of elastic collisions and energy loss factors. Specifically, the marble tends to penetrate the glass rather than bounce, indicating a significant difference in energy transfer. The analysis emphasizes the importance of collision elasticity and the effects of deformation during impact.
  • Understanding of elastic and inelastic collisions
  • Familiarity with energy transfer principles
  • Knowledge of material properties, specifically steel and glass
  • Basic physics concepts related to projectile motion
  • Research the principles of elastic and inelastic collisions
  • Explore the concept of energy loss during collisions
  • Investigate the material properties of steel and glass regarding impact resistance
  • Learn about experimental methods for measuring bounce height and energy transfer
Physics students, materials scientists, and anyone interested in the dynamics of collisions and energy transfer in solid materials.
buffgilville
1) If you dropped a steel marble onto a steel plate and then dropped a steel marble onto a glass plate, which would you expect to bounce higher? Why?
2) Suppose that a projectile marble and target marble do not collide with their centers of mass equidistant from the floor. What problems in analyzing this experiment are caused by this non-ideal collision?
The steel on steel case.
Why?
Because the marble just went right through the glass instead of bouncing.
The reality is that it depends on how elastic the collision is. Energy losses occur if there is permanent deformation, if the deformation is converted into heat, or if there's is some residual deformation that recovers after the collision.
Suprisingly to most people, a pool ball bounces really well off a hard surface.
  • · Replies 19 ·
