Finding Velocity(Momentum related)
  • Thread starter Thread starter Exuro89
The discussion centers on calculating the velocity of a small ball after it collides with a larger ball that has been dropped and is rebounding elastically. The established conclusion is that the velocity of the small ball immediately after the collision is three times its initial velocity, expressed as V_B = 3V_b. Participants emphasize the importance of applying conservation of momentum (m1v1 = m2v2) and conservation of energy principles to derive the solution, particularly in scenarios involving elastic collisions.
  • Understanding of elastic collisions in physics
  • Knowledge of conservation of momentum principles
  • Familiarity with conservation of energy concepts
  • Basic algebra for solving equations
  • Study the principles of elastic collisions in detail
  • Learn how to apply conservation of momentum in multi-body systems
  • Explore conservation of energy in elastic collisions
  • Practice solving problems involving different mass ratios in collisions
Students studying physics, particularly those focusing on mechanics and collision theory, as well as educators seeking to enhance their teaching methods in these topics.
Exuro89
Suppose you hold a small ball in contact with, and directly over, the center of a large ball. If you then drop the small ball a short time after dropping the large ball, the small ball rebounds with surprising speed. To show the extreme case, ignore air resistance and suppose the large ball makes an elastic collision with the floor and then rebounds to make an elastic collision with the still-descending small ball. Just before the collision between the two balls, the large ball is moving upward with velocity and the small ball has velocity . (Do you see why?) Assume the large ball has a much greater mass than the small ball.
(a) What is the velocity of the small ball immediately after its collision with the large ball? (answer is V_B = 3V_b)
(b) From the answer to part (a), what is the ratio of the small ball's rebound distance to the distance it fell before the collision?
m1v1=m2v2
I'm really not sure how to start this out. Our professor gave us this answer to the first part of the problem but I'm not see how I can come to that conclusion. I'm really having an issue with there just being "large and small" masses and not specific values. How do I go about progressing in this problem? Thanks.
EDIT: I was told to find the consvervation of momentum and then find the conservation of energy to find the velocity of the smaller ball. So I would do MaVa = MbVb, solve for Va. Not sure how conservation of energy will be. Will it just be KEa + GPEa = KEb + GPEb?
show some attempt. Whatever you think just let us know.
  • · Replies 16 ·
