New Reply
Rigid Body - Linear (Center of Mass) motion/Rotational Motion
Share Thread Thread Tools
Mar25-11, 12:24 AM   #1
This is a very simple problem to state, yet I've not found any answers on PF or anywhere else online.
So let's say we have a simple rigid body like a rod. We apply an external force Fext for a fixed time dt to the rod in two different ways: (1) directly on the center of mass and (2) on the side of the rod. In both cases, we have the same motion of the center of mass, and hence the same kinetic energy associated with the center of mass. However, in (1) the rod does not rotate, whereas in (2) it does as we've applied a torque relative to the CM. So in (2) we have an extra kinetic energy of rotation in addition to the kinetic energy for the CM's motion. How is this possible, given that we applied the same force for the same time in the two instances? Doesn't this violate the fact that we did the same amount of work "input" in the two cases?
2. Relevant equations
Fext= MACM
T =0.5mv2
3. The attempt at a solution
N/A
Thanks for all the help.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Galaxies fed by funnels of fuel
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> Google eyes emerging markets networks
Mar25-11, 01:16 AM   #2
Homework Helper 2012
Recognitions:
Homework Helper Homework Help
The motion of a rigid body consist of a translation and a rotation about the CM. If the force exerted has nonzero torque about the CM the body will rotate. The work "input" equals to the change of KE, and it is translational KE + rotational KE so no "fact" is violated.
ehild
Mar25-11, 04:56 PM   #3
Okay, thanks, but suppose we don't invoke the work-kinetic energy theorem, and instead want to calculated the work "input" directly from the integral of F*dr. Then doesn't it seem like we've imparted the same amount of work to the rod since the "dr" in (1) and (2) are the same?
Also, we've imparted the same amount of momentum F*dt to the body. Doesn't this mean that their kinetic energies should be the same, since Kinetic Energy = p2/2m?
Mar26-11, 02:06 AM   #4
Recognitions:
The same work done on that rigid body will change the kinetic energy by equal amounts. But the kinetic energy includes both the translational KE 1/2 mV2 (V is the velocity of the centre of mass) and the rotational kinetic energy 1/2 Iω2 ( I is the moment of inerta and ω is the angular speed). The dr term in the work is the displacement of the point of attack of the force. It is not the same as the displacement of the CM in the second case.
If a body rolls down a slope the time it reaches the ground depends on the shape. A solid sphere will move faster than a hollow one in spite the equal works done by gravity in both cases.
The force acting for dt time changes the momentum by Fdt. If it has torque τ the angular momentum will change, too, by τdt.
ehild
Mar26-11, 10:43 PM   #5
Thanks, ehild. This has been revelatory.
Mar27-11, 12:33 AM   #6
Recognitions:
You are welcome :)
ehild
May3-11, 06:17 AM   #7
I had the same question in my mind. So based on what i could understand can i say that the force acted in case 2 will be more 'efficient' compared to force acted in case 1? Because it will create more total kinetic energy.
New Reply
Thread Tools
Similar Threads for: Rigid Body - Linear (Center of Mass) motion/Rotational Motion
Thread Forum Replies
Rigid body motion Introductory Physics Homework 3
Circular Motion, Center of Gravity, Rotational Motion Homework Help Introductory Physics Homework 1
rigid body solid: center of mass and tendency to topple Introductory Physics Homework 1
center of mass of a rigid body-sphere Introductory Physics Homework 11
Rigid Body Rotational Motion Introductory Physics Homework 2
