Need help with a physics practical to do with slingshots?
The discussion revolves around a physics practical project involving slingshots, where the original poster seeks ideas for variables to investigate in relation to physics concepts such as potential energy and kinetic energy.
  • Exploratory, Conceptual clarification, Problem interpretation
  • Participants suggest various variables to change, including the angle of launch and the elasticity of the rubber band. There is discussion about measuring potential energy and the speed of the stone as it leaves the slingshot.
The conversation is ongoing, with participants providing suggestions and exploring different angles of investigation. Some guidance has been offered regarding the effects of angle on distance and height, but there is no explicit consensus on the best approach yet.
There are constraints regarding the complexity of the project, as it needs to meet A-level standards, and some participants express concerns about the predictability of certain experiments.
obi1
Need help with a physics practical to do with slingshots!?
Basically I am doing a project on slingshots, we are allowed to investigate any areas do do with physics, however I need some ideas, I was hoping I could change a couple of variables and measure things.
my idea was to change the density of the rubber band used in the sligshot and measure the potential energy, then work out the speed of the stone as it leaves the slingshot using KE=1/2 MV^2
But I feel that's not enough
Please can someone help me to find other PHYSICS area which I could investigate.
try changing angle of launch, initial speed, density of air (not possible though), ... but yes you can change volume of ball keeping mass same for the last one
to change the initial speed i would have to pull the rubber band more longer right, but the problems with that is that its no easy to do, the practical has to be up to Alevel standards :(
its necessary to use sling shot?
Do one thing ... get different rubbers of different elasticity ... use an apparatus so that each time rubber is pulled to same distance ... that way initial velocity will change
yh that's what I've been doing today lol, but my teacher said that that's to simple and predictable because it obvious that the more elastic the rubber band and more stretched the further the object will travel.
so show him how angle affects distance and height
(Hint: height is max at 90 and distance traveled at 45 ... ... ...shhhhh)
also show him that any angle θ from vertical or horizontal has same distance traveled but different height (except for 45)
ohh sounds great, will try that out on Monday, thanks for your help! :)
  • · Replies 35 ·
16K
23K
  • · Replies 18 ·
