Calculate Mass of Eri B & C: Solar Mass Ratio
The discussion revolves around calculating the masses of two stars, Eri B and Eri C, in the Eridani system, using their orbital characteristics and distance measurements. The problem involves concepts from celestial mechanics and gravitational interactions.
  • Participants explore the use of Kepler's third law to determine the reduced mass of the system. There is confusion about integrating the parallax measurement and the distance ratio into the calculations. Some participants question the correct application of the reduced mass formula and its relationship to the center of mass.
The discussion is active, with participants sharing their attempts and clarifying concepts. Some guidance has been provided regarding the application of Kepler's laws and the definition of reduced mass, but there is still uncertainty about how to incorporate all given parameters into the solution.
Participants are navigating constraints related to the definitions and relationships between the stars' distances, masses, and the implications of the parallax measurement. There is an acknowledgment of potential misunderstandings regarding the formulas involved.
mjolnir80
we are looking at two stars in the eridani system, eri B and eri C. the period of the system is 247.9 years. the system's measured trigonometric parallax is 0.201 arcseconds and the tru angular extent to the semimajor axis of the reduced mass is 6.89". the ratio of distances of eri b and c from the center of mass is ab/ac= 0.37. what is the mass of Eri B and C in terms of the mass of the sun?
MbRb + McRc / Mb+ Mc
im kind of confused about how to start this off. i thought about using the distance of both the stars from the sun as the reference point for the formula but that doesn't really work. If anyone could give me a rough idea of what direction to go with this problem i would really appreciate it
I think the easiest way to start off is to use the modern version of Kepler's third law to find the system's reduced mass. You can then find the masses of the two components quite easily.
ok so i got the reduced mass
now i know that the formula for reduced mass is m1 + m2 / m1m2 but i don't really know where to go from here
what I am having trouble understanding is where the parallax and ratio of distances comes in
How did you get the reduced mass without using the parallax? Kepler's third law is a relationship between mass, period, and semi-major axis. I don't see how you got mass without knowing the semi-major axis.
Supposing your reduced mass is correct, you know that from the definition of the center of mass, Mb*a_b=Mc*a_c. You also know the ratio between a_b and a_c.
P.S. reduced mass is m1*m2/(m1+m2), not (m1+m2)/m1m2
thanks for the help
i used P^2/a^3 = 4 pi^2/ MG to get the mass
  • · Replies 0 ·
