| New Reply |
If light has no weight, how can it push objects? |
Share Thread | Thread Tools |
| Mar31-11, 11:53 AM | #35 |
Mentor
| Mar31-11, 12:00 PM | #36 |
| Mar31-11, 12:07 PM | #37 |
Recognitions:
What we have is 'rest mass' which is 0. And 'relativistic mass' which is E/c2. |
| Mar31-11, 12:09 PM | #38 |
| Mar31-11, 12:30 PM | #39 |
Can somebody explain to an ignorant lay man: where is gone mass of electron and positron in their proces of so called " annihilation "? plus what about magnetic property of electron, from where it come? I will be very gratefull.
mquirce |
| Mar31-11, 12:43 PM | #40 |
Mentor
Relativistic mass is just a synonym for energy. So what value does the concept add? |
| Mar31-11, 12:46 PM | #41 |
Mentor
http://www.physicsforums.com/showpos...3&postcount=56 Note that the mass of a system is not equal to the sum of the masses of the consitutent particles. |
| Mar31-11, 01:50 PM | #42 |
Recognitions:
| Mar31-11, 01:58 PM | #43 |
Sorry for my stupidity, but i don,t understand sentence ' invariant mass of photon photon, and the meaning of summa of masses. If i bother you live with no more.
mquirce. |
| Mar31-11, 05:07 PM | #44 |
| Apr1-11, 04:38 PM | #45 |
Recognitions:
If it matters what you mean, it needs to be specified if it's not clear from the context. In non-relativistic contexts it doesn't matter what you mean when you mention "mass". Otherwise it needs to be specified. I guess I've been neglecting to be clear myself, using the word "mass" for "relativistic mass". My apologies for that - I'll be more careful. What does the concept of "relativistic mass" add? Well, for instance, you can predict the effect of a gravitational lens on photons. Or you can predict how much photons add to dark matter mass. Or you can say something about conservation of momentum in relativistic situations since you can't really ignore "mass-less" photons in quantum physical reactions. If I've insulted you somehow, please enlighten me. Otherwise accept my apologies for it was not my intention to insult anyone. |
| Apr1-11, 05:46 PM | #46 |
| Apr1-11, 06:12 PM | #47 |
Mentor
This discussion of the intrinsic mass of a collection of photons has diverted this thread from the original question. The intrinsic mass of a single photon is identically zero. The momentum of a single photon is not zero. It is instead given by p=hf/c=h/λ where h is Planck's constant, f is the photon's frequency, and λ is its wavelength. I like Serena, you have used E=mc2 multiple times in this thread. A much better version of this equation is [tex]E^2 = (m_0c)^2 + (pc)^2[/tex] where m0 is the rest mass and p is momentum. For photons, which have a rest mass of zero, this reduces to E=pc. No mention of mass whatsoever. |
| Apr1-11, 06:39 PM | #48 |
Recognitions:
Can you say how much Newton is "off"? So how about the contribution of photons to the known mass in the universe? |
| Apr1-11, 06:45 PM | #49 |
Recognitions:
My point is mainly that it is a matter of perspective. Afaik both forms are true, or in other words, it's "relative", which is what relativity theory is all about. |
| Jun22-11, 04:41 AM | #50 |
In plain english a photon has momentum because of the energy it carries. If it loses ALL of that energy then there is no photon, therefore it is massless. Some may argue that a virtual photon remains, but it is still massless.
| Sep21-11, 02:24 AM | #51 |
"Light, photons, is an electromagnetic field which exerts force on charges --> Push objects."
OK, I understand this. The light is an electromagnetic field, and the electromagnetic field interacts with the electrons, and the protons of the material, pushing them back and forth. But why would that push the solar sail away from the light source? The electrons (and protons) are going to vibrate perpendicularly to the direction of the ray of light that shines on the sail, right?, because the magnetic and electric fields of the light ray are perpendicular to the direction the light ray is traveling. The 'pressure' on the electron would be back and forth perpendicularly to the direction the light ray is traveling. I see that causing heat, warming up the sail. But, how does that cause the sail to move away from the light source? |
| New Reply |
| Tags |
| light, mass, momentum, wtf |
| Thread Tools | |
Similar Threads for: If light has no weight, how can it push objects?
| Push-up as Lever - How Much Weight Moved? | General Physics | 10 | ||
| Why the black objects absorb more light and heat from the other color objects? | General Physics | 27 | ||
| push weight question | Classical Physics | 4 | ||
| Push up weight distrubtion problem | Introductory Physics Homework | 1 | ||
| Can you push down more than your weight? | General Physics | 33 | ||
