Physics Hwk. problem: Conservation of Linear Momentum
The discussion revolves around a problem in the context of conservation of linear momentum, specifically involving a swimmer running off a raft and the resulting recoil velocity of the raft.
  • Exploratory, Assumption checking, Mathematical reasoning
  • The original poster attempts to apply a momentum conservation equation but questions its correctness after receiving an unexpected result. Other participants confirm the equation's validity and inquire about the original poster's answer.
Participants are actively discussing the application of the conservation of momentum principle. Some guidance has been offered regarding potential issues with significant figures in the answer provided by the original poster.
There is mention of different raft weights in similar problems, which may influence the interpretation of the situation. The original poster's answer is questioned in the context of rounding and significant figures.
shawonna23
55 kg swimmer is standing on a stationary 225 kg floating raft. The swimmer then runs off the raft horizontally with a velocity of +4.4 m/s relative to the shore. Find the recoil velocity that the raft would have if there were no friction and resistance due to the water.
I used the equation vf2=-m1*vf1 divided by m2, but the answer is wrong. Did I use the wrong equation? Please Help!
Hey I had this same homework problem. Almost exactly infact. The only thing different is your raft weighs 225kg and mine weighed 230kg. And I got the problem correct so I think I can help you.
The equation you are using is correct. What was your answer?
Physics Hwk. Problem: Conservation of Linear Momentum
Thanks, the answer i got is -1.08.
That should be the correct answer then. Unless your using webassign and it requires 3 significant digits. Then you are rounding too soon.
  • · Replies 18 ·
18K
  • · Replies 31 ·
  • · Replies 62 ·
14K
18K
  • · Replies 19 ·
