Spring cannon question involving conservation of energy.
The discussion revolves around calculating the necessary compression of a spring in a cannon to hit a target box located 2.2 meters away. The spring is initially compressed by 1.1 cm, but the marble falls short by 27 cm. Key equations include the kinetic energy formula (Ke = (1/2)mv^2) and the elastic potential energy formula (ePe = (1/2)kx^2). The solution requires determining the spring constant and utilizing kinematic equations, emphasizing the importance of making assumptions about the trajectory and launch angle.
  • Understanding of kinetic energy and elastic potential energy concepts
  • Familiarity with the conservation of mechanical energy principle
  • Knowledge of kinematic equations for projectile motion
  • Basic algebraic manipulation and symbolic reasoning skills
  • Learn how to calculate spring constants using Hooke's Law
  • Study projectile motion and its kinematic equations in detail
  • Explore energy conservation principles in mechanical systems
  • Investigate the effects of launch angles on projectile trajectories
Students in physics, educators teaching mechanics, and anyone interested in understanding energy conservation in projectile motion scenarios.
MrMagoo22
Two children are playing a game in which they try to hit a small box on the floor with a marble fired from a spring-loaded cannon mounted on a table. The target box is 2.2m horizontally away from the edge of the table. The spring is compressed 1.1cm, but the ball falls short of the box by 27cm. How far does the spring need to be compressed to hit the box directly? It is assumed that friction will not affect this problem.
Kinetic Energy: Ke = (1/2)mv^2
Elastic Potential Energy: ePe = (1/2)kx^2
Conservation of Mechanical Energy: Pe = -Ke
Kinematic Equations:
X = ViT + (1/2)at^2
Started working with elastic potential energy first, realizing that I'd need to know the spring constant to get the potential energy, which would lead to the answer:
ePe = (1/2)k(0.011)
ePe = -Ke = -1/2mv^2
(.0055)k = (-1/2)mv^2
Wasn't working out past that point, too many unknowns, so I tried working with the trajectory of the shot with kinematics to get the initial velocity of the shot and work back:
Vix =
Vx =
Ax = 0
X = 1.92
T =
Viy = 0
Vy =
Ay = -9.81
Y =
None of the kinematics worked off that small amount of information, so I was stuck again. It feels like there isn't enough information available to get an actual answer (no mass for ball, no table height, no spring constant, really any of those would help.) but I may be overlooking something.
Try putting away your calculator until the very end and work symbolically. You will find that all the unknown values can be lumped together into a single constant, and that you won't even need that if you set up a ratio at the end (a bit like using PV = nRT to find changes in pressure and volume).
You'll have to make certain assumptions about the trajectory (for example, you might assume that the launch angle is horizontal, and that the table height is fixed at some value, say h).
  • · Replies 22 ·
  • · Replies 20 ·
