How Do You Convert 2-Axis Rotation to 3-Axis Lift for a Disc?
  • Thread starter Thread starter dav_i
    Lift Rotation
This discussion focuses on converting 2-axis rotation (tilt in the x-direction \(\theta_x\) and y-direction \(\theta_y\)) into 3-axis lift for a disc mounted on three vertical pistons. The solution involves calculating the angles \(\alpha\) and \(\beta\) based on the tilt angles and the angle \(\Omega\) from the x-axis. The final approach requires measuring the average height of the three pistons and adjusting their heights accordingly to maintain the disc's center at a constant elevation.
  • Understanding of trigonometric functions and their applications in physics.
  • Familiarity with rotational dynamics and angular measurements.
  • Knowledge of basic geometry related to circular motion.
  • Ability to perform calculations involving multiple variables and constraints.
  • Study the principles of rotational dynamics in mechanical systems.
  • Learn about trigonometric transformations in 3D space.
  • Explore methods for maintaining equilibrium in multi-point support systems.
  • Investigate advanced techniques in robotic control for precise height adjustments.
Engineers, physicists, and students involved in robotics, mechanical design, or any field requiring precise control of multi-axis systems will benefit from this discussion.
dav_i
Hi there,
In my experiment I have a disc which needs to be pitched and rolled about it's centre. The disk is mounted by three vertical "pistons" one every 120degrees. I need to convert a tilt in the x-direction [tex]\theta_x[/tex] and a tilt in the y-direction [tex]\theta_y[/tex] to how much each piston should be raised and lowered by. An additional constraint is that the centre of the disc must stay at the same height.
I've been bashing my head against a wall with this for what seems like forever and any help will be appreciated...
We name the positioners A, B and C at height [tex]z_{a,b,c}[/tex] and the angle from origin O to A is [tex]\alpha[/tex] O to B as [tex]\beta[/tex] and O to C [tex]\gamma[/tex].
The direction O to A is at an angle of [tex]\Omega[/tex] to the x-axis.
The length of O to A is r.
I figured out that
[tex]\alpha = \theta_x\cos\Omega + \frac{\sqrt{3}}{3}\sin\Omega+ \theta_y\frac{\sqrt{3}}{3}\cos\Omega-\theta_y\sin\Omega[/tex]
and
[tex]\beta = \theta_x 2 \frac{\sqrt{3}}{3} \sin \Omega + \theta_y 2 \frac{\sqrt{3}}{3} \cos\Omega[/tex]
From here I get stuck: I've tried many things but I know they're wrong (as in my experiment it doesn't work properly!)
Any help please, thanks in advance
Solution found!
Measure the average height of the three points.
Use trig to move z_a and z_b.
Remeasure average height.
Move z_a, z_b and z_c all the difference between the two.
  • · Replies 95 ·
