What is the solution to the Maths Olympiad problem involving sine?
  • Context: Undergrad
  • Thread starter Thread starter Gotcha
    Math olympiad Olympiad
The discussion revolves around a Maths Olympiad problem involving the summation of sine values from 1 to 90 degrees. Participants explore various methods to solve or approximate the sum without the use of a calculator, delving into mathematical techniques and reasoning.
  • One participant presents the problem and requests assistance in solving the sum of sine values from 1 to 90 degrees.
  • Another suggests using the sine addition formula and properties of sine to simplify the problem.
  • Some participants propose using Euler's formula and complex numbers to derive a general formula for the sum.
  • A different approach involves approximating the sum using integrals, with one participant suggesting that the integral provides a close approximation.
  • Concerns are raised about the accuracy of the integral approximation, with suggestions for averaging upper and lower sums to improve the estimate.
  • Multiple participants express uncertainty about the methods proposed and seek clarification on the steps involved.
  • There is a discussion about whether the problem requires an exact solution or if an approximation is acceptable, with differing opinions on the expectations of the Olympiad format.
  • Some participants challenge the algebraic manipulations presented, leading to further clarification and corrections of earlier statements.
Participants do not reach a consensus on the best method to solve the problem or the nature of the expected answer. Multiple competing views and methods remain, with ongoing debate about the validity and effectiveness of each approach.
Some methods rely on complex numbers and series, which may not be accessible to all participants. The discussion also highlights the potential for approximation versus exact evaluation, which remains unresolved.
Readers interested in mathematical problem-solving, particularly in the context of competitive mathematics or Olympiad-style questions, may find the various approaches and discussions valuable.
Gotcha
The following is a problem I got in a Maths Olympiad, I had to solve it without a calculator, although I couldn't solve it:
sin 1 + sin 2 + sin 3 + ... + sin 90
If anyone could show me how to solve this I would really appreciate it.
Mathematics news on Phys.org
write sin(n) = sin(1)cos(n-1)+cos(1)sin(n-1), and use the fact that sin(x) = cos(90-x) and you're done.
I don't know will this method work ,
but i will try to find
(sin 1 + sin 2 + sin 3 + ... + sin 90)(cos 1)
= (sin 1)(cos 1) + (sin 2)(cos 1) + (sin 3)(cos 1) + ... + (sin 90)(cos 1)
or (sin 1 + sin 2 + sin 3 + ... + sin 90)(sin 1)
this is just a suggection , may not work. :smile:
Or simply use euler's rule
and u r done
-- AI
There is another way to do this, but you have to know how to use complex numbers, series, etc. It gives you a general formula.
Basically, you can say that this is a sum from 1 to N of sin(n). This is hard in itself to evaluate, so you use Euler's formula where e^(i*x)=cos(x)+i*sin(x). You then use the sum from 1 to N of e^(i*n*x) which is a geometric series. The nth sum is then equal to (1-e^iN*x)/(1-e^i*x).
If you can get this far, figure out a way to rewrite the (1-e^iN*x)/(1-e^i*x) so that it looks like a different function. If you have no idea what I'm talking about (I don't know what level math olympiad is at), I don't know method without using complex numbers/series/functions.
Are you sure they didn't ask you merely to approximate it rather than actually solve it exactly?
I've got a feeling that they are expecting you to realize that it is a close approximation to,
[tex]180/\pi \, \int_{0}^{\pi/2}\sin(x) \,dx = 180/\pi[/tex]
or numerically about 57.
Actually that integral (above) is an ok approximation but not all that good because it's just an upper sum. It would be a lot closer if you averaged the upper and lower sums as in
Integral ~= 1/2 { (sin 0 + sin 1 + ... sin 89) + (sin 1 + sin 2 + ..sin 90) }
= 1/2 { S -1 + S} = S - 1/2
So a better approximation to the given Sum (S) would be,
[tex]S \simeq 180/\pi \, \int_{0}^{\pi/2}\sin(x) \,dx + 1/2 = 180/\pi +1/2[/tex]
I don't really understand how you arrived at that, and how it'd help solve the problem. Can you please elaborate?
All of this stuff is great, thanks guys!
This still doesn't solve the problem without the use of a calculator ...
except if you can calculate the sines of numbers in your head!
For other people who might not be aware, maths olympiad questions are multiple choice.
Perhaps if you posted the options we might be able to help you decide which decimal answer was the most likely.
I'd presumed that the possible answers were in exact forms.
As for devious:
sin(n)=sin(n-1+1) = sin(n-1)cos(1) + sin(1)cos(n-1)
Let S be the original sum, then
S= sin(1)(1+cos(1)+cos(2)+cos(3)+...+cos(89)) + cos(1)(sin(1)+sin(2)+..+sin(89))
S=sin(1)S + cos(1)S - cos(1)
since the sums of the cos's is the same as the sum of the sin's.
from which we can find S.
This was a 3rd round maths olympiad, and it wasn't multiple choice.
Ah, sorry. thought it was one of the first two.
DId it explicitly ask you to work out the decimal expansion of the sum, or evaluate it? surely an exact solution involving sin(1) and cos(1) is far better than any decimal expansion? This is the Olympiad, so I'd presume it uses proper mathematical standards ie an answer of 2pi is written and not "6.28 to 2 dp", and hence that the solutions offered here which are 'exact' constitute the one that they wanted.
I'm looking at this and I think that the way to handle this is the way I above mentioned.
If you follow the steps above, you get the value (1-e^iN*x)/(1-e^i*x).
This can then be factored into (you take e^(iN*x/2) out of the top and e^(i*x/2) out of the bottom)
e^( iN*x/2 ) * ( e^(-iN*x/2) - e^(iN*x/2) ) / ( e^(ix/2) * ( e^(-ix/2) - e^(ix/2) )
Recognize that e^(-iN*x/2) - e^(iN*x/2) is = -2i*sin(Nx/2) and that e^(-ix/2) - e^(ix/2) = -2i*sin(x/2)
Also, this was a combined expansion of cos(nx)+isin(nx) so the value for sin(nx) will be the imaginary part of the above.
You get:
sum sin(nx)= sin(Nx/2)/sin(x/2) * sin((N-1)x/2)
Plugging in N=90 and x=1, you get the value 56.7943 (using degrees not radians), the same as mentioned above, and you now have a general formula for all problems of this type.
I don't think the value needs to evaluated ...
if one gets sin(pi/35) as an answer , that's an answer enough ...
(if u catch my drift...)
-- AI
I don't really get this one. :shy:
Shouldn't it be: S= sin(1)S + cos(1)S + sin(1)?
cos(1)[sin(1)+sin(2)+..+sin(89)]
=cos(1)[sin(1)+sin(2)+..+sin(89)+ sin(90) - sin(90)]
=cos(1)[S - sin(90)]
=cos(1)[S - 1]
=cos(1)S - cos(1)
if I'm right
:-p
=cos(1)[S - 1]
=cos(1)S - cos(1)
if I'm right
:-p
You are. I messed up some stuff when I typed it out. :approve:
  • · Replies 18 ·
