Spring equation proof and work question
  • Context: Graduate
  • Thread starter Thread starter gaborfk
    Proof Spring Work
The discussion revolves around a physics problem involving a particle attached between two identical springs on a frictionless table. Participants are tasked with deriving the force exerted by the springs when the particle is displaced and calculating the work done in moving the particle from one position to another. The scope includes theoretical reasoning and mathematical formulation.
  • Homework-related
  • One participant notes that the factor of 2 in the force equation arises from the presence of two springs.
  • Another participant suggests that the term L/(sqrt(x^2+L^2)) represents the sine of the angle between a spring and the vertical, indicating a relationship to the geometry of the setup.
  • A participant expresses confusion about the origin of the (1-) term in the force equation and seeks clarification on how to combine the components of the equation.
  • Regarding the work done, one participant proposes that integration should be performed from x=A to x=0 to find the total work done by the force.
  • Another participant acknowledges the cancellation of vertical components of the forces, which contributes to the net force acting on the particle.
  • A later reply requests a step-by-step explanation for solving both parts of the problem, indicating ongoing uncertainty about the approach.
Participants express varying levels of understanding and confusion regarding the problem. There is no consensus on the derivation of the force equation or the method for calculating work, indicating that multiple competing views and uncertainties remain.
Some assumptions about the geometry and forces involved may not be fully articulated, and the discussion does not resolve the mathematical steps necessary for deriving the force or calculating the work done.
Students or individuals interested in mechanics, particularly those studying spring dynamics and force calculations in physics problems.
gaborfk
A particle is attached between two identical springs on a horizontal frictionless table. Both springs have spring constant k and are initially unstressed.
-------A---
a) If the particle is pulled a distance x along a direction perpendicular to the initial configuration of the spring, show that the force exerted by the springs on the particle F=-2kx(1-L/(sqrt(x^2+L^2)))i (where L is the vertical distance of each spring at rest)
b) Determine the amount of work done by this force in moving the particle from x=A to x=0
On part a)
I got that the 2 is there since there are two springs. The L/(sqrt(x^2+L^2) is the sin of the angle between the a spring and the vertical. Where does the (1-) comes from? Also how do I tie the equation together, after figuring out all the parts?
On part b)
Do I have to integrate f(x) as x=A goes to x=0?
Thank you
Calculate the stretch of one spring from its equilibrium length of L. (This is where you'll see the "1-" term.)
Only the horizontal component of that force survives in the net force.
Thank You ! I did not realize that the vertical components cancel out!
Bye
Need Explanation
I still don't understand how the problem will work... could you explain with a few steps how to solve both parts? :redface:
  • · Replies 27 ·
