Hypnotoad
- 35
Complex conjugates (new question in 1st post)
I have a couple questions on complex variables:
1.)If you have a complex function defined as follows:
[tex]f(z)=u(x,y)+iv(x,y)[/tex]
with x,y real, what do you get if you take the complex conjugate of the variable z?
[tex]f(z^*)=?[/tex]
I was thinking that it wouldn't change since the complex variable has been replaced with two real variables, but that doesn't seem right.
If I take the conjugate of the entire function, is this what I should get:
[tex]f^*(z)=u(x,y)-iv(x,y)[/tex]
2.) If you are trying to prove that a function is not analytic at a specific point, is it sufficient to show that the Cauchy-Riemann conditions do not hold? I'm trying to show that the derivative of a function at zero is dependent on the direction that you approach zero. I've shown that the C-R conditions are not met, but I'm not sure how to show explicitly for that point that they are not met.
EDIT: NEW QUESTION
I figured I would just edit this topic instead of starting a new one. I'm trying to prove that if a function [tex]f(z)[/tex] is analytic then the function [tex]f^{*}(z^{*})[/tex] is also analytic.
I'm not sure how to get this started. It makes sense that taking the conjugate wouldn't affect the differentiability, but I don't know how to prove that. Any hints on how to get this problem started?
[tex]f(z^*)=?[/tex]
EDIT: NEW QUESTION
