How does Changing Salt Bridge Solution affect observed voltages?
Changing the salt bridge solution from Potassium nitrate to Zinc nitrate affects the observed cell potentials in electrochemical cells, particularly those involving Zn2+ ions. The reduction potential of Zn2+ is +0.76 V, which influences the potential difference depending on its position as either anode or cathode. If Zn2+ is the anode, the potential difference increases; if it is the cathode, the potential difference decreases. The resistance of the salt bridge solution also plays a critical role in the overall cell performance.
  • Understanding of electrochemical cells and half-cell reactions
  • Familiarity with standard reduction potentials
  • Knowledge of salt bridge functions in electrochemistry
  • Basic concepts of electrical resistance in solutions
  • Research the impact of different salt bridge solutions on electrochemical cell performance
  • Learn about the Nernst equation and its application in calculating cell potentials
  • Explore the effects of ionic strength on electrode reactions
  • Investigate the role of resistance in electrochemical systems and how to measure it
Chemistry students, electrochemists, and anyone studying or working with electrochemical cells and their performance metrics.
faradayslaw
In a lab in which many half-cells are constructed, one of which contains Zn2+, the original salt bridge solution is Potassium nitrate. Suppose we needed to change this solution to Zinc nitrate. What would be the effect on the observed cell potentials?
Reduction Potential of Zn2+ = +0.76 V
Ecell=Ecathode-Eanode
So it seemed at first that the observed voltages would not be altered in all half cells except that with the Zn 2+ ions, since the Zn 2+ ions are not involved in the half-cell reactions, but on the other hand, the high reduction potential of Zn2+ may lead to Zn2+ reducing, rather than the actual metal cations in the anode.
Moreover, for the Zn2+ half cell, the potential difference would increase if the Zn2+ was the anode, and would decrease if Zn2+ was in the cathode.
Please let me know if this is the correct way to think about the problem
Thanks,
Salt bridge doesn't change electrode reactions, however, different solution may have different resistance.
