Help with acceleration on incline
The problem involves a block resting on an inclined plane that is accelerating to the right. The incline makes an angle of 28° with the horizontal, and the block is held in place by static friction. The objective is to determine the minimum acceleration required for the block to slide down the incline.
  • Participants discuss the forces acting on the block, including static friction, normal force, and weight. There are attempts to apply Newton's second law and to draw free body diagrams. Questions arise regarding the setup of coordinate axes and the components of forces.
Several participants are actively working through the problem, re-evaluating their equations and the components of forces. There is a mix of confusion and progress as they clarify the roles of different forces and the angles involved. Some guidance has been offered regarding the correct application of trigonometric functions and the breakdown of forces.
Participants express uncertainty about the angles used in their calculations and the relationship between the components of the forces. There is also mention of the need to consider the specific conditions of the inclined plane, which affects the normal force and friction calculations.
jhson114
An inclined plane that makes an angle of 28° to the horizontal is mounted on wheels. A small block of mass m = 1.3 kg rests on the plane, held there by a coefficient of static friction µ = 0.7.
The plane is accelerating to the right. What is the minimum acceleration in order that the block slides down the plane?
I'm confused on where to even start. help please
Because coefficient of static friction=F x R(normal reaction),hence
0.7=F x mg
Force = 0.7/mg
=0.055 N
You say the plane is accelerating to the right, what is the plane acceleration ?
Newton's 2nd law
Draw a diagram of the mass showing all the forces on it. (There are three forces acting.) Now consider the conditions just before the mass starts to slide down the plane: The vertical forces are in equilibrium; the horizontal forces must produce an acceleration. Apply Newton's 2nd law and solve for the acceleration.
i drew fbd, and set x-axis in the direction of the acceleration, and y-axis straight up.
Then i applied the Newtons second law, and this is what i got.
ma = fs - mg(cosx)
1.3a = 0.055 - (1.3*9.8*cos28)
when i solve for a, i get a negative number.
i can't figure out what went wrong.
I don't know what that equation represents.
Do it step by step:
(1) Identify all the forces on the mass.
(2) Write the equation for vertical equilibrium.
(3) Apply Newton's 2nd law for the horizontal force components.
Combine the equations from (2) and (3) and solve for "a".
for vertical, i got this: F (force y) = N (normal) - W(weight)SinX
for horizontal, i got : F (force x) = fs(static friction) - W(weight)CosX
i replaced F with MA (mass x acc) and tried solving it. this is what i did for the previous post.
you have you axes tilted...so with that tilted axis, you have accelertaion going in both the x and y directions...use a straight axes (were x is in the direction of acceleration)...that way you have acceleration in only one direction
As Spectre5 notes, you need to analyze vertical and horizontal components, not components perpendicular and parallel to the surface.
The three forces that I see are: normal force, static friction, and weight. All three have vertical components. (Note that since we are finding the point at which the mass just overcomes the static friction, that friction force must equal [itex]\mu N[/itex].) Similarly, the normal force and friction both have horizontal components.
Redo your equations.
is the frictional force for x component and y component equal in magnitude?
i reworked the equations as stated above and this is what i got:
Fy(force y) = fs(static fric y) + Ny (normal y) - W(weight)cosX
Fx(force x) = fs (static fric x) + Nx (normal x)
im kind of getting it but still alittle confused on how to calculate Ny and Nx and whether static friction force for y component and x components are equal.
man i suck at this :(
You are not taking full advantage of the given information. The only things you don't know are N and a; all else is given (mass, [itex]\theta[/itex], [itex]\mu[/itex]). Use this information to find the vertical and horizontal components of the three forces.
For example. The normal force, N, has a vertical component of [itex]N cos\theta[/itex] and a horizontal component of [itex]-N sin\theta[/itex]. Due a similar component breakdown for the friction force ([itex]\mu N[/itex]) and the weight (mg).
Now redo your equations once again. Don't give up.
one more question. the angle for feta always going to be 28 degrees for all components?
isnt the vertical component Nsine(feta) and horizontal Ncos(feta)?
Draw a picture and figure it out. Remember that [itex]sin(28) = cos(62)[/itex], etc.
I was using [itex]\theta = 28[/itex]; sorry if that was confusing.
this is the final equation i was able to come up with.
Fx = f*cos(feta) - N*cos(feta)
Fy = f*sine(feta) + N*sine(feta) - W (W=mass*gravity)
is this correct? you said above that for horizontal it should be sine, and vertical cos, but i don't understand this. i think it should be other way around.
oh i see what you did. yeah that was alittle confusing. anyways does my equations look okay?
dang it. its still wrong. i sux. :(
Fx = Mass*A
Fy = 0
for friction i used 28degrees as feta
for normal i used 62 degrees as feta
i get negative number for an answer.
Rather than use [itex]\theta[/itex], specify the particular angle you mean. It doesn't matter whether you use sin(28) or cos(62), but you need to specify the angle you are using. And instead of f, put what it equals [itex]f = \mu N[/itex]; same for W, use [itex]w = mg[/itex].
Woo hoo! i got it! 1.2! Yeah baby. haha.
What i was doing wrong was for f, i was using the value that other guy posted but he calculated it thinking it was flat on the ground therefore he subsituted N as m*g. But that wasnt the case here because it was slanted. wow. tough stuff. thanks DocAl :)
  • · Replies 19 ·
  • · Replies 27 ·
