New Reply
Geese dynamics
Share Thread Thread Tools
Apr4-11, 03:01 PM   #1
Recognitions:
Gold Membership Gold Member
Geese dynamics
So today I practiced 8fps (frames per second) tracking on a local greylag geese colony. Then you get this:
I guess from the shift in the background you could estimate the take off speed of this formation flight. The total series is 12 frames in RAW + small jpg then the buffer was full.
Unfiortunately because the left goose was also the "bravo" in the formation, he is partly shielded off in most frames. The only real keeper is the fifth frame (the second frame is not tack sharp):
Spring is a bit early here:
while at the other side of the pond, I saw a rendezvous in the flowers:
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Ants and carnivorous plants conspire for mutualistic feeding
>> Forecast for Titan: Wild weather could be ahead
>> Researchers stitch defects into the world's thinnest semiconductor
Apr4-11, 06:25 PM   #2
Recognitions:
Awesome!
Apr4-11, 06:28 PM   #3
Mentor
Very nice !
Apr5-11, 10:33 AM   #4
Recognitions:
Geese dynamics
Thanks Andy and Lisa,
Well maybe to share some more. I did that series of the geese in take off in manual mode but with ISO in auto. That way I could select the aperture one click closed (F6.0), to improve it's sharpness, getting closer to the sweet spot, which is pretty important at max zoom 300mm. And I could get a reasonable short shutter speed, freezing the action (1/750 s). This way the ISO would adjust for a correct exposure. However I made those settings earlier in a somewhat brighter setting, and that would give me ISO 200-800. As it turned out however, this series was shot with the sun out and I got ISO 3200 instead.
The problem with that is noise. The signal to noise ration decreases under sensitive ISO settings and the result is shown in the upper frame here, with a 100% crop (RAW unadjusted for anything).
The lower frame shows what noise reduction does, I tried several settings with DPP manually for chroma and luminance noise reduction and ended up with both on 6 out of 20 increments. which is quite different from the default setting.
However you can also clearly see the loss of texture caused by the noise reduction, especially in the goose's cheek.
Ah well Photography is always a game of finding the best compromise.
Apr5-11, 11:36 PM   #5
Recognitions:
Those are beautiful! I like the bees too. Little E really just focused in on her first bee-watching experience two days ago, when a large bumblebee was checking out a bush outside our front window. She liked that it would dart around and then hover, and then dart around more. Once it put its legs down and looked like it would land, but decided not to do so.
Apr6-11, 02:37 PM   #6
Recognitions:
Nice, yes nature is waking up rapidly
Anyway I went back today, beautiful weather and captured several air movements. The next sequence explains partly a bit why the EOS 7D is roughly twice as expensive than the EOS 550D
All shots are in a 8 frame pes second sequence, 25% of the small jpg output, the inserted crops are 100% size of the small jpg, but on the raw files they are double that size:
The 7D not only focusses incredibly fast but it also predicts where the moving subject will be at the moment the frame is taken and it even does that in memory mode when the subject is moving out of the sensor area in the center as can be seen on the last pic.
Apr6-11, 04:25 PM   #7
Recognitions:
Anyway some of todays catch, after raw processing,. reduced to 25% and then cropped.
Apr6-11, 10:19 PM   #8
Those pictures are killer. Andre, how long did it take you to learn how to take pictures like that? I'm still figuring out how to use my FZ-40.
Apr7-11, 03:15 AM   #9
Recognitions:
Quote by Topher925 View Post
By practicing tracking of moving objects, I guess and knowing the hardware. Birds in flight (BIF) also requires hardware that is up to that. And thrashing some 200 pictures of the 220 I shot in that hour, keeping only the best.
The FZ-40 is a fine camera, outzooming my set considerably, I know it's early predessessors, the FZ-8 and FZ-18, but the lack of speed in focussing and frame repetition frequency makes getting results like this a bit hard.
There is a lot to tell about advantages and disadvantages of small sensor as the FZ-40, easy zoom optics is a positive, noise is a negative. Also interesting is the type of sensors. I believe that most SLR sensors are CMOS type, whereas most small sensor camera's use CCD's. CMOS gives a digital output instead of analog of the CCD, which is making the system much quicker. And it seems that the more pixels the system gets, the longer it takes for the CCD systems to digitize the output. But the individual pixel processing of the CMOS also seems to generate more noise, not something you would want with already noise sensitive small sensors.
New Reply
Thread Tools
Similar Threads for: Geese dynamics
Thread Forum Replies
What is Dynamics General Physics 4
[SOLVED] Wild geese@pf.com General Engineering 16
Dynamics and action-reaction pairs Classical Physics 11
Dynamics homework help Mechanical Engineering 1
Molecular Dynamics vs Rigid Body Dynamics General Physics 4
