How Does a Magnetic Field Affect a Charged Particle's Motion?
  • Thread starter Thread starter vsage
    Magnetism
The discussion focuses on the effects of a magnetic field on a charged particle's motion, specifically a particle with a mass of 7 kg and a charge of 82 micro-Coulombs entering a 9 T magnetic field at a speed of 92 m/s and an angle of 25°. The participant correctly identified that the magnetic field does not do work on the particle (A is false), the x-component of velocity remains unchanged (B is true), the force acts in the -z direction (C is true), the particle follows a helical path (D is true), and the speed remains constant (E is false). The key takeaway is that the magnetic force is always perpendicular to the velocity, resulting in no work being done.
  • Understanding of classical mechanics, specifically Newton's laws of motion.
  • Familiarity with electromagnetism concepts, particularly the Lorentz force law.
  • Knowledge of vector components and trigonometry for analyzing motion in magnetic fields.
  • Experience with the right-hand rule for determining force direction in magnetic fields.
  • Study the Lorentz force equation and its implications for charged particles in magnetic fields.
  • Learn about the right-hand rule and its applications in electromagnetism.
  • Explore the concept of helical motion of charged particles in uniform magnetic fields.
  • Investigate the relationship between magnetic fields and work done on charged particles.
Students of physics, educators teaching electromagnetism, and professionals in fields involving charged particle dynamics, such as accelerator physics or plasma physics.
vsage
Another magnetism question
A particle of mass 7 kg carrying a charge of 82 micro-Coulombs enters a uniform B field of intensity 9 T at a speed 92 m/s and at an angle of 25° with respect to the field lines as shown in the figure. (Positive y is up positive x is right the field is pointing in the positive x direction and positive z is coming out of the screen)
True/false
A) The field does a finite amount of work on the particle as the particle's trajectory is bent by the field.
B) The x-component of the particle's velocity is unchanged as it passes through the B-Field.
C) The Force on the particle is in the -z direction.
D) The particle follows a helical path.
E) The particle's speed varies as it passes through the B-Field.
I got these answers:
A. True Work = Fcos(theta) and theta is always 90 degrees
B. False magnitude of speed is always the same but direction changes
C. True - right hand rule
D. True - Force is negative z direction but acts circularly in the plane of the field
E. False - Speed can't vary since the force acts perpendicular to the velocity.
Which ones did I get wrong?
Regarding (A), how can the field do work if the force is perpendicular to the direction of movement?
  • · Replies 31 ·
  • · Replies 25 ·
