Relating Voltage to Magnetic Field
This discussion focuses on relating induced voltage to magnetic field strength using a Helmholtz coil connected to an AC power source. The key equation derived is ε = -dΦ/dt, where Φ represents magnetic flux. The induced voltage is influenced by the sinusoidal variation of current, leading to the expression B = ε/(Aωsin(ωt)). The conversation emphasizes the importance of measuring the angle between the loop and the coil's plane to accurately determine the magnetic field strength.
  • Understanding of Faraday's Law of Electromagnetic Induction
  • Familiarity with Helmholtz coil configurations
  • Knowledge of AC circuit theory and sinusoidal functions
  • Basic proficiency in calculus for differentiation
  • Study the application of Faraday's Law in AC circuits
  • Explore the mathematical derivation of magnetic flux in varying magnetic fields
  • Learn about Helmholtz coil design and its magnetic field characteristics
  • Investigate the effects of angular velocity on induced electromotive force (emf)
Physics students, electrical engineers, and anyone interested in electromagnetic theory and applications involving induced voltage and magnetic fields.
llenkic
I did a lab experiment with Helmholtz coil, where we had to build a probe and connect it to an oscilloscope to measure the induced voltage, from the magnetic field produced by the Helmholtz coil. The Helmholtz coils were connected to an AC power source.
Now I have to relate the induced voltage, to the magnetic field strength inside the coils.
[tex]\epsilon[/tex] = -[tex]\frac{d\Phi_{B}}{dt}[/tex]
I know that by Faraday's Law, that a changing magnetic flux will induce an emf. And since the coils were connected to an alternating current, the current is probably varying sinusoidally.
If this were a situation where the area that was changing with respect to time, I would do this
[tex]\epsilon[/tex] = -B[tex]\frac{dA}{dt}[/tex]
since the magnetic flux, [tex]\Phi[/tex]_b = BA cos[tex]\varphi[/tex].
I feel I should do something like that, but have current varying with time, except I am really having trouble relating the magnetic flux to current...
If I understand correctly, you're inserting a loop of wire as a probe into the coil, then measure the induced voltage to get the magnetic field strength of the coil at that point, yes?
If the loop is inbetween the two coils and parallell to the coil's plane, then the induced voltage follows ε = -dΦ/dt = -BdA/dt. As the magnetic field probably isn't homogenous when you insert it directly, have the loop in the middle of the plane of the coil then rotate it to get a better value for B.
Then you can measure the angle between the normal to the plane of the coil and the normal to the plane of the loop as θ. Then the equation becomes ε = -BA*dcos(θ)/dt.
Now assuming that the loop rotates at a constant speed ω, then ε = -BA*dcos(ωt)/dt.
ε = -BA*dcos(ωt)/dt = BAωsin(ωt) from which B = ε/(Aωsin(ωt)).
Although, if using AC current for the coil, then it would be best not to rotate it. Since the magnetic field created by a Helmholtz coil is B = (4/5)3/20nI/R for DC, AC will have I as i*sin(2πft - φ), where i is the peak current.
Then B = (4/5)3/20ni*sin(2πft - φ)/R = B0sin(2πft - φ), where B0 is the peak magnetic field strength.
Thus ε = -dΦ/dt = -AB0dsin(2πft-φ)/dt = -2πf*AB0cos(2πft-φ).
Yes, that's what I had to do, the probe was inserted at the axis of the coil.
So you just replaced the current in the DC expression for magnetic field and replaced it with an AC expression for current? I hadn't thought of replacing B in the magnetic flux equation with an expression for the magnetic field... That makes so much sense, thank you for your help!
