Transformers frequancies possible to use?
  • Thread starter Thread starter aryenudelman
    Transformers
Broadband transformers can effectively operate across a frequency range of approximately 3 decades, such as from 100 kHz to 10 MHz or from 1 MHz to 100 MHz, depending on the impedances and power levels involved. Specialized construction techniques may enhance this capability further. Users interested in utilizing transformers across such frequency ranges should explore broadband pulse transformers for optimal performance.
  • Understanding of broadband transformer design
  • Knowledge of impedance matching techniques
  • Familiarity with power levels in electrical engineering
  • Basic principles of PCB technology
  • Research broadband transformer design application notes
  • Explore impedance matching methods for transformers
  • Investigate specialized construction techniques for enhanced frequency range
  • Learn about PCB coil design for transformer applications
Electrical engineers, PCB designers, and anyone involved in the design and application of transformers across varying frequency ranges.
aryenudelman
Hi to all
is it possible to use the same transformer
in the range of KHZ on the one hand
and on the other the same one for
MHZ?
thanks a lot
aryenudelman said:
Hi to all
MHZ?
thanks a lot
Depending on the impedances and power levels, you should be able to get a broadband transformer to work over about 3 decades (like 100kHz to 10MHz, or 1MHz to 100MHz), or maybe more with specialized construction techniques.
Here's the hit list from googling broadband transformer pulse transformer, including some nice design application notes:
http://www.google.com/search?source...302&q=broadband+transformer+pulse+transformer
What actual frequency range are you interested in?
thanks
it is interesting
is there really option to work in decades like you mention
100k then 10 mhz
can it be a coils for PCB technology
i couldn't find some
thanks
  • · Replies 26 ·
  • · Replies 18 ·
