If wormholes connect two areas in spacetime, wouldn't that require 5
The discussion revolves around the dimensionality of spacetime in relation to wormholes, specifically whether the existence of wormholes necessitates the introduction of a fifth dimension beyond the conventional four-dimensional spacetime described by General Relativity. Participants explore theoretical implications, analogies, and the necessity of extra dimensions in understanding wormholes.
  • Some participants propose that wormholes might require an extra dimension to connect two areas in spacetime, suggesting a five-dimensional framework.
  • Others argue that while extra dimensions may seem necessary for visualization, the mathematics of General Relativity does not require them to describe the curvature of spacetime.
  • One participant emphasizes that wormholes are a theoretical possibility without direct evidence, indicating that their existence remains mathematically speculative.
  • Several participants discuss analogies involving folding paper to illustrate how points can be connected without invoking additional dimensions, with differing interpretations of what this implies about the nature of spacetime.
  • There is a contention regarding whether the analogy of folding a two-dimensional surface necessitates a third dimension, with some asserting that it does not, while others maintain that the analogy's limitations must be acknowledged.
  • Some participants express skepticism about the existence of extra dimensions, while others acknowledge the popularity of the concept in theoretical physics.
Participants do not reach consensus on whether wormholes necessitate a fifth dimension. There are competing views on the interpretation of analogies used to explain the concept, and the discussion remains unresolved regarding the dimensionality of spacetime in relation to wormholes.
Participants highlight limitations in their analogies, particularly regarding the dimensionality of the examples used and the implications for understanding spacetime curvature. The discussion reflects a range of assumptions about the nature of dimensions and their relevance to theoretical physics.
Jonnyb42
If wormholes connect two areas in spacetime, wouldn't that require 5 dimensions? (an extra dimension past 4d spacetime.)
Astronomy news on Phys.org
Well you never can tell, there might be other dimensions. It certainly seems like a popular idea these days, for several reasons. However, are they required to explain General Relativity? Frankly, no. Even in a situation like a wormhole, where spacetime has to bend back and connect to itself, only the curved four-dimensional world we live in has any reality. It may look like extra dimensions are needed to embed that world in some higher dimensional Euclidean space. But since we are confined to our four dimensions, there is no way to detect anything outside that, and it's perfectly consistent to do physics without assuming that anything else exists.
It is my understanding that wormholes are a theoretical possibility yet, currently, WITHOUT direct evidence.
Not saying they can't exist, but keep in mind that their existence is currently purely mathematically related.
This bears repeating. Although human minds may require an extra dimension to visualize what's going on here (To use the lower dimensional analogy, if you imagine a wormhole connecting two points on a piece of paper, we extend the "throat" of the hole into the 3rd dimension. You're assuming something similar for 4d spacetime with wormholes), the mathematics do not require a higher dimension! It's not even a question of whether or not we can in principle detect other dimensions -- this is a separate question entirely. The fact is that within the realm of differential geometry (upon which GR is built), you do not need extra dimensions to curve spacetime.
Ok well, I find that to be crazy.
So can it then be thought of as, scaling?
For instance instead of imagining the x-axis bend into the y direction in some regions, can by the same way imagine the x-axis scaled differently at those "bent" regions?
I am a proponent of "extra-dimensions"
Yet, I find it difficult to find any authoritative/experimental evidence to support this notion.
I have heard that actually we have more than 10 dimension.. would that be possible?
I thought wormholes folded space to connect two points.
A simply analogy, if I draw to points on a piece of paper and then fold it in half so they touch, have I used an extra dimension? Of course not.
If there didn't exist a 3rd dimension you would not be able to fold them and connect the points.
But it does exist, it is already there. There's no need to invoke another dimension.
But your example is connecting two points in 2d spacetime isn't it, there is not 3rd dimension supposedly, yet you used it to connect the two points.
The world is 3D last time I checked. The third dimension is there, even if you're not immediately using it (well, actually you are using it because you can't have only 2D in reality).
your analogy doesn't have the same dimensions as reality, if it did why would u call it an analogy?
Of course it does. To be an analogy it has to be similar, that's all.
http://dictionary.reference.com/browse/analogy
dude, 2d spacetime connecting 2 points through 3rd dimension.
There isn't a 3rd dimension in 2d spacetime...
Are you saying there is 5th dimension in our 4d spacetime?
I'm asking if that's the case.
What are you taking about?
My original question is:
How can there be imaginable wormholes connecting two points in our 4d spacetime without an extra 5th dimension.
The paper analogy is a 2d spacetime, connected were imagining a 3rd dimension to bend the paper into. If your saying that we never introduced a third dimension in the 2d spacetime analogy, then your saying, "yes we have a 5th dimension, it's always there."
Well the way I'm looking at it is that the paper exists within the three dimensions (ignoring others at the moment for simplicity), but we can fold it within those dimensions to join the points.
Think of a balloon, with a piece of string running through the middle. You can 'fold' the balloon so that the ends touch and you never invoke an additional dimension.
Okay.
It's not hard to understand! He's using a 3d piece of paper and folding it to put two distant coordinates next to each other, no extra dimension there
EDIT: He=Jaredandjames
The paper is supposed to be 2d, that is the point. The real fact that it is 3d, (has thickness) is irrelevant. Then your saying our spacetime has thickness in some 5 dimensions??
EDIT: I should say, the fact that a real piece of paper is 3d is irrelevant, because it's not really a piece of paper that were using, it's a hypothetical 2d spacetime, that has no 3rd dimension.
[Note: The piece of paper in what follows is to be thought of a two-dimensional surface, i.e. no thickness]
This is irrelevant, jared. If you want to make your analogy correct, you need to think of it differently. The curvature induced on the piece of paper is a property of the piece of paper and the piece of paper alone. It can be described completely adequately by referring only two two-dimensional coordinates labeled on the paper.
Specifically, you do NOT need a 3rd coordinate to describe the curvature. So while it is true that in every day life to impose this curvature we bend the paper through the third dimension, one does not need to extend this to the universe (as OP would like). That is, the curvature of our universe can be described by referring only to our four dimensions, without any need for invoking a fifth.
The act of "visualizing" a surface necessarily involves an extra dimension. But that means absolutely nothing about the existence of such extra dimensions, only that if we wanted to visualize them, we would need them.
Jared Nathan James = my whole name.
My point with the 3 dimensions is that we must have them, there is no real object that only exists with 2 dimensions. So we're folding with the three and not needing to invoke another, as per your explanation, if you only use the two to explain you don't need to invoke a third.
Nabeshin, that is what I understood from the first couple of posts and I realize I just need to study General Relativity to understand curvature fully.
  • · Replies 16 ·
18K
  • · Replies 22 ·
12K
  • · Replies 111 ·
  • · Replies 0 ·
