New Reply
[SOLVED]Hanging Wire Uniform Magnetic Field
Share Thread Thread Tools
Apr7-11, 09:05 PM   #1
Question
See figure attached.
2. Relevant equations
3. The attempt at a solution
[tex]\vec{F_{b}} = i\vec{L} \times \vec{B}[/tex]
Using my right hand rule, I can see that the force is pushing the wire to the right. This correlates with what is in the drawing.
As the force pushes the wire to the right, due to the finite length of the strings on which it hangs, it will start to move up and to the right.
If I can somehow figure out the force that causes it to move, I can solve for B.
Since the wire is moving to the right and up do I have to relate the force due to the field to the force of gravity somehow?
Thanks again!
EDIT: Solved it. The answer is A I believe.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Galaxies fed by funnels of fuel
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> Google eyes emerging markets networks
New Reply
Thread Tools
Similar Threads for: [SOLVED]Hanging Wire Uniform Magnetic Field
Thread Forum Replies
Find induced E field inside a disk in an uniform magnetic field. Advanced Physics Homework 5
single circular loop of wire filled with a uniform magnetic Introductory Physics Homework 1
Wire Loop falling through uniform magnetic field Advanced Physics Homework 1
Wire Loops, Current, Magnetic Field, & Straight Wire HELP! Introductory Physics Homework 1
