Vector function for the curve of intersection of the paraboloid
The discussion focuses on finding a vector function for the intersection of the paraboloid defined by the equation z = 3x² + 2y² and the cylinder described by y = x². The solution involves substituting the cylinder's equation into the paraboloid's equation and parameterizing the variables using t, specifically setting x(t) = t. The curve passes through the point (1,1,5) but does not pass through (3,3,9), as verified by substituting these coordinates into both equations and confirming the equality holds only for the first point.
  • Understanding of parametric equations
  • Familiarity with 3D graphing concepts
  • Knowledge of paraboloids and cylinders in three-dimensional space
  • Ability to manipulate algebraic equations
  • Learn about parameterization of curves in 3D space
  • Study the properties of paraboloids and their intersections with other surfaces
  • Explore the use of graphing calculators like the TI-89 for visualizing 3D functions
  • Investigate the implications of intersection points in multivariable calculus
Students and educators in mathematics, particularly those studying calculus and geometry, as well as anyone interested in understanding the intersection of 3D surfaces.
DeadxBunny
Original question:
a) Find a vector function for the curve of intersection of the paraboloid z = 3x^2 + 2y^2 and the cylinder y = x^2.
b) Show that this curve passes through (1,1,5) but not (3,3,9).
I really have no idea how to do either parts of this question. Any help would be greatly appreciated! Thanks!
I am not quite sure how y=x^2 is a cylinder in 3d coordinates but you don't need to have a good sense of visualization to do this question (A TI-89 or other device that does 3D graphs might help you though). Substitute one equation into the other and think about each variable as a function of t. As for part b, all you need to show is that where x(t1)=3, y(t2)=3 and z(t3)=9 that either t1!=t2 or t2!=t3 and show that where x(t)=1 that y(t)=1 and z(t)=5. Hope this helps.
DeadxBunny said:
Original question:
b) almost seems too easy... (it seems you don't need the solution to (a) to answer (b) )
If (1,1,5) is an intersection point of two surfaces, then
x=1, y=1, z=5 should yield an equality for both
z = 3x^2 + 2y^2 and y = x^2. Otherwise, it's not an intersection point.
Observe that x=3, y=3, z=9 does not satisfy both equations.
for a),
following up on vsage's comment,
define "t" to be a parameter for the curve, so that ( x(t),y(t),z(t) ) describes a point on that curve. A useful choice is start with is x(t)=t. Then y(t) and then z(t) follow.
  • · Replies 22 ·
12K
