hawaiifiver
- 56
- 1
I can think of two things. Stimulated Emission and Absorption. Would it be possible to do an experiment where you could control coniditions to allow just these two outomes?
Thanks
Thanks
hawaiifiver said:I can think of two things. Stimulated Emission and Absorption. Would it be possible to do an experiment where you could control coniditions to allow just these two outomes?
Thanks
Creator said:Sure; done all the time. Ever hear of lasers.?
A photon is a fundamental particle of light that carries energy. When it is fired at an atom, it can interact with the electrons in the atom, causing them to absorb or emit energy in the form of light.
Yes, firing a photon at an atom can change its energy level. This is because when a photon is absorbed by an atom, it transfers its energy to the electrons in the atom, causing them to jump to a higher energy level. When the electrons return to their original energy level, they emit a photon of light.
The effect of firing a photon at an atom depends on the energy and frequency of the photon, as well as the energy levels of the electrons in the atom. If the energy of the photon matches the difference in energy between two levels, the photon will be absorbed and the electrons will jump to a higher level. If the photon has lower energy, it will not be absorbed and will pass through the atom.
Yes, firing a photon at an atom can cause chemical reactions. This is because the absorption or emission of a photon can disrupt the stability of the atom's electrons, leading to changes in the arrangement of atoms and the formation of new chemical bonds.
Firing photons at atoms has many applications in modern technology, such as in laser technology, communication systems, and medical imaging. It is also used in scientific research to study the structure and behavior of atoms and molecules.
