Water going down a waterfall, where is it warmer?
  • Thread starter Thread starter aeromat
    Water
The discussion focuses on calculating the temperature difference of water at the top and bottom of a 120m waterfall using the conservation of energy principle. The specific heat capacity of water is 4186 J/kg°C. By equating the potential energy at the top to the thermal energy at the bottom, the relationship can be established as mgh = mcΔT. This leads to the conclusion that the temperature increase of the water can be determined by the height of the fall and the specific heat capacity.
  • Understanding of conservation of energy principles
  • Familiarity with specific heat capacity calculations
  • Basic knowledge of potential and kinetic energy equations
  • Ability to manipulate algebraic equations for thermal energy
  • Study the derivation of the conservation of energy equation
  • Learn how to apply specific heat capacity in thermal calculations
  • Explore potential and kinetic energy transformations in physics
  • Investigate real-world applications of thermal energy in fluid dynamics
Students studying physics, particularly those focusing on thermodynamics and energy conservation, as well as educators seeking to explain energy transformations in practical scenarios.
aeromat
Consider a waterfall that is 120m high. How much warmer is the water at the bottom of the waterfall than at the top? The specific heat capacity of water is 4186J/ kg*°C.
Conservation of Energy
Eg [top] = Ek [just before the water hits the ground]
(m)(g)(h) = 1/2(m)(v)^2
I don't know how to compare the warmness of the top to the bottom, or how to get it calculation-wise. Does this have to do with:
E = (m)(c)(T)?
Where "E" is the heat energy?
It's a straightforward conservation of energy.
(1) Potential energy before the fall > (2) Kinetic energy just before it hits > (3) Thermal energy in the water.
You can go straight from (1) to (3)
But would you mind giving me a hint as to how I would go about with the calculations?
  • · Replies 17 ·
