Why Is dz/dt Negative in Cosmology?
  • Thread starter Thread starter Sirius24
    Change Negative
The discussion focuses on the calculation of dz/dt in cosmology, specifically as a function of redshift (z) and the Hubble constant (H_o). The derived equation is dz/dt = (1+z)H_o[1-(1+z)^(3/2)], which indicates that for z > 0, dz/dt is negative. This negative value signifies that the universe is decelerating, leading to a decrease in redshift over time.
  • Understanding of redshift (z) in cosmology
  • Familiarity with the Hubble constant (H_o)
  • Basic knowledge of differential calculus
  • Concept of cosmic expansion and deceleration
  • Study the implications of redshift in cosmological models
  • Learn about the Friedmann equations in cosmology
  • Investigate the relationship between cosmic expansion and the Hubble constant
  • Explore the concept of deceleration in the context of dark energy
Astronomers, cosmologists, and physics students interested in understanding cosmic expansion and the behavior of redshift in the universe.
Sirius24
I am working with cosmology and expansion.
Obtain dz/dt as a function of z and H_o only. What is the sign for dz/dt and why?
z is the redshift and H_o is the Hubble constant.
So I found the equation for dz/dt = (1+z)H_o[1-(1+z)^(3/2)] based on previous sections of this problem. I can see that for z>0, dz/dt is negative. I also have a graph that confirms this. I don't understand why this is true physically.
Why is dz/dt negative?
If I recall correctly, that's because the model you're using is actually decelerating, which means that the redshift will be decreasing with time, making [tex]\frac{dz}{dt}[/tex] negative.
