electromania
- 2
If you arrange infinite amount of charges in a circle, will the electric field anywhere within the circle be zero?
The discussion revolves around the behavior of the electric field in a circular arrangement of charges, particularly focusing on whether the electric field is zero at any point within the circle. The scope includes theoretical considerations of electrostatics and the properties of conductors.
Participants do not reach a consensus, as multiple competing views remain regarding the behavior of the electric field in circular arrangements of charges and conductors.
There are unresolved aspects regarding the assumptions made about the nature of charge distribution and the definitions of "within the circle" versus "within the conducting material."
No. The field within a uniform circle of charge is not zero everywhere, as it would be within a uniform spherical shell of charge.electromania said:If you arrange infinite amount of charges in a circle, will the electric field anywhere within the circle be zero?
Under electrostatic conditions, the field within the conducting material itself will be zero, no matter what the shape of the conductor.electromania said:But why is the electric field in a circular conductor always zero,
Say you have a conducting wire in the shape of a circle, which you charge. The charge will arrange itself on the outer surface of the conductor such that the electric field within the material will be zero. But inside the circle is not part of the conducting material. The field within the circle will not necessarily be zero.aren't the charges arranged in the same way?
