Book stacking - how rigorous is the standard proof?
The discussion revolves around the mechanics of stacking identical books at the edge of a table to maximize the overhang. Participants explore the validity of the standard proof, particularly focusing on the assumptions made regarding the number of books at each height and the implications of these assumptions on the optimal stacking configuration.
  • One participant questions the standard proof by induction, suggesting that allowing multiple books at the same height could lead to counterexamples that challenge the optimality of the solution.
  • Another participant argues that the center of mass (CM) of the top n books is crucial for stability, indicating that only one book is needed at the next level to support the stack.
  • A different viewpoint emphasizes that real-world factors, such as friction and the non-rigid nature of books, complicate the theoretical model and may lead to misleading experimental results.
  • One participant asserts that the proof's purpose is to demonstrate harmonic progression, while also noting that the normal and weight couple is the primary cause of instability, regardless of other forces like friction.
  • Further clarification is provided that if the assumption of one book per level is relaxed, the standard inductive argument for optimal stacking may not hold.
Participants express differing views on the assumptions underlying the standard proof, particularly regarding the number of books allowed at each height. There is no consensus on whether the standard proof remains valid under these conditions, and the discussion reflects multiple competing perspectives.
Participants highlight limitations in the standard proof related to assumptions about book arrangement and the effects of real-world conditions, such as friction and the rigidity of books. These factors may influence the applicability of the theoretical model to practical scenarios.
bcrowell
Staff Emeritus
Insights Author
book stacking -- how rigorous is the standard proof?
There is a classic problem in mechanics, which is that you have n identical books, and you want to place them in a stack at the edge of a table so that they stick out as far as possible. Here is a typical, fairly careful statement of the problem with its solution: courses.csail.mit.edu/6.042/fall05/ln8.pdf (see p. 7).
I tried this on the kitchen table with a stack of encyclopedias tonight, hoping to catch the interest of my daughter. I did, and she tried it herself. One thing that she did made me doubt whether the standard solution by induction is really valid. She would make a stack, see it start to tip over, and then put in another book way in back, low down, to shore it up. This violates one of the assumptions that I haven't seen explicitly stated, which is that at any given height, there is only one book.
Is it possible to find a counterexample to the standard bound by using a stack that has more than one book at the same height?
Or, alternatively, is it possible to prove that putting more than one book at the same height is never optimal?
The CM of the top n books only depends on the positions of those books.
To make a stable stack of n+1 books, you only need to support the top n books at one point, namely directly underneath its CM. Therefore, you only need one book at level n+1.
Real books are not perfectly rigid cuboids with uniform density, and if the surfaces in contact are not all horizontal planes, friction forces come into effect. Practical experiments may be misleading :smile:
The proof in that book is just to show us the application of harmonic progression.Normally in physics we also have to consider the normal from books below, which will form a couple along with the weight force acting downwards.So what your daughter did was just natural to balance the couple and prevent the stack from falling.By the way it was really an interesting application of Harmonic Progression!
Hi, AlephZero,
Thanks for the reply! I'm afraid this argument doesn't really convince me, though. If you assume one book per level, then the proof by induction is straightforward, because the optimal stack of n+1 must be composed of an optimal stack of n on top of the n+1-th book. This is the standard argument. But if you don't assume one book per level, then you can't necessarily assume that the optimal stack of n+1 must be composed of an optimal stack of n on top of the n+1-th book.
Ben
hello bcrowell,
Try to understand what I have told you.It doesn't matter whether friction exists,or any other real situation problem.It is normal and weight couple which causes tumbling of books and no other real life force.Though forces like friction will effect but this is the main reason.I repeat that the explanation given in the pdf file mentioned by you was just to demonstrate the use of Harmonic Progression.Just take a look at the attachment image.
Regards,
Bhaskar
27K
  • · Replies 17 ·
