How do batteries maintain charge
  • Context: High School
  • Thread starter Thread starter peter.ell
    Batteries Charge
Batteries require a complete circuit for electricity to flow from the anode to the cathode due to the presence of a voltage gradient within the electrolyte solution. When the terminals are disconnected, the electrons cannot move freely, leading to a buildup of pressure without a path for discharge. This prevents the battery from short-circuiting and allows it to maintain its charge. Understanding this mechanism is crucial for comprehending battery functionality and efficiency.
  • Basic understanding of electrochemistry
  • Familiarity with battery components: anode, cathode, and electrolyte
  • Knowledge of electrical circuits and voltage gradients
  • Concept of electron flow in conductive materials
  • Research the role of electrolytes in battery chemistry
  • Explore the principles of voltage gradients in electrochemical cells
  • Learn about different types of batteries and their discharge mechanisms
  • Investigate methods to improve battery efficiency and charge retention
Students of electrochemistry, electrical engineers, and anyone interested in understanding battery technology and its applications.
peter.ell
I recently realized that I actually have no idea why batteries need the two terminals connected in order for electricity to flow from the anode to the cathode. After all, if electricity flows when the two terminals are connected, since there is an electrolyte solution between the two, electrons should be able to just flow directly from anode to cathode without having to go through a wire outside of the battery to do so; essentially causing all batteries to short circuit themselves and not be able to hold charge. This seems reasonable, especially considering the tendency for the cathode and anode to want to balance their charges, and the electrolyte solution between represents a perfectly reasonable way to do so in the absence of a more efficient wire connected the two together directly.
But obviously this doesn't happen, why not?
Thank you!
hi peter.ell! :smile:
there's a voltage gradient inside the battery, with every electrolyte "pushing" the one in front …
with the terminals disconnected, there's nowhere for the front one to go, so the others behind put pressure on him, but it doesn't get them anywhere! :wink:
  • · Replies 58 ·
  • · Replies 36 ·
  • · Replies 22 ·
