New Reply
Simulink Max/Min Control
Share Thread Thread Tools
Apr12-11, 08:52 AM   #1
I am modelling the vibration of a 2 D.O.F system with damping in Simulink.
I want to set up control such that if the control value is between two values (max and min) then it sets the control value to the specified input but if it is outside the max and min interval then the control value is set to the max or min as appropriate.
eg.
Fd> Fmax , then set to Fmax
Fd< Fmin , then set to Fmin
If not set to Fd.
Fmax and Fmin will vary slightly throughout the simulation so can not use a max/min since they vary with time during the simulation.
Any ideas how it will be best to do this. Basically going to be three inputs into the block from the system which need to be evaluated and then the appropriate input set as the output.
I have tried IF blocks but they won't work properly for the simulation.
Thanks
Dan
PhysOrg.com
PhysOrg
engineering news on PhysOrg.com
>> Researchers use light projector and single-pixel detectors to create 3-D images
>> GPS solution provides 3-minute tsunami alerts
>> Single-pixel power: Scientists make 3-D images without a camera
Apr12-11, 09:53 AM   #2
I've responded to your post in the Engineering Systems & Design sub-forum. Please refrain from double posting.
New Reply
Thread Tools
Similar Threads for: Simulink Max/Min Control
Thread Forum Replies
Simulink Max/Min Control Engineering Systems & Design 3
Three Tank Control System on Simulink Engineering, Comp Sci, & Technology Homework 0
pid controller for position control in amb simulink help Engineering Systems & Design 2
Proportional control, Integral control Mechanical Engineering 0
dimmer or router speed control as resistance heater level control Electrical Engineering 11
