Register to reply
Quantum, commutation, suffix
by Chronos000
Tags: commutation, suffix
Share this thread:
Chronos000
#1
Apr12-11, 10:04 AM
P: 80
The question asks for [Xi^2, Lj]
I can get to the line:
ih(bar) Xk ekjl Xl + ih(bar) ekjl Xk Xl
this line must be zero but I don't see how it is.
It looks like an expansion of a commutation between Xk and Xl but not quite right
Phys.Org News Partner Science news on Phys.org
FIXD tells car drivers via smartphone what is wrong
Team pioneers strategy for creating new materials
Team defines new biodiversity metric
tiny-tim
#2
Apr12-11, 10:33 AM
Sci Advisor
HW Helper
Thanks
tiny-tim's Avatar
P: 26,148
Hi Chronos000!
(try using the X2 and X2 icons just above the Reply box )
Quote Quote by Chronos000 View Post
That's just 2ih(bar) Xk ekjl Xl.
Maybe the second one should be ih(bar) Xk eljk Xl ?
Chronos000
#3
Apr12-11, 03:26 PM
P: 80
I done it again
got ih Xo ejmo Xm + ih ejmo Xm Xo
can I switch the order of the last X operators and put a negative in front? which would give me a commutation
why did u say the previous solution was 2ih(bar) Xk ekjl Xl when the order was different in the last expression?
vela
#4
Apr12-11, 04:04 PM
Emeritus
Sci Advisor
HW Helper
Thanks
PF Gold
P: 11,757
That is equal to 0 because XoXm is symmetric while ejmo is antisymmetric.
Chronos000
#5
Apr12-11, 04:19 PM
P: 80
I'm sure I've seen something like this before but I really don't have a clue how you can see which is symmetric or not
vela
#6
Apr12-11, 04:25 PM
Emeritus
Sci Advisor
HW Helper
Thanks
PF Gold
P: 11,757
XoXm is symmetric because you can swap the subscripts without changing anything, i.e. XoXm=XmXo. The tensor ejmo on the other hand is antisymmetric because it changes sign when you exchange a pair of subscripts, i.e. ejmo=-ejom.
tiny-tim
#7
Apr12-11, 04:56 PM
Sci Advisor
HW Helper
Thanks
tiny-tim's Avatar
P: 26,148
Hi Chronos000!
sorry, I wasn't thinking straight earlier
vela is right, ejmo is antisymmetric, so if you multiply it by something symmetric (in 2 of the 3 indices in ejmo), you get 0
(when you do all the adding, for example you add ej12X1X2 and ej21X2X1 the latter is -ej12X2X1 = -ej12X1X2)
Chronos000
#8
Apr12-11, 05:09 PM
P: 80
thanks for your replies. So my expression is just 0 + 0. I don't do anything like you have done in your final comment tiny-tim?
Are you allowed to change the position of the epsilon yes? as it does really "act" on anything but just tells you what the cross product is.
tiny-tim
#9
Apr12-11, 05:15 PM
Sci Advisor
HW Helper
Thanks
tiny-tim's Avatar
P: 26,148
That's right
I only did that to prove that it works, but you can just say "it's obvious!"
You can change the position of any whole thing
what you can't do is change the position of indices (unless they're symmetric indices, in which case you can, or unless they're anti-symmetric indices, in which case you can if you multiply by -1).
Chronos000
#10
Apr12-11, 05:22 PM
P: 80
thanks I'm pretty happy with this now
Register to reply
Related Discussions
Quantum mechanics, suffix notation Advanced Physics Homework 5
Integral with suffix notation Calculus & Beyond Homework 1
Quantum commutation identity Advanced Physics Homework 2
Commutation relations in relativistic quantum theory Quantum Physics 7
Ic suffix in chem nomenclature Biology, Chemistry & Other Homework 2
