New Reply
Surface charge, electric fields, and capacitance
Share Thread Thread Tools
Apr14-11, 09:23 PM   #1
Two large conducting sheets are charged with a positive surface charge density. They stand vertically facing each other a distance d apart.
a.) suddenly, we shrink the left sheet to a square with sides equal to d, what is the field at the point along the central axis of the smaller sheet a point directly between the two plates?
b.) By shrinking both sheets to a square with sides equal to d, let each sheet have oppositely charged sufaces with two dielectrics (K1, K2). what is the relationship between E1 and E2 for a series configuration?
c.) Alternatively for b) what is the E-Field relationship for a parallel configuration when the sheet's contact area is shared equally?
d.) what is the equivalent capacitance in each case b) c)?
2. Relevant equations
C = (K*Epsilon*Area)/d
Efield at a point from a surface charge is = integral of kq/r^2 dq
dq = sigma dA
3. The attempt at a solution
I don't really know where to begin with this....I know in between two parallel plate capacitors the field is uniform and it will change with the change in one plate but the question does not explain what the original dimensions are....and when one shrinks that means the field wont be uniform....
But how do I figure out exactly what that is?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Heat-related deaths in Manhattan projected to rise
>> Dire outlook despite global warming 'pause': study
>> Sea level influenced tropical climate during the last ice age
Apr14-11, 09:24 PM   #2
I want to take this one step at a time so I want to address A.) first
New Reply
Thread Tools
Similar Threads for: Surface charge, electric fields, and capacitance
Thread Forum Replies
Electric fields and net charge General Physics 3
Electric Fields and Surface Charge Densities on Conducting and Non-Conducting Sheets Introductory Physics Homework 1
[SOLVED] Capacitance and electric fields Advanced Physics Homework 2
Electric charge and fields: uniform electric field Introductory Physics Homework 1
Electric charge and fields Introductory Physics Homework 7
