Quick easy question to make sure i got this
  • Context: Undergrad
  • Thread starter Thread starter Gecko
The discussion revolves around determining the domain of the function f(x) = √(x-1). Participants explore the implications of different interpretations of the domain, particularly in the context of real numbers versus complex numbers, and clarify notation related to interval representation.
  • One participant suggests that the domain of f(x) = √(x-1) is (1, ∞), questioning this interpretation.
  • Another participant asserts that x = 1 should be included in the domain, proposing that it should be [1, ∞).
  • A third participant argues that the question is poorly posed, noting that if f is defined over the reals, the domain could be any subset of [1, ∞), and that the context of the codomain is crucial.
  • Further clarification is sought regarding interval notation, specifically the meanings of [x,y) and (x,y), with one participant explaining that [x,y) includes x but not y, while (x,y) excludes both endpoints.
  • Another participant expresses frustration with the question's formulation, suggesting it lacks precision and should specify the maximal domain under consideration.
Participants express disagreement regarding the formulation of the question and the interpretation of the domain. There is no consensus on how to best define the domain or the implications of the question's wording.
Some participants note that the question's ambiguity arises from the lack of specification regarding the codomain and the definition of the function, which complicates the determination of the domain.
Gecko
does the domain of [tex]f(x) = \sqrt {x-1}[/tex] equal [tex]dom(f) = (1,\infty)[/tex]? if wrong, can you tell me what i did wrong? thanks.
x = 1 would be included.
f is (presumably) a function into R, and then taking any subset of [1, inf) as its domain will also work. However, if you set f's codomain equal to C (the complex numbers), then its domain could be any subset of R or C... It doesn't seem like a particularly well-posed question.
the question was exactly "What is the domain of [tex]f(x) = \sqrt {x-1}[/tex]?" so the answer is [tex]dom(f) = [1, \infty)[/tex]? and its in the very begginning of the book so i don't think it would go into complex numbers (seeing as i have no idea what they are) i just wanted to make sure i was understanding the material up to this point.
oh yeah, does [x,y) mean the the domain can be equal to or greater than x and greater than y, or is it less than y? and (x,y) means that its greater than x and y or just less than y? i was confused with this in the book as well (wish the answers where in the back >.<)
Your book is very sloppy in asking this (along with most other books).
What it should have said is:
(Given that the value of f should be a real number), What is the MAXIMAL domain we can assign to this function?
The parenthesized condition might be dropped.
[x, y) means that the domain is equal to or greater than x, but less than y.
(x, y) means that the domain is greater then x but less than y.
It isn't a well posed question. In fact it is an abhorrently incorrect question that makes many of us of the 'pure' persuasion want to commit murder. However, it is also a very common [kind of] question, and one must always append the words: where the function is considered as a subset of RxR, and the domain is maximal with respect to this property.
(Not for the digestion of the OP, but perhaps for Muzza: the domain could be taken as any algebraically closed field, and seeing as no range is specified at all even that is assuming too much. The domain and Range are part of the definition of the function and should not be omitted. But that doesn't stop every calc/pre-calc course I've seen doing this.)
