Thread Closed
Classical and Quantum Mechanics via Lie algebras
Share Thread Thread Tools
May27-11, 07:21 AM   #52
Recognitions:
Quote by PAllen View Post
I was really intrigued by Neumaier's approach until I read this discussion and what it predicts for this case. Why use buckyballs? Something much simpler: any atomic or molecular beam prepared to interfere in the double slit experiment with deposition on plate that contains none of that atom or molecule. Run it only long enough for sparse deposition, and check for individual atoms consistent with an interference pattern. Shouldn't be hard to do (e.g. silver on glass plate).
I would literally bet a million dollars that the outcome would be consistent with conventional interpretations and falsify Neumaier's.
Note that doing the experiment is far from easy. You need to make sure that
(i) the absorbing surface is completely silver-free,
(ii) one and only one silver atom is emitted by the source,
(iii) The silver field at the absorber had no time to redistibute itself during the procedure it takes to search the absorber for a single silver atom.
May27-11, 05:55 PM   #53
Quote by strangerep View Post
Sorry, I can't stay silent. The never-ending torrent of such sensationalist ill-informed remarks is getting a bit tedious.
The whole point about interpretations is that every interpretation predicts the same things for any given experimental setup. If they didn't, then interpretations would be experimentally decidable, and those in contradiction with experiment would be discarded. Arnold's interpretation is just that -- an interpretation. It does not contradict experimental results, but rather offers a more rational way of thinking about QM.
And others did "figure it out" (in related forms). Arnold already said elsewhere that his initially naive views about particles in QM were improved considerably after discussions with experts in quantum optics years ago.
If you want to search for a "right" interpretation, first master the most essential and basic interpretation, i.e., "shut up and calculate". Everyone with an interpretation must master "shut up and calculate" first, since that's what decides whether QM is or isn't in contradiction with experiment.
Mainstream Quantum Interpretations are only accepted as valid candidates if they are at least scrutinized by 500 physicists. Neumaier's interpretation just less than ten. That is why I'm inviting others to help scrutinize it. You, Strangerep, is on Neumaier's side. So those who are neutral or can see the logical flaw of Neumaier's such as Pallin pls. elaborate. If at the end of the day, you can't see any theoretical flaws and agree it's a valid interpretation candidate. Then state so in order to make Neumaier's Interpretation part of pop-sci books.
Regarding buckeyballs, atom interferometry, etc, the generic features of the "shut up and calculate" interpretation for a field incident on a double-slit were explained in post #73 of this thread:
http://www.physicsforums.com/showthr...82#post3171882
with an additional bit in post #78.
The more accurate calculations with a relativistic quantum field instead of a classical field do not change the gross features significantly. (Mandel & Wolf give details.)
It's an incident field, and it's already been discussed in the thread I mentioned above. The calculations from Mandel & Wolf indicate the probalistic nature of the predictions.
May27-11, 05:59 PM   #54
Quote by A. Neumaier View Post
How could this have been figured out before 1911, at a time where not even the Schroedinger equation was discovered? The reason why it hasn't been discovered is that those working on the foundations rarely also work on quantum fields, and those who work on the latter usually have more pressing things to do than to indulge in foundational issues. So the interface between foundations and quantum fields has been very little explored.
A quantum field transports the energy in the same way as a classical field, namely by evolution according to the field equations. The energy of a radially expanding field is distributed uniformly.
So an extremely tiny amount of energy arrives at any place of the hollow sphere, integrating over the sphere to the energy of one electron. Thus energy is conserved. The probability of response anywhere is extremely tiny, too, so that uncertainties in the sphere by far dominate the effect, and nothing can be concluded.
Pallin, what can you say about Neumaier's explanation above? If he is right... since you want to bet a million dollars against him... then Neumaier's would be richer by 2.3 million dollars because a Nobel Prize money is about 1.3 million dollars... lol...
Others pls. join scrutinize Neumaier's Interpretation and either support it doesn't violate some known principles or have theoretical flaws or point out the flaws if you can so Neumaier would be aware of them too, and can either improve them or just call it a day.
May27-11, 06:11 PM   #55
Recognitions:
Gold Membership Gold Member
Actually, I am not able to give expert critique of Neumaier's theory. From what I do understand, I like it if it were just an interpretation. I just responded the discussion with spectracat, where both agreed that standard QM and Neumaier's theory actually made a different prediction. That makes it not just an interpretation (similar to, if you believe some of Deutch's proposals, MWI is testable). Given the difference in prediction, my physical intuition finds the standard prediction much more plausible, enough for me to bet on it. Given this I simply wanted to raise that buckyballs are not needed - just something easy to detect that is not in the receiver.
I would be very interested in strangerep commenting on the prediction difference and the feasibility of an experiment. Strangerep knows this area *much* better than I.
May27-11, 06:12 PM   #56
Quote by Varon View Post
Pop-sci!???? Why would you want such a thing in the first place???
I thought we were talking REAL science here.
May27-11, 08:20 PM   #57
Recognitions:
Yup .. that is why I proposed cooling the detector plate to 4K (or below), so that the atoms would stay in their original impact locations.
I would also modify (ii) to say that exactly one silver atom impacts the surface between imaging steps.
Cooling the detector is easy .. I have multiple 4K cryostats in my own lab. A much bigger problem is making sure that you only have a single atom coming through at a time, I can imagine several approaches to achieving that, but they are all non-trivial, and I am not sure they would work. Even if you could achieve that, imaging a single atom is extremely hard, unless you can narrow down its position to a fairly small region.
I think these experiments are doable, but would require at least a million dollars worth of equipment to achieve. As interesting as I find Neumaier's proposal, I am sad to say that I don't think there are many experimentalists out there willing to commit those kinds of resources to this project.
May27-11, 09:22 PM   #58
Quote by Oudeis Eimi View Post
Pop-sci means popular science and includes books from Brian Greene, Gribbin, and other pop-sci books. Brian Greene and others have mentioned all existing interpretations but not Neumaier Interpretation. Hence if it's valid, then it should be part of pop-sci books so people would have options that is based on QFT.
May27-11, 09:29 PM   #59
Quote by SpectraCat View Post
CERN and Fermilab have resource and budgets. I wonder how to introduce Neumaier approach to them. If they can prove Neumaier conjecture... they would get the million dollars back as a Nobel Prize money amounts to 1.3 million dollars. Remember the scientists who were able to prove Einstein Photoelectric effects.. they won a Nobel too.
May28-11, 01:17 AM   #60
in the thread http://www.physicsforums.com/showthr...Interpretation there is an unanswer message from JesseM about Neumaier Interpretation and Bell's Theorem. The last message of it points to this thread so let us continue where it left.
In message #14, Strangerep (lone known supporter of Neumaier Interpretation) states:
"No. States do not consist of "definite outcomes". Although one might like to think of individual events in experiments as definite outcomes, all experiments involve some level of statistical analysis."
JesseM answered:
I think you're talking about statistical analysis used in coming up with values of variables for the quantum system itself, but I was talking about the macroscopic "pointer state", like the number that appears on a computer monitor after it runs its statistical analysis program (or the numbers representing raw data before analysis, which may not directly correspond to any quantum observable). That's an element of the physical world too, one which we can directly observe, if Neumaier's interpretation only gives probability distributions for such macro-states rather than definite values, then I would say it isn't a full model of the "one world" we find ourselves in. Again, I'm not requiring that a full model allow such states to be predicted in a deterministic way, it'd be fine if it had a stochastic element which randomly picks one macrostate based on the probability distribution, but as I said this element would have to be a nonlocal one.
Think of it this way: suppose you want to build a simulated universe running on a computer (or collection of computers, see below), and the simulation is supposed to model all the types of macrostates we can directly observe (while it doesn't need to have any model of microstates which we only infer based on macrostates). The model need not predict the results of particular trials of any real-world experiment, but we should be able to create a model of the same type of experiment on our computer(s), with the simulation yielding a series of macroscopic pointer states whose overall statistics should match the results of analogous experiments performed in the real world. If we require that the simulation be a "local" one, then we could imagine a bunch of computers which were each responsible for simulating a small element of space, and on each time-increment the computer should give an output based only on inputs from other computer outputs that lie within its past light cone (this is assuming the laws of physics can be approximated arbitrarily well be a simulation with discrete "pixels" of space and time; if not, you could imagine replacing the finite array of computers with a perfectly continuous array of "functions" at each point in space, which continuously produce outputs at each instant of time based only on inputs from points in their past light cone). And the computers can have stochastic random number generators built in, so if part of their output consisted of a probability distribution, they could also use that probability distribution to randomly select one specific output based on that distribution.
If observable macrostates in a region of space at a particular time are just a function of all the computers' outputs in that region at that time (outputs which may be thought of as "microstates" for specific points in space), then the point here is that no "local" simulation of this type, where the computers have no access to inputs outside their past light cone when generating outputs, can ever give a pattern of macrostates consistent with QM. Even if computers at each point can generate probability distributions in a local way, a stochastic rule for generating specific outcomes based on these probability distributions would have to operate nonlocally, with computers representing points at a spacelike separation coordinate their random choices to make sure they created the correct entanglement correlations. This is just a natural consequence of Bell's theorem. So, I think it's misleading to call Neumaier's interpretion a "local" one, it either fails to model the fact that we see particular outcomes for macroscopic pointer states (which all other interpretations attempt to account for) rather than just probability distributions, or if the model is made to include a stochastic rule for generating a series of particular macrostates, then the rule must operate in a nonlocal fashion.
Then in Message #16 there. Strangerep quoting JesseM in the above "I think it's misleading to call Neumaier's interpretion a "local" one" said: "I'll leave that one for Arnold to answer in due course."
Ok. Arnold, Pls address JesseM argument that Neumaier Interpretation is not a local one. It seem you tried with superior mathematics to prove that Bell's Theorem and Aspect experiment are just local ones with hidden variable and they don't really have non-local correlations in spite of numerous experiments to the contrary that carries positive result of violation of Bell's Theorem. Arnold Neumaier. Are you trying to say that Bell's Theorem is not really violated. Or the violation is as a result of hidden variables?
May28-11, 07:25 AM   #61
Rap
I guess I missed it - what exactly is Neumaier's prediction (measurement-wise) for one or many buckyballs (or other particles not present in the detector) sent through a double slit? What would happen if one went looking for individual buckyballs at the detector?
May28-11, 07:42 AM   #62
Quote by Rap View Post
Neumaier said that since there is no particle, there is no need to explain where the particle (or Buckyball) goes. Here's Neumaier answer in message #35:
"Most electrons in a real material are there smeared out in a way that the particle picture is misleading. Chemists use electron densities, not electron positions to describe things. Thus a newly arriving delocalized electron is nothing very special to the detector.
In an interference experiment, neither the electron nor the buckyball is a particle, since the latter is a semiclassical concept without meaning in case of interference. Since there is no particle, there is no need to explain where the particle goes.
The density of the electron field or the buckyball field increases at the target - that's all that can be said, and this is enough for verifying what one can actually measure - e.g. the silver film in a Stern-Gerlach experiment after a macroscopic amount of silver accumulated."
What do you think?
May28-11, 10:10 AM   #63
Rap
What do you think?
Well, I read that, but it is still not clear to me what the prediction is. If we shine a beam of buckyballs (plane wave function for buckyballs) on the double slit, what happens at the detector?
I think that the "beam" will be diffracted, and its intensity at a point on the detector will give the probability of detecting a buckyball strike at that point. For many buckyballs, this will give the density of buckyball strikes in the neighborhood of that point. If a buckyball just embeds in the detector without being destroyed, then you should be able to use an electron microscope to find it.
May28-11, 06:51 PM   #64
Isn't it that Arnold Neumaier approach supposed to make the measurement problem non-existent? But according to The_Duck reply in the Quantum forum about QFT and Particles that:
"The measurement problem has nothing to do with particles in particular. The measurement problem is how we get from a superposition of states to one single observed reality. QFT has superposition in exactly the same way as nonrelativistic quantum mechanics, only now it is superpositions of different possible field states instead of different possible particle positions or whatever."
What really is Neumaier position about this?
(btw.. I love to call him Neumaier as it is unique and like von Neumann.. both of them very skill mathematician... calling him Arnold would keep reminding me of Arnold Schwarzenegger.... a brute physical force compare to von Neumann pure intellectual might... lol)
May29-11, 02:08 AM   #65
What? According to the new von Neumann of the 21th century. The particle is never a particle in the first place but just quantum field or wave. So what happens is that (according to him) "It arrives at the various places of detector with different intensities, and these intensities stimulate all the electrons. But because of conservation of energy, only one can fire since the first one that fires uses up all the energy available for ionization (resp. jumping to the conduction band), and none is left for the others"
Therefore you can't find any single buckyball at the detector. They are smeared all over the detector. I don't know if he means the atoms of say a 430-atom buckyball became become fragmentalized all over the detector or the buckyball just divides into many parts that is still interconnected. Hope others can clarify.
May29-11, 03:32 AM   #66
Recognitions:
[...] it is still not clear to me what the prediction is. If we shine a beam of buckyballs (plane wave function for buckyballs) on the double slit, what happens at the detector?
I think that the "beam" will be diffracted, and its intensity at a point on the detector will give the probability of detecting a buckyball strike at that point. For many buckyballs, this will give the density of buckyball strikes in the neighborhood of that point. [...]
Exactly. The math (as in Mandel & Wolf) just predicts probabilities for interactions occurring (between incident field and detector) in any given region of the detector, in any given time interval. Arnold's interpretation is just an interpretation -- it doesn't make an experimentally testable prediction by itself separate from the theory. The math that actually makes a prediction is the same as mainstream quantum theory.
Quote by Varon
Strangerep (lone known supporter of Neumaier Interpretation) [...]
... maybe because I've actually worked through large amounts of the detail in his book, and his other papers on quantum theory.
I'd like to remind readers of this thread that Arnold's original purpose in opening this thread was to seek feedback on the presentation in the book prior to publication. (See opening post.) There's a LOT more in the book than just an interpretation, and much of it could benefit from feedback indicating specific areas which are unclear, or mis-sequenced, etc, etc. I.e., the sort of feedback that helps turn a draft into a publication.
Edit: One important theme in the book is already implicit in the title:
"Classical and Quantum Mechanics via Lie algebras".
Arnold addresses both the classical and quantum cases, also thermodynamics, and relates them with considerable insight into their common features, interwoven with Lie-algebraic ideas. This commonality (once comprehended) was a real eye-opener for me when I first began to understand it.
May29-11, 09:32 PM   #67
Recognitions:
There is a discrepancy in here somewhere. Arnold and spectracat agreed that Arnold's theory predicted that a single buckyball diffracted by a double slit would not lodge at any single location on detector screen (it would activate, e.g. electrons in the detector, but would not, itself, lodge at one point). Spectracat and I believe that standard QM predicts the buckyball will lodge at one place, with the location consistent with the propabilities of the interference pattern. Arnold agreed this experiment would distinguish his theory from convention QM.
Please clarify the situation.
May30-11, 04:23 AM   #68
Recognitions:
Re-reading the earlier posts in this thread, I'm not sure they really "agreed" on very much. But I must leave that for Arnold to clarify since he understands his work much better than I do. :-)
I would have expected that it depends on the details of the interaction Hamiltonian between a (quantum) buckyball field and the spatial array of atoms in the detector, i.e., whether the interaction Hamiltonian allows the formation of a bound state between the buckyball and the detector atoms (both considered as localized fields), or just some sort of excitation of the electrons of the atom(s) in a region of the detector, or maybe a combination of both. I don't see it as being a test of an interpretation though, since the detailed predictions must still be calculated using standard QM/QFT machinery once the interaction Hamiltonian is specified.
Thread Closed
Thread Tools
Similar Threads for: Classical and Quantum Mechanics via Lie algebras
Thread Forum Replies
Do I need Classical mechanics and waves in order to understand Quantum mechanics???? Academic Guidance 22
hydrogen atom obeying classical mechanics rather than quantum mechanics Introductory Physics Homework 6
Classical and Quantum Mechanics via Lie algebras General Physics 0
Classical vs Quantum Mechanics General Physics 1
classical and quantum mechanics General Physics 6
