Thread Closed
Li alloy powders
Share Thread Thread Tools
Oct22-04, 03:35 AM   #1
Li alloy powders
I need the test methods for the Li alloy powders. What type of a test is needed to determine the content of the alloy? For instance Li-Al alloy? I couldn't find a suitable test for these powders (as known, these alloy powders are air and humidity sensitive, difficult to handle)
PhysOrg.com
PhysOrg
engineering news on PhysOrg.com
>> Researchers use light projector and single-pixel detectors to create 3-D images
>> GPS solution provides 3-minute tsunami alerts
>> Single-pixel power: Scientists make 3-D images without a camera
Oct25-04, 02:33 PM   #2
Recognitions:
Gold Membership Gold Member
Retired Staff Staff Emeritus
Can you not get spectroscopic analysis done by a lab ?
Oct26-04, 08:45 AM   #3
Quote by Gokul43201
These alloys, as known, are kept in inert(Ar) atmosphere. As contact with the humidity in the air or the air itself, it immidiately form oxide or hydroxides. So this limits me to carry out ordinary determination analysis. Would ICP work in this case? Or another think is that to convert the Li-Al alloy to its oxides, and then make wet analysis... I am not sure...
Nov14-04, 07:49 PM   #4
Recognitions:
Li alloy powders
You can disperse the powder in an inert glue (such as those typically used for powder samples) and do XRD analysis to determine composition. The glue will prevent reaction with O2 or H2O. The only problem is that XRD does not have very high resolution for determining composition. You might have an error as big as 2 or 3% depending on the quality of XRD machine itself and sample size.
Thread Closed
Thread Tools
Similar Threads for: Li alloy powders
Thread Forum Replies
Dissolving the powders in tea bags Chemistry 3
heat treatment of Al alloy Materials & Chemical Engineering 1
Separating an alloy Chemistry 1
searches of nd-fe-b alloy Atomic, Solid State, Comp. Physics 3
Removal of oxygen on Boron powders Materials & Chemical Engineering 2
