Cancelling out units in an equation
  • Thread starter Thread starter andrewvidler
    Cancelling Units
The discussion revolves around the manipulation of units in the context of calculating viscosity, which is expressed in Pascals per second. The original poster presents an equation involving various physical quantities and seeks assistance in the final step of unit cancellation.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss methods for organizing and simplifying units in a fraction. One participant describes a systematic approach to writing units in a single fraction and simplifying them. Another participant questions the correct unit representation of viscosity and offers a breakdown of the relationship between pressure and its units.
The conversation is ongoing, with participants exploring different interpretations of viscosity units and how to convert them appropriately. Some guidance has been provided regarding unit simplification, but there is no explicit consensus on the final unit representation.
There is a mention of confusion regarding the correct units for viscosity, with one participant asserting that viscosity is measured in Pascal-seconds, while another suggests a different representation. The original poster's final units are noted as 453 kg/sm, which raises further questions about conversion to the standard units of viscosity.
andrewvidler
Hi i have done all the work for this problem calculating viscosity and i come to the last part where i need to manipulate and cancel out units to come to a final solution. The equation works out as
viscosity = 0.0042m^2 x 9.8m/s/s x 11,401.4kg/m^3 all divided by 1.034466m/s
viscosity is measured in Pascals/sec
can someone help me with the last step with the units
thanks
I usually start by drawing a long horizontal line and writing all the units in the denominator or numerator as appropriate. Thereby, dividing by a/b means writing b "above" and a "below" (as dividing by a/b means multiplying by b/a).
In this case, going through them one by one, you'd get
[tex]\frac{m^2}{1} \times \frac{m}{s \times s} \times \frac{kg}{m^3} \times \frac{s}{m}[/tex]
If you write this in a single fraction, and take the similar units together, you get
[tex]\frac{m^3 \, s \, kg}{s^2 \, m^4}[/tex]
which is straightforward to simplify.
Now to check that this is indeed Pa/s, it is easiest to convert Pascals into kg/m/s. Personally, I find it easiest to remember that pressure is force per unit area, and Newton's law is F = ma, so
[tex][Pa] = \frac{[F]}{[A]} = \frac{[m] [a]}{[A]} = \frac{kg \times m/s^2}{m^2} = \frac{kg \times m}{s^2 \times m^2}[/tex]
welcome to pf!
hi andrew! welcome to pf! :smile:
(try using the X2 icon just above the Reply box :wink:)
nooo :redface: … viscosity is measured in Pascal.sec :wink:
thanks - my final units are 453 kg/sm. any chance on helping me how to get this into pascals which are measured in mPa s?
Pa.s = force.time/area = mass.time.acceleration/area
= mass.time.distance/time2.area :wink:
